Unicyclist Community
Reply
Old 2012-04-27, 10:28 AM   #46
onewheeldave
Semi Skilled Unicyclist
onewheeldave's Avatar
Quote:
Originally Posted by Eddbmxdude View Post
Got mine built up last night
Tyre rubs on the frame because the rim is so badly buckled, it won't true enough to stop it rubbing so I'll have to get a new rim and relace the wheel.
The brake is so powerful, im going to be able to ride some stupidly steep stuff with it!
Its a monster, weighs a ton, but Im a downhill rider so it doesn't matter too much
It does look very heavy- how do you get to the top of the hills you ride down?
__________________
"You can't outrun Death forever.
But you can make the Bastard work for it."
--MAJOR KORGO KORGAR,
"Last of The Lancers"
AFC 32
onewheeldave is offline   Reply With Quote
Old 2012-04-27, 10:32 AM   #47
Eddbmxdude
THE original 12" Trials vid
Eddbmxdude's Avatar
Quote:
Ski lift or walk
__________________
www.voodoounicycles.com- The UKs only Extreme Unicycle Display Team
I guess it's just a good thing you didn't include the footage of us snorting cocaine from the thighs of prostitutes eh Edd. - Boogie
Eddbmxdude is offline   Reply With Quote
Old 2012-04-27, 10:42 AM   #48
Feisty
Registered User
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
Can I play!
KH26 Frame
KH fixed seat post
KH Freeride Seat
KH seat brake mount
single bolt seat post clamp
Qu-Ax lightweight 145mm cranks
Nukeproof Electron pedals
Dartmoore Raider rim
Nimbus Disc Hub
DT Compertion db black spokes
DT silver brass nipples
2.4 Conti RubberQueen (black chilli)
conti tube with secret sealant
D-Brake disc mount
Shimano SLX disc brake
160mm Formula disc
5.45 kg!
Feisty is offline   Reply With Quote
Old 2012-04-27, 12:25 PM   #49
mowcius
Converted Unicyclist
Location: North Yorkshire Unicycles: Koxx White Widow 32h, KH 24" Muni w/HS33, KH 29" Muni w/203mm MT2+Oracle disk hub
And I thought a 203mm on my 29er was going to look big!
Building mine up over the weekend.
Cheers dmacuni for your review - I've also got my MT2 and I'm going to head to my local engineering store tomorrow to pick up some shorter & smaller headed screws and plastic cable clips if I can't find any lying around.
__________________
I ride down mountains on this thing - Your argument is invalid.
#unicycle on irc.freenode.net
mowcius is offline   Reply With Quote
Old 2012-04-27, 12:55 PM   #50
Feisty
Registered User
Feisty's Avatar
I got my p clips (cable clips) from halfords and used some spare disc rotor screws
Old 2012-04-27, 01:13 PM   #51
Nurse Ben
XC Muni
Nurse Ben's Avatar
If the rim wasn't bent before you built the wheel, then the problem is with the build. Take it to your LBS and let them retension the wheel, the steep dishing on the Oracle hub is hard to true and keep true.
What frame is that?
__________________
I dream of hamsters and elderberries
Nurse Ben is offline   Reply With Quote
Old 2012-04-27, 01:16 PM   #52
Eddbmxdude
Eddbmxdude's Avatar
Quote:
What frame is that?
Rim was buckled before I built it up. I was hoping I'd be able to true out the buckle but its too far gone. New rim time
Its the Oracle frame
__________________
Old 2012-04-27, 01:19 PM   #53
Feisty
Registered User
Feisty's Avatar
What frame is that?
Looks like a de-stickered Nimbus Oracle with those brazed on cable bosses and curved crown.
That Gazzi looks very tight in there
Old 2012-04-27, 01:25 PM   #54
Eddbmxdude
Eddbmxdude's Avatar
Yeah its the Oracle, not sure why it came without stickers but Im glad it did. Not keen on the colour scheme of the Oracle.
Haha yeah it is tight, its actually touching in the photo because of the buckled rim
__________________
Old 2012-04-27, 01:38 PM   #55
Nurse Ben
XC Muni
Nurse Ben's Avatar
You got a frame without the parts? That's not fair! In the states we can only completes until the next shipment
So, is the frame wide enough for a Gazz 3"?
Bummer about the rim, they aren't cheap.
__________________
Old 2012-04-27, 01:42 PM   #56
Feisty
Registered User
Feisty's Avatar
The frame is only 600g odd so not very heavy, is it not cost effective to order one from the UK?
Old 2012-04-27, 01:53 PM   #57
Eddbmxdude
Eddbmxdude's Avatar
Yeah the frame will fit the Gazz easily, my rim is just very buckled!
__________________
Old 2012-04-27, 02:38 PM   #58
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Dude, don't talk bad about my Oracle's color scheme.
My Oracle is (Louisville) Cardinal red.
My KH 36er is (Kentucky) Wildcat blue.
My dual hole (165/137) KH Moment cranks are nearly as heavy (586g) as the Oracle frame! I will be getting some single hole 150mm cranks when Kris drops his new line of Moments.
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is offline   Reply With Quote
Old 2012-04-27, 03:02 PM   #59
Feisty
Registered User
Feisty's Avatar
Quote:
Which is why my new ride isn't sporting any Moments, bomb proof but I don't do anything needing that amount of strength!
I like the colour stickers just find the rim a bit in your face, Black rim with coloured nipples FTW!
Old 2012-04-27, 05:49 PM   #60
bouin-bouin
Didier
bouin-bouin's Avatar
Quote:
Originally Posted by dmacuni View Post
I'm told the d'Brake fits newer batches of Triton frames; my 29er frame is a custom one off from mid 2009, so it may be why it doesn't fit. My 36er triton frame is from a 2011 batch, I'll check compatibility next time I have the d'brake off the wheel.
Cheers, Dmac
Exactly Daniel, Dimitri modified the Triton design after my remark 2 years ago
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Reply
Tags
brake, d'brake, disc, muni, nimbus, official, oracle, thread
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
"Official" 29er Tire Reviews Thread Nurse Ben Unicycle Product Reviews 252 Today 04:39 AM
Nimbus (disc brake) Oracle MUni DavidHood Unicycle Product Reviews 67 2012-12-09 03:40 AM
The Official "What's up this weekend, brah" thread CottonAnatomy Just Conversation & Introduce Yourself 24 2009-12-21 08:36 PM
Custom 2008 Nimbus 26" Muni with Magura Brake Mounts Nurse Ben Trading Post 3 2008-10-17 05:43 PM
The official "uncover the mole" game thread habbywall Just Conversation & Introduce Yourself 55 2006-02-27 09:59 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11571 seconds with 11 queries
