Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 2012-05-18, 02:00 AM   #16
Justin LE
Mad Scientist Type?
Justin LE's Avatar
1-way bearing adapter plate
The adapter starts off as a chunk of 1" aluminum plate on a rotary table in the milling machine.
Justin LE is offline   Reply With Quote
Old 2012-05-18, 02:05 AM   #17
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Then the outside surface is machined out. This will become the new right side of the Nuvinci hub, and the cavity in the middle is machined to a 72mm bores so that it can support a CSK35PP one-way bearing.
Old 2012-05-18, 02:08 AM   #18
Justin LE
Mad Scientist Type?
Justin LE's Avatar
The inside surface here should just fit over the recently machined Nuvinci hub. Parting the metal piece this way out of what started off as just a square cutoff chunk of aluminum is always a bit magical.
The holes around the adapter flange will bolt to what's left of the Nuvinci spoke flange.
Old 2012-05-18, 02:09 AM   #19
dragonzfly
Rob O'Brien, Sydney
dragonzfly's Avatar
Woah....So Awsome
I did not want that story book to end.
Please post more, its really cool.
dragonzfly is offline   Reply With Quote
Old 2012-05-18, 02:16 AM   #20
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Thru Axle Hub
For the actual wheel itself, I decided to use an off-the-shelf 20mm thru axle front bicycle hub rather than machining one from scratch.
The thru axle hub standard is 110mm wide, so it works OK with the 100mm ball bearing width of a unicycle frame, and by making a spindle that is 20mm OD then it becomes pretty straightforward to have a spindle that goes through the hub and rotates independent of the wheel.
The only minor modification I had to make to the hub was machining down the face for the disk mount so that the cog and chain which will bolt to it won't rub against the frame.
Old 2012-05-18, 02:19 AM   #21
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Spindle
The square taper spindles I found at the bike shops were all too short, so I hacked up a cartridge bottom bracket, removed the spindle, and then cut it in half.
Old 2012-05-18, 02:21 AM   #22
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Spindle (cont.)
A piece of steel tubing was then turned on a lathe to have a 20mm OD, and a bore that just fit the spindle halves pulled from the bottom bracket.
Once assembled and welded together we had a square taper spindle that fit right inside the 20mm thru axle hub and which was long enough for the cranks to be properly clear the frame.
Old 2012-05-18, 02:38 AM   #23
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Nuvinci Drive Cog
The nuvinci hub comes with a splined interface that a threaded adapter slides onto on which you then attach a screw-on freewheel. This had to be modified quite a bit to in order to fit a drive cog and the one way ball bearing. I decided to use a standard ISO 44mm disk bolt pattern, since there are fix-gear bike types who use the disk mount of a bicycle hub for a fix gear cog.
In my case, I had a set of 16, 18, and 20 tooth cogs with a disk mount bolt pattern from tomicog that I got in anticipation of this project.
So a disk was cut out of 1/4" steel plate with a hole saw, then drilled and tapped with a 44mm ISO bolt pattern, and then silver soldered to the splined freewheel thread adapter from the Nuvinci.
Old 2012-05-18, 02:40 AM   #24
Justin LE
Mad Scientist Type?
Justin LE's Avatar
Here is the set of drive chain parts lined up how they will all fit together.
Old 2012-05-18, 02:43 AM   #25
Justin LE
Mad Scientist Type?
Justin LE's Avatar
First drivechain test
And then after sandblasting and making a few shims and spacers for all the alignments to work out, we finally got to test out the entire drivechain assembly just last week!
Old 2012-05-18, 02:45 AM   #26
knoxuni
wes style!!
knoxuni's Avatar
Send a message via Skype™ to knoxuni
go JUSTIN
__________________
Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
knoxuni is offline   Reply With Quote
Old 2012-05-18, 04:02 AM   #27
OutdoorJunkie
Addicted to muni!
OutdoorJunkie's Avatar
That frame is beautiful! Brilliant work!
OutdoorJunkie is offline   Reply With Quote
Old 2012-05-18, 05:22 AM   #28
scott ttocs
Unicyclist
scott ttocs's Avatar
Beautiful work!
I did not realize you could braze stainless steel. Do you need special brazing rods?
Scott
scott ttocs is offline   Reply With Quote
Old 2012-05-18, 05:39 AM   #29
dmacuni
The other unicycling geologist.
dmacuni's Avatar
Wow!
Holy cow, what an amazing series of photos showing the evolution of an even more amazing project! Looking forward to seeing more results as you post them, keep up the brilliant work!
__________________
Ken Looi - Nostradamus of the unicycle world???
dmacuni is offline   Reply With Quote
Old 2012-05-18, 06:52 AM   #30
Dartmech
Unicyclist
Dartmech's Avatar
Over the years I've been a member of multiple car and motorcycle forums that have never had a post with such detail and commitment to the final product. Kudos my friend. Oh the world domination devices I would make with all that machinery at my finger tips...
BUT it looks like its going to be ridiculously heavy. I still wanna ride when you get done though.
Dartmech is offline   Reply With Quote
Reply
Tags
grail, holy, project
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The last WW1 combat veteran has died. At the going down of the sun... GILD Just Conversation & Introduce Yourself 4 2011-05-11 03:16 AM
Holy Grail of Suspension unicycles. HA! EUREKA! unibikeling General Unicycling Discussions 134 2008-12-05 03:49 AM
The quest for the Holy Grail nuu Test 1 2008-04-21 01:55 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 0.11232 seconds with 10 queries
