#1 |
Registered User
handrail tutorial
hey
I was surprised to find that there is no hand rail tutorials. If anyone knows of a tutorial or is willing to make one it would be very useful to me! Thanks!! |
#2 |
Unicon 17
Indeed, there is currently no handrail tutorial. However, I am working on a grind tutorial (including ledges and park rails, with both front and back foot) aswell as on a handrail tutorial (only front foot unfortunatly...we would have to ask Kelly, Chris H. or Kevin M. for handrail grinds with both feet).
I expect to be done by mid-July, otherwise it would have to go after Unicon at the end of August. For now, I can still help with some tips : 1) Make sure you are really confident with ledges and park rails grinds. You should be able to hit them with some speed too. 2) You should have pretty good rolling hop skills (height and length). The difficulty of handrails shouldn't lie in getting you pedal up to the rail. 3) Find a good rail to begin with. It will depend of the set, but it should be between 3 and 6. Shorter, you'll have to hop way to high and you'll probably just kiss it. Longer, you might have a hard time staying on it all the way. Also, try to find one that is not too steep, otherwise it's quite scary. 4) Remember that it's only a grind on a rail. Personally, I used to be very impressed by handrails. I considered them to be in another league or something. They only really are grinds over stairs. For me, they were and still are about 90% a mental game. Once you mentally know you can hit it, you'll get it (or get injured trying, which is just as rewarding ! Read Jacob's post about that here : http://unicyclist.com/forums/showthr...53#post1493153) 5) And just a general advice : try to be respectful of your environment. If you can, use plastic pedals, which won't scratch too much the rail, and don't get in the way of pedestrians. That way you'll project a much better image of yourself and of unicycling, and you will be much less likely to get in trouble. Hope I could help a little ! Hugo
__________________
Kris Holm Unicycles Follow Municycle.ca's Team blog Communauté des monocyclistes à Montréal : Monotréal ! |
#3 |
Registered User
Thanks for the help Hugo!
If i only have metal pedals should i take the studs off of one side or should i leave them on. Let me know when your tutorial comes out. |
#4 |
Unicon 17
You should take the pins off of one side of your pedal. Otherwise it will grip on the rail and it will probably result in a nasty fall !
Sure I'll let you know, it's just that I am currently in a rush for the end of my semester, so I don't really have the time to edit it.
__________________
#5 |
Registered User
sweet, thanks.
I just have one more question. Is it easier to grind on your front or back pedal? |
#6 |
Unicon 17
That's a tricky question.
It's a personal preference which you notice as early as when doing crank stalls. One side feels more comfortable to stall on. It should be the same for grinds. When you are first learning, none is easier than the other. A difference starts to appear when you move to rails (especially round ones), where usually it is a bit easier for front foot riders. Then, when you want to be able to grind on the other side (usually referred to as your "blind" side), you have to re-learn everything from the beginning, since the stance is very different. But all in all, both have their pros and cons. There are some interesting discussions concerning this that were brought up in this thread, started by today's best grinder, Chris H. ( ) : http://unicyclist.com/forums/showthread.php?t=91708
__________________
Kris Holm Unicycles Follow Municycle.ca's Team blog Communauté des monocyclistes à Montréal : Monotréal ! Last edited by Hugo_Duguay; 2012-06-24 at 04:06 PM. |
#7 |
Lets Ride
I know from riding BMX that they make plastic pedal plates (they mount onto one side of pedals) that allow you to still have metal pedals and cut back on damage to the rail. just watch your footing when doing uni spins or crank flips the plates can be slippery. idk if you can find them on unicycle.com but I know you can order them on dans comp for around $10
#8 |
Registered User
If i want to hit a curved rail, is it easier to take it on the inside or the outside?
#9 |
Unicon 17
I find it way easier to grind on the inside part. It takes you along all the way, whereas when grinding on the outside part, you need to lean a lot more over the rail to make sure your pedal stays on.
Oh and I have been caught up in other things, but I am still working on that grinding tutorial, just so you know. I would like it to be done atleast by the end of this month, but it's hard to tell, I have a bunch of other stuff to worry about aswell...
__________________
#10 |
Registered User
thanks Hugo. I can't wait to see your tutorial
#11 |
Registered User
I'm slowly getting better at this so I think it's time to move on to plastic pedals. Any thoughts on the best grinding pedals would be appreciated.
Thanks
__________________
My youtube channel:CANMOREUNIPRODUCTIONS Visit municycle.ca for all your unicycle needs |
#12 |
Mike Padial
Heres a mini tutorial made by colby thomas
#13 | |
Unicon 17
Quote:
Then, I know some people use the Animal plastic pedals and some other pedals too, but I can't comment on those since I've never used them.
__________________
#14 | |
Registered User
Quote:
![]() PS any updates on the tutorial Hugo?
__________________
My youtube channel:CANMOREUNIPRODUCTIONS Visit municycle.ca for all your unicycle needs Last edited by muni123; 2012-12-24 at 08:11 AM. |
#15 |
Unicon 17
The first part of my tutorial, concerning ledge grinds, is done and should be online soon (as in the next few days). The second part, concerning handrails and commitment, will take longer now that there is snow. I prefer not to say any time in particular as I realize after re-reading this thread that I am rather good at procrastination.
Sorry about that.
__________________
| Tags |
| handrail, tutorial |
Similar Threads
| Homemade Handrail | Unisykolist | General Unicycling Discussions | 10 | 2009-05-10 09:13 AM |
| First Flatland Tutorial arrived: Seat Wrap - Detailed Tutorial ! | Unisykolist | Unicycling Articles and Tutorials | 16 | 2008-08-06 11:24 PM |
| 4 stair handrail | surfer1024 | Unicycling Videos | 14 | 2008-07-19 05:04 AM |
| Handrail... | extremtrialist | General Unicycling Discussions | 25 | 2006-08-01 09:24 PM |
| 7 stair handrail | zach_jucha | General Unicycling Discussions | 1 | 2005-03-03 03:25 PM |
