Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 2012-09-21, 10:08 AM   #46
Alan Hogan
The Highland unicyclist
Alan Hogan's Avatar
Quote:
Originally Posted by enaddi View Post
I am going to schlumpf it Any idea how i could calculate the spokelenght? I thought about 6 spokes and then 2 "emty holes.
the existing spokes are about 315, it might be worth trying them??
Alan Hogan is offline   Reply With Quote
Old 2012-09-26, 05:55 PM   #47
Nurse Ben
XC Muni
Nurse Ben's Avatar
Picked up my 32" Maxxis Advantage Frankentire at the shoe repair shop, they stitched between the knobbies and down the sidewall, currently drying from a liberal application of liquid rubber that I painted onto the seams and joints, should be ready to mount for tonight's romp in the woods :0
Pictures to follow...I'm soooo excited
If this thing stays together, I'm making a 2.25 Ardent next!
http://www.maxxis.com/Bicycle/Mountain/ADvantage.aspx
26X2.10 ( 52/53-559 ) Black, 120tpi, FOLDABLE, 555gm, DUAL 65 eXC/Silkworm
Finished weight is less that 700gm
__________________
I dream of hamsters and elderberries
Nurse Ben is offline   Reply With Quote
Old 2012-09-26, 06:06 PM   #48
knoxuni
wes style!!
knoxuni's Avatar
Send a message via Skype™ to knoxuni
that is SWEET! do you want to let me barrow it
__________________
Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
knoxuni is offline   Reply With Quote
Old 2012-09-27, 01:36 AM   #49
Nurse Ben
XC Muni
Nurse Ben's Avatar
Step One: The big cut or as I thought at the time, "the big committment". I did a simple 2" overlap, this was a tense moment
Step Two: Grind and prep for gluing, not so bad if you have got a dremel and a razor knife, maybe twenty minutes worth of grinding and smoothing, the easy part
Step Three: Figuring out the bead diameter. I glued one side and let it set up, then I used the original tire and a bunch of binder clips, lined it up and went for it!
Step Four: The final glue up using Barge contact cement, highly recommended. I tried vulcanizing tire glue first and it did not work. Barge was excellent, easy to work with, even allowed some fine adjusting. Note: Use the tires "lines" to get the sidewalls straight; mucho importante!
Step Five: The shoe repair guy sewed my treads and saves me hours of pain and suffering, he went up and down the sidewallsbetween the knobbies, and along the beads. This is the shot from inside, total cost $20
Step Six: Applyied rubber armor over the seam and threads, this is some good stuff, kinda like a fibrous shoe goo, designed to protect leather boot toes, also works for frankentires
The weigh-in, drum roll.....yes folks, that is the correct weight
Final product after the first big ride, two thumbs up!!
No complaints, this is a great riding wheel, well worth the effort, the tire worked very nice, much better than the stock tire. The Maxxis Advantage Silkworm is a racing tire, so kinda soft in the sidewall for tech muni, so my next tire project will be an Ardent 2.4, then I'll use the Advantage as my back up tire.
The tire dimensions are fairly close to the stated dimension of 2.1", which worked out to be 3/8" taller and wider than the stock tire. There is a slight hump at the joints which can be seen when I spin the tire. I shaved the center knobby slightly right at the seam, so the hump is <1/8" and not noticeable when riding. I had a sllight stretching of the rubber at the center line of the tread, but no noticeable stretching at the sidewall.
I pumped it up to 40psi and it held fine, backed it down to 25psi for tonight's trail riding which felt about right for the tire "design".
If you are on the fence about doing this project for yourself, don't be, the wheel is plenty strong for muni and franketire build is easy. It feels like a tall 29er, easier to throw around than a 36er, but faster than a 29er.
__________________
Old 2012-09-27, 01:49 AM   #50
saskatchewanian
ERIC P
saskatchewanian's Avatar
That looks great Ben! Congrats on your first frankenbaby!
__________________
saskatchewanian is offline   Reply With Quote
Old 2012-09-27, 04:01 AM   #51
OutdoorJunkie
Addicted to muni!
OutdoorJunkie's Avatar
Awesome! That looks great What do you think the 2.4'' wire bead model would be like as a 26'' muni tyre? I hear it is WIDE and the tread pattern looks good.
OutdoorJunkie is offline   Reply With Quote
Old 2012-09-27, 04:19 AM   #52
UPD in Utah
Unicyclist
UPD in Utah's Avatar
Oh, Ben....
.... you've created a lovely mutant monster, that even looks potentially ridable by mere mortals. And must be fast/fun fun/fast too.
Nice work on Project-32!
UPD in Utah is offline   Reply With Quote
Old 2012-09-27, 12:51 PM   #53
Nurse Ben
XC Muni
Nurse Ben's Avatar
Wire bead won't work, you can stitch the metal, so then it would only be glue holding it together, which would probably separate.
I was thinking of an Ardent 2.25, but I have a couple Ardent 2.4s, so I'll probably use what I have on hand.
