Unicyclist Community
Reply
Old 2012-05-23, 05:38 PM   #1
Bogyo
Registered User
Question A question, help needed
Hi!
I made a unicycle about a month ago, and learned to ride it. This one isn't enough strong to perform tricks on it, so I'm making another one. I would like to make the frame for the same size like on a standart unicycle (so I will be able to put a splined hub in it later, if I need it) I didn't found it on the internet, and I don't have anybody near me, who could answer the question below, this is why I'm writing here.
So could anyone please measure the distance between the two bearings on his/her unicycle?
Thanks for your answers, it will help me a lot.
BTW sorry if this post went into the wrong part of the forum, but it seems the right place for me right now.
Bogyo is offline   Reply With Quote
Old 2012-05-23, 07:10 PM   #2
Twente Muni
Tom
Hi Bogyo,
Take a look at the unicycle stores (municycle.com), at the hubs and bearing spare parts.
The bearing spacing is 100 mm, measured from the middle to the middle of the bearing. The bearing diameter is 42 mm.
The bearing width is 12 mm
you can also google "Schlumpf hub manual", there you will find a drawing of the fork ends for the bearings.
Good luck with the built of your unicycle.
Twente Muni is offline   Reply With Quote
Old 2012-05-23, 07:47 PM   #3
Ereksonj
Registered User
Ereksonj's Avatar
Take into consideration that splined hub bearings are a different size than cotterless bearings
__________________
"Cobra on my left, leopard on my right!" -Jim Morrison
Ereksonj is offline   Reply With Quote
Reply
Tags
needed, question
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
URGENT HELP NEEDED: Unicycle repair in NYC hexacoto General Unicycling Discussions 4 2012-03-02 09:32 PM
newish rider hopping help needed greenie Unicycling Articles and Tutorials 22 2011-08-11 08:25 PM
Help Champy Unicycling Articles and Tutorials 15 2011-07-23 03:23 AM
Cranks moving on the hub! Help needed! jaco_flans General Unicycling Discussions 10 2011-03-22 02:38 PM
stripped k1 street cranks? help needed! aidanteleki General Unicycling Discussions 3 2010-12-31 12:27 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08862 seconds with 10 queries
