Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
Need help with a Pashley unicycle model unknown.
Hello,
I have an old Pashley unicycle which has not been used for a long time and I am trying to remove the wheel so I can change the tyre and inner tube, but I am struggling to work out how to remove the wheel. I can remove the cranks using a crank removal tool, but I cannot work out how to remove the bottom bracket/axle as it is not similar to that of my road or mountain bike and a bottom bracket removal tool does not appear to fit it. Is this the correct way to try and remove the wheel, or should I be trying to remove the Pashley Bearing Housings from the frame? Any help or suggestions would be great. Thanks |
#2 |
Mainly XC Muni
Those Pashley bearing holders are a "lollipop" design, so the only way to get the wheel off the frame is to undo the bolt(s) holding the lollipops to the frame legs. You can't remove the axle - it's part of the hub.
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) |
#3 |
Registered User
Thanks Rob, I will give that a go.
| Tags |
| model, pashley, removal, unicycle, unknown, wheel |
Similar Threads
| Need Help with my first Uni | markonewheel | General Unicycling Discussions | 37 | 2012-06-21 09:06 AM |
| Need help with KH36 (short rider) | LoneReaction | General Unicycling Discussions | 30 | 2011-10-27 05:27 PM |
| Need help with buying 24" tire | LoneReaction | General Unicycling Discussions | 13 | 2011-10-21 05:50 PM |
| Need help with assembling a QU-AX QX | Kal | General Unicycling Discussions | 6 | 2011-10-08 06:15 PM |
| I need help with 90-90 unispins. | turbo5speedgl | Unicycling Articles and Tutorials | 5 | 2011-05-07 05:13 PM |