My next one may be a butt joint with a "patch" of casing tying the ends together from the inside, that would reduce the hump and smooth out the sidewall, also stitching across the joint would be cleaner.
I have enough left over carcass from the Advantage that I might use that for the Ardent so it sews easier and weighs less. I wish I had time to build another tire this week, but I leave for Moab on Sunday
__________________
Old 2012-09-27, 01:02 PM   #54
Fatlazypig
Unicyclist
How much heavier would this type of tyre be for a 36?
I know the new light weight tyre is on the way. But if these hold together and are as light as they seem. Might be a sensible option
Foss tube and 2 racing ralphs might make for a much more nimble 36er
Has this been done already?
Fatlazypig is offline   Reply With Quote
Old 2012-09-27, 01:40 PM   #55
saskatchewanian
ERIC P
Not to distract from the 32ers but yup, it's been done.
http://www.unicyclist.com/forums/showthread.php?t=89630
__________________
Old 2012-09-27, 02:16 PM   #56
Nurse Ben
XC Muni
Nurse Ben's Avatar
Yeah, Eric has been there already.
But personally, being as I have ridden an RR 2.4 29er and I am riding a comparable Maxxis tire, I don't believe a lightweight tire is a good choice because the sidewall is just not sufficient to support our weight.
The prototype 36er tire I'm riding now is ~1500gm, 300-400gm lighter than a Nightrider. I think this tire has a good balance of weight, durability, and flexibility. I would not like this tire as much if it were lighter as it would probably be insufficient for off road use. For on road high pressure use, a 1000gm skinny tire is probably doable, but once you add knobbies, abrasion resistance, etc...you have a heavier tire, which is what accounts for the 1500gm off road tire.
So yeah, there is such a thing as having a tire that is too lightweight.
Also, these Frankentires, they are not as durable as a ready built tire, so there is a greater liklihood that they will fail dramatically; ie split apart and jam in the frame, so riding one off road at low speeds is one thing, riding them on thasphalt at a high rate of speed is probably a bad idea.
I measured my prototype 36" tire this morning and it is now, with a couple months of regular use, a full 2.5" wide and 2.25" tall. It is a big tire for a 36er.
__________________
Old 2012-09-28, 12:16 AM   #57
OutdoorJunkie
Addicted to muni!
You didn't read what I wrote properly!
"Awesome! That looks great What do you think the 2.4'' wire bead model would be like as a 26'' muni tyre? I hear it is WIDE and the tread pattern looks good."
I did not mean use the tyre to make frankentyre! I was asking you what the 2.4, 26'' Advantage would be like as a muni tyre for a 26'' unicycle
Old 2012-09-28, 07:39 PM   #58
Nurse Ben
XC Muni
Nurse Ben's Avatar
Oh, you mean as a regular "buy off the wall" stock tire...well the Advantage is a nice tire, I don't know that it's any better or worse than the Ardent, Maxxis uses the same casings between tires and changes the tread pattern.
The Sillkworm sidewall is like a Racing Ralph Evo, so for racing only, not very sturdy, and prone to cutting, so I don't think it's good muni material.
The Advantage tread pattern is a little more "open" than the Ardent, so if you like that style it might suit your needs.
I compared them side by side just now and the Advantage has a solid line of outside knobbies vs the Ardent having a "in and out" pattern along the outside edge. I'd never thought about it before, but the solid edge may be what makes the Hans Dampf and Intense such nice riding tires...
Personally, I find the Ardent 2.4 to be a great tire, only surpassed by the Hans Dampf, but if you can get the heavier duty Advantage in a 2.4, you should try it.
__________________
Old 2012-11-21, 06:42 AM   #59
enaddi
"Durchgeknallte Einradbraut"
enaddi's Avatar
Send a message via ICQ to enaddi Send a message via MSN to enaddi
Thumbs up Geared one
Quote:
Originally Posted by Alan Hogan View Post
To me it felt pretty much the same as the 29, just went faster and was slightly harder on very steep hills. Next project will be to schlumpf it
I successfully "schlumpfed" it Here it is:
enaddi is offline   Reply With Quote
Old 2012-11-21, 09:57 AM   #60
vookash
vookash's Avatar
Send a message via Skype™ to vookash
Looks great. How it rides?
__________________
http://vooni.kkdt.org My unicycling adventures including RomUni ride.
vookash is offline   Reply With Quote
Reply
Tags
the missing link a 32, udc, unicycle, walmart
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
32 inch wheeled bikes at walmart Fatlazypig General Unicycling Discussions 47 2012-10-03 02:19 AM
The "eagle has landed" at UDC USA Nurse Ben General Unicycling Discussions 46 2012-04-13 08:30 PM
[For Sale: Europe] 36" UDC Unicycle (+ travel bag) Tom Atto Trading Post 1 2012-04-07 10:25 AM
To Live and Ride in LA (in the dark) DancesOnH2O General Unicycling Discussions 6 2011-10-28 06:57 PM
Is this Maxxis creepy crawler the same as the one on UDC? imm0rtal General Unicycling Discussions 15 2011-08-23 06:17 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 1.06130 seconds with 10 queries
