Unicyclist Community
Reply
Old 2011-08-11, 02:59 PM   #46
Jan Hulshagen
Unicyclist
190cm
73kg
24x3
140mm
Jan Hulshagen is offline   Reply With Quote
Old 2011-08-11, 04:18 PM   #47
drQuirky
on a wheel, gonna spin it
168cm
50kg
24" X 2.35 tire
125mm cranks
no idea of psi. i pump it up so its not flat and not anywhere near about to burst
drQuirky is offline   Reply With Quote
Old 2011-08-11, 05:27 PM   #48
MuniOrBust
show me the muni!
MuniOrBust's Avatar
5'7"
145 lbs
24x3
150mm
MuniOrBust is offline   Reply With Quote
Old 2011-08-11, 07:22 PM   #49
edg
Unicyclist
75kg (165lbs)
73 cm (5'8")
26 x 3"/ 170mm cranks
edg is offline   Reply With Quote
Old 2011-08-11, 07:54 PM   #50
OutdoorJunkie
Addicted to muni!
OutdoorJunkie's Avatar
6', 26'' muni with 2.7 tyre 150mm cranks, 65kgs.
OutdoorJunkie is offline   Reply With Quote
Old 2011-08-12, 06:58 AM   #51
vookash
vookash's Avatar
Send a message via Skype™ to vookash
Looking at the graphs it seems that 29er is a bit different category, but comparison of 24vs26vs height makes sense.
vookash is offline   Reply With Quote
Old 2011-08-12, 06:52 PM   #52
MP Uni
UnRegistered User
MP Uni's Avatar
5'3" 95lbs 20x2.5 135mm
__________________
It's called a Muni ride, not a Muni walk ... If you're not tired at the end of a MUni ride, you're doing something wrong. - Tholub -
Unicycles: 19" Koxx One Black Domina II, 29" Nimbus Drak equipped with custom center-pull brake system
MP Uni is offline   Reply With Quote
Old 2011-08-12, 10:43 PM   #53
UNIROX
Unicyclist
UNIROX's Avatar
5"2
126lbs/58kg's
26 x 2.5
137mm
I can't believe how little some of you weigh! Gosh I'm not exactly overweight and some of the riders much taller than me weigh about 8kg's less! shocka! :0
UNIROX is offline   Reply With Quote
Old 2011-08-12, 11:05 PM   #54
Nurse Ben
XC Muni
Nurse Ben's Avatar
So you want me to pick one of my unicycles, even though I ride all of them?
Gee, which one should I pick?
The one I rode today? 26 guni 2.6
The one I rode most last month? KH 29 2.4
The one I ride most in the winter? Conundrum 26, Larry 3.8
How about the one I ride when the trails are nasty? KH 36 2.5
Then there's the recent crank reduction I've working through, went down from 170 to 165 on my 29er to improve spin, then to improve my shifting I went down from 165 to 150 on the 26 guni.
Yeah, I don't know much, but I think this sorta comparison is doomed to failure simply because there are too many variables, including experience, terrain, age, body to weight ratio, strenght vs finesse (style).
Maybe if you limited the responses to people who ride a certain style or a certain terrain, but then there is still quite q bit of variability in something as simple as "road riding".
Tell ya what, you pick one, take artistic license, it is your thread
Nurse Ben is offline   Reply With Quote
Old 2011-08-12, 11:14 PM   #55
Nurse Ben
XC Muni
Nurse Ben's Avatar
Now about that psi thing that someone mentioned, something about pound per square inch based on rider weight.
Yeah, it would probably work that way IF all tires/tubes were created equal, if the terrain were held constant, and if we all rode the same style.
However, that ain't the way it works, some folks like a hard tires, some like it soft, some ride fast, some ride slow, some hop and others roll.
My tire pressure on muni have varied from as little as 8psi on a Larry 3.8", to 14psi on a Duro 3", to 25 psi on a Racing Ralph 2.4". Then for 36er riding it's an even wider range, anywhere from 20 psi on dirt/gravel to 40psi on pavement.
At time I will also increase or decrease psi for changes in conditions or when I get tired. As well, I have found that temperature can signifciantly change the way a tire rides, cold weather requires less pressure, whereas hot weather requires more pressure.
