#16 | |
ERIC P
Quote:
If the sidewalls are not flat then you may get fluctuations in brake power and weird forces on your pads if the rim is just the tinniest bit out of round. If the rim states "disk only" then chances are the sidewalls are already fairly thin and it is not advisable to use rim brakes as they will wear the sidewalls even thinner over time, eventually causing rim failure. If the rim was designed for rim brakes but just has not been machined/surfaced there is no danger, only the paint can be a detriment to proper brake function. To remove paint from the sidewall of a rim you can remove the tire, jam a sanding block between the rim and frame and spin away. That worked really well on my old airfoil rim. failing that there are all sort of disk options now
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton |
| Tags |
| brakes, important |
Similar Threads
| Trick Names and What They Are | MM38 | General Unicycling Discussions | 7 | 2011-08-08 09:09 PM |
| How many freemounts are there? Which ones are the best and the easiest to learn? | Luderart | General Unicycling Discussions | 13 | 2011-07-20 11:47 AM |
| Semcycle - Are they home? | Cudzu | Unicycle Product Reviews | 6 | 2011-03-31 09:28 PM |
| Obstacle tracks? What are they called? Where can I find them? | Dane M | General Unicycling Discussions | 15 | 2011-03-29 03:50 PM |
| They don't make uni's like they used to. | Dane M | General Unicycling Discussions | 11 | 2011-03-19 08:18 PM |
