Unicyclist Community
Reply
Old 2011-10-19, 09:47 PM   #1
Biped
Ischial Tuberitus
Biped's Avatar
24" Wheel in a 26" Frame
For those how can't decide...
I'm on the fence between a KH24" and a KH26.
Are there any pitfalls to running a 24" wheel in a 26" frame? The new KH 26" frames can handle a 3" tire.
The only downside to it, besides the need to have multiple wheels, is that the crown of the frame will be a couple of inches taller on the 26" frame.
Am I missing something here?
__________________
Kung fu/Kungfu or Gung fu/Gongfu is a Chinese term referring to any study, learning, or practice that requires patience, energy, and time to complete.
Often used in the West to refer to Chinese martial arts.
Also known as Wushu and Unicycling.
Biped is offline   Reply With Quote
Old 2011-10-19, 09:55 PM   #2
OUK
An)-On Juncher
OUK's Avatar
Shouldn't be any problem As well I know..
__________________
~An)-On
Ethjulet Cykel - UDC Denmark
Danish Trial Team
I ride one wheel cus it's way more sustainable than riding two!
OUK is offline   Reply With Quote
Old 2011-10-19, 10:01 PM   #3
munimag
Registered User
The only problem would be if you want to put rim brakes on the frame. The brake mounts would be in the wrong place for the 24 inch rim.
munimag is offline   Reply With Quote
Old 2011-10-20, 01:50 AM   #4
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Unless Kris lowered the KH24 in the last few years the crown height is actually the same, just different locations for the brake mounts.
__________________
saskatchewanian is offline   Reply With Quote
Old 2011-10-20, 02:55 AM   #5
scotthue
10k & Marathon World Champ
scotthue's Avatar
Send a message via Skype™ to scotthue
So a ~2008 model KH24 frame is the same crown height as the new KH26 frame that can accomodate the 3" tires?
scotthue is offline   Reply With Quote
Old 2011-10-20, 03:13 AM   #6
Dr D
Registered User
As bizarre as it sounds, I have a Triton frame designed for multiple wheel sizes. I'm running a 26" and will be switching to a Large Marge when the snow flies. So far no issues from muni riding and commuting other then it looks a little different. I don't see there being an issue using a KH with similiar plans involved as long as the brakes can be lined up (as discussed).
If I was big on tricks it might get a bit hard to work with.
Dr D is offline   Reply With Quote
Old 2011-10-20, 04:15 AM   #7
Ereksonj
Registered User
Ereksonj's Avatar
I thought about this once. I realized that the most expensive portion of the unicycle is the wheel/hub/wheel build/ect. I decided that it is worth the extra money to have two unicycles instead of one and a half, where I have to switch the wheels every time I wanted a different riding style.
__________________
"Cobra on my left, leopard on my right!" -Jim Morrison
Ereksonj is offline   Reply With Quote
Old 2011-10-20, 04:44 AM   #8
saskatchewanian
ERIC P
Quote:
yup, 14" from axel centre to bottom of the crown.
A Duro 26x3 fits just fine in my KH24 frame, and since I use disk breaks, no problems.
__________________
Old 2011-10-20, 01:45 PM   #9
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
That means I wouldn't have to buy a KH26 frame is I want a 26" greared wheel? (I only have a KH24). That's awesome!
Eric, how old is your KH frame though? I know that the clearance was lowered on the 20" from 2007 to 2008, I dont know about the 24".
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2011-10-20, 02:08 PM   #10
saskatchewanian
ERIC P
mmm looks like a 2007
Perhaps you could get a cheap 07 KH24 frame from Bedford?
__________________
Old 2011-10-20, 02:11 PM   #11
jaco_flans
Trials & Muni!
jaco_flans's Avatar
My friend has a 26" Nimbus, I'll try this and I'll post here with the results later
Darren probably has some awesome deals on KH 07 frames!
__________________
Jakob F.
Old 2011-10-20, 02:24 PM   #12
Nurse Ben
XC Muni
Nurse Ben's Avatar
Ummm, isn't that the design that tends to break at the weld between the seat post tube and crown?
If money is the issue, I'd get a steel Nimbus frame then add extra magura mounts on the other side to have 24/26 brake mounts or get a disc brake set up.
I have not broken a frame, but considering how much torque I put on my seat/handle, the seat post and seat post tube are really getting worked, be a shame to buy a frame and have it break.
FYI, there are some new frames and hubs on the horizon, so it might be worth saving those pennies
Nurse Ben is offline   Reply With Quote
Old 2011-10-20, 02:45 PM   #13
scotthue
scotthue's Avatar
It tends to break there if you're doing street on it. I've had a KH24 2007 since then and I bet it up pretty well. I'm a light rider but it does get beat up. I've also used a handlebar with it, which adds some extra torque to the frame.
Old 2011-10-20, 03:00 PM   #14
jaco_flans
Trials & Muni!
jaco_flans's Avatar
The Nimbus wouldn't work because the 26" would be for my Guni projects
I used to have a Nimbus 24" frame on my Muni and I traded it for a 2008 KH. Much lighter, my Muni lost 1lb by changing the frame!
__________________
Jakob F.
Old 2011-10-20, 03:44 PM   #15
Alan Hogan
The Highland unicyclist
Alan Hogan's Avatar
20-24
Its no problem..... I have a 20" in my 24" KH frame ....... looks a bit of a mongrel though
__________________
Unicycling in the Scottish Highlands
http://www.facebook.com/?ref=home#!/Highland.Unicyclist
Alan Hogan is offline   Reply With Quote
Reply
Tags
24 wheel in a 26, frame
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[Wanted North America] 24" or 26" MUnicycle gingercycle Trading Post 1 2011-07-21 01:44 PM
24" vs. 26" for Muni? rpt50 General Unicycling Discussions 1 2011-04-02 07:14 PM
[For Sale: North America] Black 26" Bedford frame W/ 24" brake mounts. KcTheAcy Trading Post 0 2011-03-27 01:24 AM
[For Sale: UK] FS. Surly connundrum 24"unicycle frame in the UK jimsmith Trading Post 1 2011-02-22 10:02 AM
Anybody use a 26" tube on a 29" wheel? Carey General Unicycling Discussions 20 2010-12-16 01:16 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08852 seconds with 10 queries