Old 2011-08-13, 12:02 AM   #56
UNIROX
Unicyclist
UNIROX's Avatar
Nurse Ben I am sensing a lot of negativity
Perhaps we should also state the type of terrain ridden with various setups then? For example technical, semi technical, mild off road, hopping oriented or rolling oriented (not sure what terminology to use.)
I also change my crank length, tyres and pressure depending on the terrain, but mostly I ride with what I've stated...it's what feels comfortable in most circumstances.
I'm wondering saskatchewanian what you are trying to establish? Do you think there will be a direct correlation between rider weight and wheel size in that smaller riders have smaller wheels and skinnier/harder tyres? I agree with Nurse Ben that rider strength would come into play...two people can weigh the same but have very different body compositions.
I don't really know enough about statistics to comment on how accurate the results will be if multiple entries are not allowed, but couldn't you find the persons average setup? Just an idea, as stated I know nothing about stats.
Old 2011-08-13, 03:14 AM   #57
Nurse Ben
XC Muni
Nurse Ben's Avatar
Not negativity, more likely cynicism, comes with age it seems
My point is that it is challenging to quantify something with so many variables and a very small population. Many of the things that "fall out" are predicatble, such as smaller people preferring shorter cranks and smaller wheels, and possibly even skinnier tires. I think this is why a certain yet to be named persona is so against polls.
What I have found over time and with practice is that my preferences don't change as much as my ability to manage difference. For instance, where two years ago I might have struggled with riding technical muni on a 26 x 3 using 150 cranks, instead using 165's to reduce my struggle, today I rode that same muni with 150's and it's no struggle at all. Though I can manage with less, I realize what I give up when using a shorter crank as I work harder to manage a steep climb or when descending a steep and rocky downhill.
My favorite muni in terms of overall functionality and general pleasure to ride is my KH 29 x 2.4 165 Venture II. I love the lack of q factor which makes the muni ride smooth, the long cranks provde great power for climbing, and the lightweight of the uni makes it so nice to throw around. I can literally glide through a turn like a bike, all the while spinning along.
I think this is what I love most about riding muni vs riding mtb, the constant involvement between the rider and the ride, no coasting allowed, it's pedal, stop, or UPD
I still think Eric needs to allow as many options as people are willing to offer, as long as they are riding what they say they're riding. I didn't get the sense that this poll was designed to determine the forum members' favorite uni combo, I thought it was to establish a connection netween uni sizing and uni rider size.
Old 2011-08-13, 03:18 AM   #58
davidp
Unicyclist
davidp's Avatar
I thought it was pretty clear that Sask was looking to see if there were any general trends between rider height (and weight) and preferred wheel size for general muni. If you don't prefer one wheel size that's fine, but it's not what this is about. There are other threads about how many unis we have and the benefits of a certain wheel size for a given situation.
Clearly different size wheels have different strengths on different terrain but again that's not what this is about. I don't think anyone is saying this will lead to some amazing new insight. It's just a simple way to add another aspect to the height/weight discussions that keep popping up.
davidp is offline   Reply With Quote
Old 2011-08-13, 03:44 AM   #59
Nurse Ben
XC Muni
Nurse Ben's Avatar
Prefered on what day, on what trail, in what weather, yadayadayada...
You'll have better luck asking me to pick my favorite food than to ask about my favorite muni.
It's drunken noodle in case you're wondering
Old 2011-08-13, 04:10 AM   #60
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Quote:
Basically if you could only use one of your Munis w/ one setup and had to get rid of the rest which would you keep.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Reply
Tags
height or weight, muni, riders, size, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Height, wheel size and used unicycles for sale David F Dodge General Unicycling Discussions 10 2011-10-04 07:17 PM
proper seat height ...big wheel vs small... ?? extremeacres General Unicycling Discussions 6 2011-02-28 01:31 AM
Crank Length VS. Height and Weight or Does Size Really Matter? pdc General Unicycling Discussions 8 2008-09-15 04:17 PM
Santa Barbara Riders, what size wheel for CA Muni Weekend? JustOneWheel General Unicycling Discussions 3 2005-08-31 11:33 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.08827 seconds with 9 queries
