#1 |
Registered User
I want a 29er Muni that FLYS!!!
Hey, I love my Nimbus 24" muni. Being able to roll over roots at a slow pace and this will my my muni of choice for technical/ turny trails.
That being said, I want a 29er now. The trails in and around Dallas are relatively flat to where REAR suspension mtn b_kes are not necessary. I would like to be able to get some distance on my muni now to build my trail legs. So here's what I want. Something durable (of course), can climb moderate hills, and can make good time. The choices are limited at this time to three. Nimbus Drak, Nimbus II and KH 29. I've read some other threads which touch on the differences but I need more of a push. I won't pay for a KH at this time. The Drak looks like it would be bulky and slow compared to the NimbusII. ie. bigger/wider/heavier rim/tire.. The frames and hubs don't appear to be much different. http://www.unicycle.com/unicycles/mo...unicycle.html/ http://www.unicycle.com/unicycles/mo...unicycle.html/ Being only a 10$ difference makes it hard to come to a decision. Am I mistakenin my assessment? I know it all boils down to personal preference but my needs are speed, distance, and climbing power. Thanks |
#2 |
Eating a sandwich
If you find a muni that flies, post video.
#3 | |
XC Muni
Quote:
You should change to a KH Freeride seat unless you like the curvature on the Nimbus seat. Long cranks are fine if you plan to do some big climbing, otherwise 125/150 moments or just 150 Ventures. You might consider a 36er, it would be a whole lot faster, that's what I ride when the trail is flat enough for beginner mtb; i.e. no suspension needed.
__________________
I dream of hamsters and elderberries |
#4 |
Eating a sandwich
None of the trails that I've seen in the Dallas area require a big beefy unicycle. The extras that the Drak offers -- 36 hole hub, magura brake mounts, and (I think) more tire clearance -- are all things you don't really need around here.
The Nimbus II should be fine. Last edited by aarons; 2012-06-26 at 06:30 PM. |
#5 | |
muni commuter
Quote:
__________________
My 29er is my little wheel. Roll it, baby! pLs forgve anu typist imak win positing forum my fone. |
#6 |
Registered User
The main two trails I'm thinking of are not 36er friendly. Theres only a few places where my 36er could be considered for off road. ie. spacious and more like roads. The trails I speak of are long but do require quick turns, small drops and very rocky ascents/descents at times. The mtn biks do need front suspension for the terrain I'm describing. Plus I would hate to free mount a 36 on the trail as often as I already have to on the street.
I have no preference about crown shape. I will probably upgrade the saddle when ordering and get dual hole cranks down the road, and tires are easily changed so I guess its all about the rim/hub Eh, decisions, decisions. I think I'm leaning toward the Nim2. It just looks a little better and has a lighter wheel (I think). |
#7 |
XC Muni
I think you're underestimating what can be done on a 36er. I ride very rough single track on my 36er, rocky, rooty, lots of abrupt changes, it is so much faster than a 29er. I only use my 29er for hard muni.
__________________
#8 |
muni commuter
If anything, a 36 is easier to ride in rocky areas than a 29, because it just rolls over a lot of the rocks that you might have to go around on a smaller wheel. With practice, I also now find the 36 to be plenty maneuverable - less than a 29 uni, but still way more precise than a bike. A 36 is certainly not limited to just fire roads, and on some single track it's actually easier than a 29 (like narrow trails with overhanging grass where you can't see holes and rocks, the 36 just plows over em with lots of stability).
I think a 36er has disadvantages vs. a 29er in just two areas: 1) Climbing, due to weight and leverage ratio. 2) Free mounting. I admit it took me over a year to get really consistent and comfortable freemounting my 36er. It is harder to freemount a 36 vs a 29, especially in difficult terrain and when tired. I suppose another disadvantage for me on the 36 is that it is too fast for comfortable riding with my son on his 24 - but that's not a problem that applies to your description. So if you're still not to the point of true comfort in mounting the 36, a 29er may be best, for now, for your riding scenario. But don't rule out using the 36 on those trails in the future! As to which 29: I'm over 200# with gear, so I would not personally go with less than 36 spokes, particularly off road. But I also don't think the Dissent would be good for trying to go fast. So I'd look at the Drak with a different tire. Also, I'd bet most of the weight difference between the two is in the Dissent tire - the Nimbus rim might be slightly heavier than the KH rim, but 4 spokes and nipples don't add much weight.
