Unicyclist Community
Reply
Old 2012-02-06, 07:53 PM   #1
Daytripper63
Robs World
Foss 36 tube question
Why cant the Foss 36 tube be used in a drilled 36 rim?
and if it is true that it can not be used can you use a 29er tube in a drilled 36 rim.
Daytripper63 is offline   Reply With Quote
Old 2012-02-07, 01:39 AM   #2
johnfoss
North Shore ridin'
johnfoss's Avatar
I have a Foss (no relation) tube in a drilled 36" rim. It's the loaner wheel Bronson gave me while I await something from Schlumpf. The stuff bulging in the holes looks like tube color, but I imagine he's got a layer of something in between. It doesn't bulge as far as the inner surface of the rim. I'd ask Bronson for details (silvacycles.com).
BTW, the combination of that tube with the drilled rim is a noticeable difference in rotating mass when riding. I'll be sorry to go back to what came with my uni.......if that ever happens.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2012-02-07, 04:09 AM   #3
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I *think* the Foss tubes have more plastic deformation than conventional tubes and may get a bit lumpy after extended use in a drilled rim with a bulging rim strip. I can't see it being an issue if you use a non-stretch rim strip (fibre tape works great)
I have one in my 36er but my rim is drilled only on the outer surface.
__________________
saskatchewanian is offline   Reply With Quote
Old 2012-02-08, 12:50 AM   #4
scotthue
10k & Marathon World Champ
scotthue's Avatar
Send a message via Skype™ to scotthue
I had a Foss tube in a drilled rim with the stock green rim tape and multiple tubes failed around there edge of a hole. I think the combination of pressure against the relatively sharp edge of the hole and the thinner tube is what produces the failure. I did use a 29er tube in the same rim, but it also failed in the same manner, however it lasted a while longer than the Foss tubes did (never more than 2 rides). I think that Eric's idea of using fibre tape could work well but could also add a bit of weight. The expensive solution is to get the Stealth2 rim because it is both stronger and lighter than the Impulse drilled rim, however it does not have the holes, so it works great with the Foss tube.
Also, unlike Bronson's wheel that John is using, the Foss tube in my rim bulged past the second wall of the rim.
scotthue is offline   Reply With Quote
Old 2012-02-08, 02:15 PM   #5
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
What do you guys mean by a 'drilled' 36" rim? Is that a Stealth rim you've custom drilled, or is there a special drilled rim I don't know about?
I have a Stealth Pro rim, but will probably upgrade to a Stealth II rim because tyres are just about impossible to remove from the original stealth rims.
GizmoDuck is offline   Reply With Quote
Old 2012-02-08, 02:39 PM   #6
scotthue
scotthue's Avatar
The nimbus impulse rim.
Old 2012-02-08, 08:08 PM   #7
bouin-bouin
Didier
bouin-bouin's Avatar
Quote:
Impulse is not a rim name but related to disc brake model, all Nimbus 36" rims are stealth
original one, named Stealth, and very difficult to remove the tyre as said by Gizmoduck, 38mm, .....
they were some Stealth rims drilled but I cannot find pictures anymore ! according to my memory they were just drilled on the outside
current rim is Stealth2, 40mm, new profile to make easier the tyre fiting
Roger may explain in details
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2012-02-08, 08:53 PM   #8
rogeratunicycledotcom
Mostly OKish Unicyclist
The only Stealth 2 rim with holes is mine. :-)
It was an experiment to see the effect of putting holes in the rim. It gave only a marginal saving in weight, weakend the rim, doubled the cost and caused more potential problems with the inner tube.
Roger
__________________
Roger Davies
Unicycle.com in the UK
The UK's Unicycle Source
www.unicycle.uk.com
rogeratunicycledotcom is online now   Reply With Quote
Old 2012-02-08, 09:05 PM   #9
davidp
Registered User
davidp's Avatar
Quote:
In the US, Unicycle.com sold the drilled rim from the Impulse unicycle separately and listed it as the Nimbus Impulse rim (though it still said Nimbus Stealth on the rim itself). This was before the Stealth2 rim was announced. I considered buying one of the Impulse rims when building up my 36" last year and I know mountainuni1 did buy one and is riding it currently.
davidp is offline   Reply With Quote
Old 2012-02-08, 09:18 PM   #10
scotthue
scotthue's Avatar
Exactly. I own all three model. Stealth, impulse (drilled stealth), and Stealth2. I am considering drilling the stealth2 (just on the inside, by expanding the spoke holes). Roger, what do you think? Would it make the rim too weak for 36er muni? (For a 60kg rider...) It's not worth the weight savings if I can't use the Foss tube in the drilled version however...
Old 2012-02-08, 09:25 PM   #11
I don't think it is worth it. The rim is amazingly strong so it can take it.
Roger
__________________
Roger Davies
www.unicycle.uk.com
Old 2012-02-09, 12:42 AM   #12
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
If drill the rim, be sure to use a full bottle of green slime to protect against flats.
corbin
(LOL>>)
__________________
http://www.corbinstreehouse.com
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2012-02-09, 04:31 AM   #13
scotthue
scotthue's Avatar
What is this mysterious green slime? And do I put it inside the tube to fill leaks, or around the drilled holes to lube them up and make them less sharp?
Old 2012-02-10, 12:54 AM   #14
uniaddict
Custom User Title
uniaddict's Avatar
I find stans tubeless sealant works better than slime; plus you need less stans, so less weight. If I have a finicky tube that gets flats often I put a few ounces of stans in and the flats stop.
uniaddict is offline   Reply With Quote
Old 2012-03-20, 10:47 PM   #15
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Before UDC added the "Not recommended for rims with cutouts/holes" note on their website, I had purchased a FOSS 36" clear tube with the intention of putting it on my first run (with the drilled Stealth1 rim) Impulse. The original "commuter" (heavy) tube was bulging out of a couple of the holes pretty bad. The tube ended up being a defect (UDC refunded in full, of course) that was fused together in spots so my LBS put the heavier tube back in and replaced the Green Rim Strip tape with duct tape. I've put over 1k miles on it since then and it seems to be holding up fine (no bulges). It does not leak air like the FOSS tube in King's Stealth2 which seems to like to revert back to 40psi whereas the heavy tube in my Impulse is holding tight at right around 60psi. I'm probably taking a hit on rotational weight (the most important kind) with the heavy tube and duct tape on the Impulse. But, if it ain't broke...
I was thinking about picking up a $6 Green Rim Strip (see picture below) on my next UDC order just to get the color theme back. I guess I will abandon the FOSS tube (based on your recommendation) for that wheel. I'm not going to build up another wheel (funny how the un-drilled Stealth2 rim is lighter than my drilled Stealth1) for my back-up/loaner to be just a "little" lighter.
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is offline   Reply With Quote
Reply
Tags
foss, question, tube
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[Wanted Australia] Triton 36 or KH 36 inch unicycle TomGozza Trading Post 4 2012-01-11 09:23 AM
how to start riding a 36" and other 36" ??? mountain shooter General Unicycling Discussions 5 2011-09-05 11:41 PM
A Tube and Tire Question mbalmer General Unicycling Discussions 10 2010-04-01 06:29 PM
Newbie Tube Question (20" Summit) Animation General Unicycling Discussions 2 2003-10-20 09:26 PM
Foss out of town some more Unicycle@aol.com General Unicycling Discussions 0 1995-09-17 10:58 AM
Copyright © 2001-2005 Gilby
Page generated in 0.25037 seconds with 10 queries
