Unicyclist Community
Reply
Old 2012-05-25, 07:01 PM   #1
Panda
Not a Bear
Panda's Avatar
Bearing Question
Hey guys,
Sorry if this is really dumb, but I've broken my bearing and need to get it off. The prooooblem is that I haven't got a bearing puller. Is there a way i can take it off without one? It's ruined, btw, so I guess it doesn't matter if I break it. I just don't want to damage my hub.
-Panda
Panda is offline   Reply With Quote
Old 2012-05-25, 07:25 PM   #2
jtrops
Registered User
How is your bearing broken? if the outer race is split, and the inner race is stuck to the spindle you may be able to break it off with a cold chisel. You should be alright as long as you don't mar the spindle in the process.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2012-05-25, 07:42 PM   #3
Feisty
Registered User
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
I had a puller and couldn't shift mine
I used a 9" grinder with a thin 1mm cutting discto cut the outer race off, then I switched to a gring disk to grind a flat spot on the inner race you slowly keep going and you can see from the edge of the race how close you are to teh axle, when you get just ther the metal is so thin at that spot it gets tempered by the heat and changes colour at the thinest point, this is when you stop and prise it off with a screw driver as the metal will be chewing gum wrapper thin at that point and will brake allowing the race to come off very easily.
Go easy as you don't want to mark the axle (although a little nic won't do any harm as long as you rub any burs off)
Feisty is offline   Reply With Quote
Reply
Tags
advice, bearing, puller, question, tools
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Question since udc is down...bearing size MuniAddict General Unicycling Discussions 3 2006-10-10 12:38 AM
KH bearing question dubmuni2004 General Unicycling Discussions 2 2006-04-01 11:33 AM
Bearing Question - Need Help pdc General Unicycling Discussions 2 2005-08-02 12:23 AM
Stupid bearing question TheObieOne3226 General Unicycling Discussions 2 2005-04-13 09:30 AM
Bearing question jason General Unicycling Discussions 8 2002-08-28 08:25 PM
Copyright © 2001-2005 Gilby
Page generated in 0.08995 seconds with 10 queries