__________________
My 29er is my little wheel. Roll it, baby! pLs forgve anu typist imak win positing forum my fone. Last edited by uniShark; 2012-06-27 at 06:32 PM. |
#9 |
Muni Foot
Is another disadvantage with the 36 over the 29 that I'm imagining an actual disadvantage:
You sit higher: 1) You smack into even more "low" branches. 2) When you do have an UPD it's even that much further to the ground. |
#10 |
UnRegistered User
I have the drak and love it. You can go pretty darn fast with the dissent tire. Its also nice to have the option of brakes. they are pretty nice to have. Also the dissent is a nice big tire so you can put pretty big tires under the Drak frame. I dont know about the clearance on the N II. I'm biased but would go with the Drak.
__________________
It's called a Muni ride, not a Muni walk ... If you're not tired at the end of a MUni ride, you're doing something wrong. - Tholub - Unicycles: 19" Koxx One Black Domina II, 29" Nimbus Drak equipped with custom center-pull brake system
#11 |
XC Muni
I suppose if you're coming from a 24", the 36" could seem really big, so a 29" would be a nice in-between size; though it'll still feel slow when you hit the flats.
I'd get the Drak and ask them to swap tires for whatever Kris is specing on the 29er; they might have it in stock and make a swap for you. That round frame is really nice, it's much easier on the knees and it looks good. 32 hole rims/hubs are the mtb standard, but most unis use 36h, so I'd stick with 36h.
__________________
I dream of hamsters and elderberries Last edited by Nurse Ben; 2012-06-27 at 07:05 PM. |
#12 |
Cokering rails2trails asphalt
if you're a normal (5'11" 175) size human being, the 36" could seem really big.
#13 | |
muni commuter
Quote:
Height vs UPD - gives more hang time for a proper landing.
__________________
#14 | |
semi-skilled laborer
I just labored over this exact conundrum a few weeks ago and went for the Nimbus 2. Now that I have it I think I made the right choice - it's plenty heavy duty for what I'm doing, learning Muni. Anything more would have been overkill for my purposes - when I start getting aggressive enough to need something sturdier I'll probably buy a 26er. And - personally I much prefer the lines of the N-2 over the round crown. I got it with the 137/165 Moment cranks which fit my skill level perfectly.
My *only* regret on the N-2 purchase is that it lacks rim brake mounts. But that just means I'll have to go disc when the time comes. Sam Quote:
#15 |
Registered User
Wow, this thread just woke up during my Muni ride today!
I agree with everything that is being said which is why I'm having trouble in the decision. My 24" is SOLID. I don't have to worry about anything during a UPD, it just takes it in without complaint. I think that is really my concern as to which 29er would soak up the abuse. My Titan, however, I would not be so sure about UPD's during a Muni ride. Also, like others have touched on, when I pop off the 24, I grab it, jump on, and keep truck'n. My 36 on just flat pavement takes a few hops and when tired just gets uglier and uglier. and Yes, there are plenty of branches that pop my helmet when I'm not paying attention. ![]() Brake mounts are no big deal with the crank options now. It sounds like, being that I will go 29er and not 36, the Drak with a lighter tire would be the best choice. I like the way the Nimbus2 looks, more like my 24", but as long as its solid who cares. I wish I could pick parts to swap. Nimbus2 with Drak wheel, different tire would be ideal |
| Tags |
| 29er, flys, muni |
Similar Threads
| [2005 KH 29er] What is the max tire size that fits ? | Siddhartha Valmont | General Unicycling Discussions | 2 | 2012-08-20 06:30 PM |
| [Wanted North America] Want 26" Nimbus Muni | Ricois | Trading Post | 1 | 2011-12-24 02:18 AM |
| Muni Pedals that allow you to change foot position | bluesman | General Unicycling Discussions | 16 | 2011-12-16 03:52 PM |
| more 29er Muni | Tucson Uni | Unicycling Videos | 26 | 2010-05-18 03:24 AM |
| Ping: bugman - banana flys | DigitalDave | Just Conversation & Introduce Yourself | 4 | 2005-03-16 09:28 PM |
