Unicyclist Community
Reply
Old 2012-04-03, 03:09 AM   #61
danger_uni
Kris Holm
I'd add that it's worth not dismissing braking power. After a decade of using Magura rim brakes and a year on disk brakes I'd somewhat disagree with Ben's suggestion that HS33's have lower power, as long as they are properly set up - being rim brakes they also scale in power with wheel size. But the predictability of disk brakes is certainly nice, particularly in the big wheel sizes.
Anyway re power - I find I really pull hard on brakes hard in some situations where you have lots of grip - full power needed. Plus any extra power will reduce fatigue when dragging the brake on long descents. To avoid disk rotor vulnerability for muni, if you need more power it's probably worth moving to a stronger brake before you move to a larger rotor, as well.
Lastly on brakes - it can be the pads that lack power not the brake itself, and brake pads get stronger when they break in. Options also exist on some brake pad brands between greater performance versus greater durability.
Kris
danger_uni is offline   Reply With Quote
Old 2012-04-03, 03:35 AM   #62
danger_uni
Kris Holm
Note - my comment on braking power notwithstanding, I do agree that we don't max out braking power on unicycles compared to what's required to stop a 40 lb DH mountain bike.
Also, I don't think ultimate braking power is necessarily directly related to modulation (e.g. grabbiness)
Old 2012-04-03, 06:36 AM   #63
Smilymarco
just call me similymarco
Smilymarco's Avatar
Send a message via ICQ to Smilymarco Send a message via MSN to Smilymarco
Using a 180mm rotor works quite well for me (first MountainUni, now an internal Shimano disk). Both were used with a Shimano SLX brake.
So far i never hit the disk and the brake never disappointed me.
The only thing i noticed: the disks get really really hot sometimes! So i dont know if using a smaller disk + more braking power will be very good. I will stick with my 180mm
__________________
Riding for Triton
Sponsored by HARTKOR FAKKER
Supported by Municycle.com
Protected by Better for your body
Smilymarco is offline   Reply With Quote
Old 2012-04-03, 08:57 AM   #64
aracer
Registered User
Quote:
Originally Posted by Nurse Ben View Post
More info on disc brake standards: there are two standards, the 51mm IS and the 74mm post mount. All of the current disc brake calipers have the mounting holes spaced at 74mm, which works for direct mount to some mtb forks and frames. But, for the remainder, the calipers must be reduced to a 51mm I.S. (International Standard) us a caliper mounting adaptor.
This is something that's bugging me about the new uni disk brake adapters. Given almost all brakes now come in a post mount version why are the uni disk brake mounts all IS? Why not make a post mount version, thus getting rid of the need for adapters? ISTM there is no advantage at all to using an IS mount with an adapter - it's just added weight and complication.
aracer is online now   Reply With Quote
Old 2012-04-03, 12:10 PM   #65
Nurse Ben
XC Muni
Nurse Ben's Avatar
I rode last night in the rain, Magura rim brakes, not a whole lot of stopping power even with two fingers, hopefully this is my last week of rim brakes.
I think the amount of brake you need depends a lot on how you use your brake, I find that brakes can put me off my line, esp on tech downhills, so I glide the brake and use pedal pressure for control; last night had me thinking that longer cranks may be in order
At 200# riding the Oregon, I have never found the 160mm rotor to be underpowered, even when riding in very wet conditions; like in Oregon.
Bigger rotors and stronger calipers have one advantage in that you might be able to get away with one finger braking in certain situations where two finger braking would be required on a smaller rotor, but then that same big rotor is going to be an overkill in light braking situations.
Disc brakes are smooth and they brake when wet.
Yeah, that would have made sense, but the only reason I can think of is the ability to shim the brake in or out depending on use.
Seriously, on a uni? I can't imagine you'd get a rotor that hot, but if you are then it might be time to try a metallic pad or change to a better rotor.
Nurse Ben is offline   Reply With Quote
Old 2012-04-03, 01:16 PM   #66
davidp
Registered User
davidp's Avatar
Well, this and the ability to run a larger rotor just by switching out the adapter. I'm not sure if that would be possible if the caliper mounts were not IS. Not many will want to run a larger rotor but I could see it being useful on a 36".
davidp is offline   Reply With Quote
Old 2012-04-03, 01:53 PM   #67
danger_uni
Kris Holm
><snip>
Yes it does get really hot - same as a bike. You can hear the hiss when you touch a wet glove to it =)
But I have never even come close to hitting or touching it when riding.
Kris
Old 2012-04-03, 02:21 PM   #68
aracer
Registered User
Quote:
Given that most MTB forks are now post mount and many people use discs larger than 160mm, such adapters obviously already exist (and are still simpler than an IS to post adapter) http://www.chainreactioncycles.com/M...?ModelID=13717
Meanwhile I should have thought the majority of uni riders will be happy using a 160 disc, and will be using a standard hub hence no need to shim, and a post mount would make far more sense rather than having to add another adapter.
