#1 |
newbie
Question for men
Hi everybody.
I apologize to the ladies on here but I got a question for the men. I just started learning to ride. I'm about 3 days in to it and doing well. Unfortunately learning has required frequent re-mounting and so I need help with ways to help protect the ummm...uh..."twig and berries" from getting sore. I've tried "re-positioning" every time before mounting but to no avail. Any suggestions? Last edited by Lonefrog615; 2012-08-11 at 03:12 AM. |
#2 |
where are the newcastle riders at?
depending on the type of ride i am going on i use different gear;
-for a muni ride i use downhill bike shorts with a padded pair of knicks inside -for trials i use my wonder jocks they are briefs with a pouch that lifts and pushes out your twig and berries so you dont have to adjust them at all http://www.aussiebum.com/underwear/1541/hip%20charcoal
__________________
If you can't convince them, confuse them. Of course I'm crazy, but that doesn't mean I'm wrong. |
#3 |
Registered User
Its too early. I was a victim of the "how do you get comfortable?" syndrome but it just comes with riding.
Now, after getting the correct seat height, I can move things up front and take a seat on my sit bones and all is well. You'll get there, don' worry. |
#4 | |
Semi Skilled Unicyclist
Quote:
when positioning the seat prior to mounting, place it further back than usual, then pull it forwards, in the process, shifting out of the way any bits of your anatomy that you don't want to be sitting on- then mount.
__________________
"You can't outrun Death forever. But you can make the Bastard work for it." --MAJOR KORGO KORGAR, "Last of The Lancers" AFC 32 |
#5 |
Registered User
This is how I get on my giraffe. It works pretty well and is easier than standing up to re-arrange.
__________________
- 4umfreak █ 4u2c.it █ a simple, fun and free Url shortener with publishing to Facebook and Twitter. █ Geagle Search Engine █ a unicyclist.com inspired search engine. (kh longneak vs shortbeak) |
#6 | |
Registered User
Quote:
... and of course there is still that random failed reposition as I mount which results in an awfully quick decision to get off the uni and retry. Ouch! There's nothing like sitting on your nutz. |
#7 |
Live every week like its shark week
I've never actually sat on my nuts before... honestly I've always been pretty comfortable on my unicycle, when the seat isn't so wide it rubs holes in my jeans, like on my learner.
Basically, from day one, when I mounted I would always move my pelvis forward on the seat a bit and then back, while standing up, and sitting down on the backwards movement. Everything would then be out of the way and I would be a happy unicyclist. It's hard to explain, but if you experiment with moving around on the seat to get comfortable, you'll figure it out.
__________________
Happy cows come from California. Then at one point, PETA got into the mix and claimed that California cows were not happy. Of course, being the animal experts PETA aren't, they were unable to quantify any method of detecting cow happiness. - JF |
#8 |
XC Muni
I'm considering surgery, maybe a it drastic for a new rider...so in the meantime just move them out of the way
__________________
I dream of hamsters and elderberries |
#9 |
Vandewoestijne
Just don't bother; then in the end they're so num that you wont feel any pain anymore.
#10 |
Scottie_uk
The Kris Holm Fusion Freeride and. Qu-ax air saddles, have cut outs to help protect the plums. I own one of the Kh saddles and its much better than the standard seats that come with bikes. However, by far the most comfortable seat I've sat on so far was one of the gell filled ones (a cow print one from UDC).
#11 | |
Gig 'em, Aggies!
Also, manscaping is recommended for this hobby.
__________________
My Unicycling Journal Officially ended. ![]() Quote:
#12 |
Graham
The channels cut out of saddles are to avoid pressure on the perineum, pressure which causes numbness and for men could potentially lead to erectile disfunction if ignored regularly for long periods of time. I understand that for women pressure in this area, also giving rise to numbness, can lead to loss of sensitivity and possibly an inability to orgasm. These issues have been covered in the literature regarding bicycle seats, cutout channels are widely accepted to improve or completely avoid the issue.
Sitting on your testicles is a separate issue. Blunt trauma (especially of the repetitive variety) can result in sterility, so its a good idea to figure out how to be comfortable. Reduced fertility (both probably not absolute sterility) can also result from poor thermal regulation of the testicles. I ride the KH fusion slim for commuting, often wearing jeans and jocks. I use the same technique as Milosboy to avoid sitting on my nuts. The only discomfort I suffer is some very minor chaffing from the seam of the jocks on the inside of the leg. But my commute is only 15mins, so it doesnt bother me much. For muni, I ride a KH fusion freeride and wear padded bib nix. No discomfort when riding in this configuration. If you experience numbness and/or testicular trauma, STOP RIDING. Change your setup, try a different saddle, saddle angle, height, etc. |
#13 |
XC Muni
+1 on the manscaping, just be done with it, once you go skin you'll never go back. Of course, there is the issue with explaining to the wife/girlfriend...
![]() Alos try some lycra shorts, that'll help keep things where you put them.
__________________
#14 | ||
Gig 'em, Aggies!
Quote:
![]() </importantbutofftopic>
__________________
#15 | |
Registered User
Quote:
If you having issues explaining the manscaping to your significant other... they need to be talked to...
__________________
My Youtube - http://www.youtube.com/channel/UCkbs...?feature=guide |
| Tags |
| men, question |
Similar Threads
| Question for NZ Uni Riders | Davey | Just Conversation & Introduce Yourself | 3 | 2011-12-09 10:00 AM |
| Question for teachers, parents etc. | fkb | Just Conversation & Introduce Yourself | 18 | 2011-07-08 02:27 AM |
| Question for the techies... | Sponge | General Unicycling Discussions | 7 | 2010-12-15 01:36 PM |
