#61 |
Physical Therapist
Hey Guys,
I received my handle from Ben (thanks Ben). I have not had a chance to mount it yet. 2 questions: 1. Did you guys buy the adjustable bar-end that Ben mentioned, and if so do you have a link to it? 2. What angle of the bar-end do you find the most beneficial? Thanks! |
#62 |
Physical Therapist
Sorry, I see there is info on this on previous posts!
Here is the ebay link: http://www.ebay.com/itm/New-Tranz-X-...item53e8600cdd Did anyone try these? And what angle did you settle on? Thanks Last edited by UniTrac; 2012-04-14 at 11:42 PM. |
#63 |
Physical Therapist
#64 |
Registered User
After riding with Nurse Ben's handle setup for a while I began to wonder if the brake couldn't be mounted directly to the bar-end grab handle. This turns out to work well as it looks cleaner, drops the weight of the secondary stubby end (2 oz) plus extra tubing, and puts the brake lever in a better position.
While I was at it shortened the bar-end by about an inch, being sure to keep a good amount of material extending past the curve as this area is really helpful when climbing. I also swapped the grip for a slightly longer one. Before and after pics below: |
#65 |
slc uni
David - that looks pretty good. What bar end are you using now?
I need to order a different pair. I got the Performance Forte OS ones, which are too big in diameter to mount the brake lever on. |
#66 |
Registered User
Tom, these are a generic aluminum bar end that I bought used on eBay. Originally I was also leaning towards an oversize bar end to give a more comfortable grip but ended up going with whatever I could find cheap. It seems to me that pretty much any non-oversized, non-stubby, curved bar end should work.
#67 |
slc uni
ok - I bought the Bontrager bar ends. Hope they do the trick.
Nobody carries a selection of bar ends any more, so I can't go to a store and take a look. A lot of the ones that are out there are oversized (Profile, Performance Forte) and many others don't list enough information in their specs to know if they are. I'd really like mine not to have any "twist" on the curved part of the bar end, so I can use it either right-handed or left-handed. I switch hands a lot. The setup you have looks the best to me. It puts the brake lever where I want it. The stubby bar end mount below the long one puts it a bit too far away and too far back. Last edited by tmoyer; 2012-05-06 at 05:27 PM. |
#68 |
Registered User
Those Bontrager bar ends look pretty similar to mine.
Before actually trying the handle my biggest concern was that the bar end angle would be comfortable for one hand but not the other. The ends I have do twist/angle at the bend, but I don't find this discourages me from using either hand. I tend to mount and hop with my left hand on the handle, climb and descend/brake with my right hand, and turn with either hand. I used the bar end that angled to the left after the curve (i.e. it would be the right hand bar end if mounted on a bike), but if had a second mount I'd probably use the other bar end instead of buying a new set; I don't think it makes much difference in practice. |
#69 | |
XC Muni
Quote:
There WAS an adjustable bar end you can get on Ebay, those can be set to straight and would be your best bet. I like mine, though I broke one of the adjustment bolts off in one of the handles, so only one is functional. If you can find a set, I'd suggest changing the adjustment bolt to something hardened, otherwise they are a pretty nice set up. Funny thing, those bar ends were all over Ebay just a few months ago, now I can't find a single set, hmmmm. I'm in the process of buying a welder so I can make my own
__________________
I dream of hamsters and elderberries |
#70 |
slc uni
I'm more afraid of the adjustable bar end breaking than I am of the curve. I plan on doing a lot of drops with this thing.
Any mechanism in there just makes it weaker than it would be otherwise. I threw on an old 22.2mm welded bar end for now and you're right, the curve isn't that big a deal. I'd still prefer one that bends straight down instead of to one side, but it's a minor issue. I'm really liking having the brake lever mounted right on the bar end. The other way made it too big a reach for my fingers. Last edited by tmoyer; 2012-05-09 at 01:08 AM. |
#71 |
Noob
Hi Nurse Ben are you planning on making another run of handles or do you have any left of your first run.
I am interested in one if you still have any left. Davey |
#72 |
XC Muni
Sorry, when I made that run of handles it cost me a lot more than expected, so I am turning it over to any interested party willing to make them.
If someone had decent aluminum welding skills and a drill press/mill, this would be a nice project, esp if you were to make your own accessory handles. I sent a sample off to UDC, not sure they'll do much with it, but the idea is out there.
__________________
#73 |
XC Muni
FYI, for those folks looking to buy bar end son the cheap, take a look at Ebay, I scored four sets of used bar ends, two mid length and two longs, all for $16 delivered
__________________
#74 |
Registered User
I really need to get my mind out of the gutter...
#75 | |
Registered User
Quote:
| Tags |
| custom, grab, handles, post |
Similar Threads
| What camera do you use? | Casper | Just Conversation & Introduce Yourself | 15 | 2012-07-09 07:09 PM |
| School Teachers... What do you teach? | 57UniRider | Just Conversation & Introduce Yourself | 76 | 2011-07-10 12:21 AM |
| what unicycles have you owned? | knoxuni | General Unicycling Discussions | 4 | 2011-04-25 09:59 PM |
| What sort of rider are you? | slackercruster | General Unicycling Discussions | 8 | 2011-04-04 12:11 PM |
| What fender are you using? | bb23 | General Unicycling Discussions | 9 | 2010-12-06 11:55 PM |