Old 2012-04-03, 02:26 PM   #69
aracer
Registered User
Actually that makes sense - most use of a brake on a uni is presumably dragging, which is how you really heat up your rotors - in terms of energy, braking from 30mph on a bike is only equivalent to dragging a brake down 9m of vertical.
Old 2012-04-03, 07:49 PM   #70
Smilymarco
Smilymarco's Avatar
Like Kris said
The longest ride with my new setup and without a pause was down 550 meters in attitude in around 2km. Braking all the time of course
I only touched it with my gloves on (Specialized Fortress, very nice leather/carbon gloves) and i could feel the heat through it.
Im using the Koolstop brake pads for the Shimano brakes: http://www.koolstop.com/english/disc_pads.html (the red ones, semi metal)
I also never had problems with touching the disk. I never hit it on the external setup and dont expect it to get hit on my internal now.
__________________
Riding for Triton
Old 2012-04-14, 12:25 PM   #71
jrwi
Registered Lurker
jrwi's Avatar
Sorry, I meant to post that info. So you are looking for a front brake for two reason, one is that the line is shorter so you probably won't have to cut it, two you need the front brake I.S. adaptor to fit the D'Brake from Nimbus.
@Nurse Ben
Thanks for this. I figured the front would be better for cable length, but it was the fitting information I wasn't sure about.
This info has been very useful, I'm sure I'd have ended up with the wrong bits if I hadn't had it. In the end, I've gone for the Tektro Auriga Comp you linked, plus the adapter. I see in other threads you've got yours set up now - how's it worked out? Was it straight forward to fit, and are you getting the all-round braking performance you need? (I'm a little way off having my new uni assembled.)
__________________
Twitter: @jrwi
jrwi is offline   Reply With Quote
Old 2012-04-14, 09:52 PM   #72
Nurse Ben
XC Muni
Nurse Ben's Avatar
Quote:
@Nurse Ben
I rode the new set up last night, the Aruiga is a fine brake, esp for the price, set up was easy, great power without being grabby. Mine actually came with adaptors, so maybe your brake will have one as well and you can send the extra back. I do notice a couple things, first is the disc brake set up adds about 250 gm to your uni; heavier hub, heavier brake. Personally, since I use my brake a lot, this is a good trade off. In contrast to Maguras, they need zero manitenance, I can brake with one finger vs two and my stopping power is greater, the glide is so much smoother, and they work when wet.
The wheel build is interesting, having been building symetrical muni wheels for four years, to build a "bike styled" dished wheel is wierd, esp because one side of the spokes is so much steeper and tensioned considerably higher. I do think that the dished wheel is strong enough for tpical muni/road use, but if I was doing huge drops where I could be landing sideways, I might stick with a standard "symetrical" wheel build.
The 29er built up much easier and nicer than the 26er, long spokes make for easier tensioning I suppose.
In terms of line length, a front brake line is long enough for most 24-29 muni, but if you use a long handlebar or you are riding a 36er, a rear brake with the longer line would be better.
Clearance is scary tight, 2mm between the caliper and the spokes, a bigger disc would improve clearance, but I did not have any problems so it's probably fine. It's possible that some brake might not work. The D' Brake adaptor is awesome, no mess, no fuss.
Old 2012-06-07, 12:11 AM   #73
piranhamatt
Registered User
after a while of looking around for a brake for a new Muni project, i settled with what looks like the best
i bought a Hope Tech M4 Evo, with a 203mm floating rotor, verry nice!
i wanted to fit the spooner on, so came up with this:
turns out the holes drilled into the lever for grip are the perfect size to tap a M3 thread into! it seems fairly secure, although a dedicated adapter would be much better.
about avid, i love the bleeding system they have, its incredibly precise, bike shops don't like it because it takes a while. but you can get a near perfect bleed with them, not something you can do with other brakes. I have a set of Avid Elixir CR's on my DH bike, and they work brilliantly! although i will agree with the juicy problem, i have seen how they go spongy while turned the wrong way!
piranhamatt is offline   Reply With Quote
Reply
Tags
brake, choice, disk, hub, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Nimbus Disk Brake 100mm hub uniShark General Unicycling Discussions 43 2012-03-18 08:16 PM
New Fixed-Geared Unicycle Hub! Question for the mountain bike equipment experts magnustudios General Unicycling Discussions 11 2012-02-08 12:02 AM
[For Sale: Europe] Brand new EXCEED TITANIUM ISIS HUB for sale with spokes! piotr pajda Trading Post 3 2012-01-31 12:56 PM
Nimbus Impulse 36 disk brake model onebyone General Unicycling Discussions 129 2011-12-18 07:08 PM
Qu-Ax Debut Frame on KH hub/Nimbus Hub emile General Unicycling Discussions 4 2011-05-09 11:39 PM
Copyright © 2001-2005 Gilby
Page generated in 0.18046 seconds with 11 queries
