Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2011-08-05, 03:08 PM   #1
Nurse Ben
XC Muni
Nurse Ben's Avatar
Custom Grab Handles, post what you got!
This little project was an idea I got from Josh at UDC. Using a KH Stiffener Plate, I had a shop punch a hole in the plate, centered between the four forward holes, then inserted a 2" stub cut from a MTB bar and welded from both sides of the plate. I can swap out bar ends easilly, super strong. I swapped out the grab handle for a freestle bumper to clean it up:
[IMG][/IMG]
[IMG][/IMG]
This is just a variation on the KH Touring Bar, using a cut off from the long end of the included t Bar. The full sized bar end is attached to a cut down mtb bar end stub, brake attaches behind the bar end, can swap bar ends, change attack angle, very sturdy, super powerful. Still running the stock seat grab handle, but will likely swap in the freestyle handle to save weight and clean up the appearance.
[IMG][/IMG]
[IMG][/IMG]
Nurse Ben is offline   Reply With Quote
Old 2011-08-07, 04:53 PM   #2
nordicnoel
How many wheels today?
nordicnoel's Avatar
I like that idea for mounting a bar end.
nordicnoel is offline   Reply With Quote
Old 2011-08-07, 10:47 PM   #3
Nurse Ben
XC Muni
Nurse Ben's Avatar
I have two different bar ends, one long and one short, I can swap them easilly, also have a cusom bar end on order that is adjustable along the axis, so I'll have tons of adjustability.
The plate mount is sweet, very strong, no flex at all, and so lightweight and simple. I'm gonna make another one for my 29er and sell the KH Touring bar.
Old 2011-08-16, 07:33 PM   #4
Nurse Ben
XC Muni
Nurse Ben's Avatar
Picked up a pair of these bar ends last week, notice the hole in the mount that angles into the handle, this is a bolt that allows the bar end to swivel on the mount, so I get a full range of anjustability:
I'll post a pic of the bar end mounted.
Old 2011-09-21, 11:44 AM   #5
Nurse Ben
XC Muni
Nurse Ben's Avatar
I now have two sets, one on my 26guni, the other on my 29er, more than 50 hours ride time and no problems, very strong and awesome power, far better than a nylon seat grab handle.
I have suggested to a couple forum members that they sell these, but no takers yet. Figure on the following costs for DIY:
KH Seat Stiffener: $25
Bar Ends: $15
Scrap Bar for stub: Free, just find some trashed MTB bars at LBS
Hole punch and welding: $15-20
Freestyle Freestyle Handle: $9
So ~$65-70 for a stiffer seat, built in brake mount, and super power grab hanlde, that's $20 less than a KH T Bar, plus it's stronger, lighter, and more appropriate to muni.
I think you could also adapt this mount for touring by having either a telescoping or fixed length T bar made with a mount to match the diameter of the bar end stub or use those adjustable bar ends and have a custom bar made
Spam, spam, please go away, don't come back any day.
Old 2011-09-21, 12:35 PM   #6
munimag
Registered User
Who makes these adjustable bar ends? Where did you get them? Thanks
munimag is offline   Reply With Quote
Old 2011-09-21, 04:48 PM   #7
Nurse Ben
XC Muni
Nurse Ben's Avatar
There's a ton of them on Ebay, seems to be a non name brand out of Taiwan, cost is ~$15 a set. So far they seem to be lasting okay, though I overcranked on bolt and it broke off in the handle, but it was really my fault
They make a short and long, short being a cut off version of the long, so you might as well get the long and trim it to fit. No problems with loosening or excessive flex.
I'm thinking of getting some tubing with the same ID and making a custom bar to fit the mount
Old 2011-09-23, 06:39 PM   #8
munimag
Registered User
How did you attach the brake mount to the plate? It looks like you used the front holes on the brake mount and the back bolts on what was the plastic handle attachment points. The back holes are wider than the front ones.
Old 2011-09-24, 12:31 AM   #9
Nurse Ben
XC Muni
Nurse Ben's Avatar
Hey Munimag, that brake hanger was a temporary fix, take a look at my current set ups.
Parts List:
KH Seat Stiffener Plate = $25
Bar Ends = $15
3" aluminum tubing scrap from broken mtb bar = FREE
KF Freestyle Handle = $10
Hole punch and welding ~ $20
How well does it work you ask?
Well enough that I made a second one and have plans for a third. It is strong and light, simple to made, easy to use.
Tips:
Make your stub long enough to clear the handle and accomodate both bar end mounts plus welding into the plate, 2.5" minimum, 3" is better.
Use quality bar ends, the longest possible, and leave the cut bar end long enough so you can move the brake around.
Next step:
A T-Bar End
Old 2011-09-24, 02:52 AM   #10
munimag
Registered User
Thanks Ben. Nice job.
Old 2011-11-06, 01:06 PM   #11
Nurse Ben
XC Muni
Nurse Ben's Avatar
Bump.
Seriously, someone needs to build these things for sale, it is the bomb, couldn't live without mine
Hey Kris, if you read this, would you offer these as an option?
Old 2011-11-06, 06:36 PM   #12
UPD in Utah
Registered User
UPD in Utah's Avatar
Hint...
Ben,
It's ironic that you bumped this today. After installing one of Brycer's frankenbrakes on my 36er (Nightrider w/ T7 handle) and one of his HS33 set-ups on my 29er (KH29 w/ Shadow handle) yesterday, I started looking at my N24. I think it needs a brake too. Which got me thinking about your grab handles mounted on modified stiffener plates. So, when are YOU going into production mode with this? Any chance you could deliver a prototype on your next trip to SLC? (Hint, hint...)
BTW, we have a great Bicycle Collective here in SLC that had a whole big plastic bin filled with bar ends of different types. I picked out 4 and they charged me a buck -- I was going to give them $5. But, when I told them what I was going to use them for, they pulled out one-and-a-half sets of semi-working Magura HS22s. I asked how much for the set, and they said, make it $10 for the whole deal. Now I've got a bit of a project on my hands (which might involve Brycer's skills) getting these brakes in working order, but I'm gonna need a modified stiffener plate on which to mount them along with a grab handle! (3rd hint)
Cheers,
Bert
UPD in Utah is offline   Reply With Quote
Old 2011-11-06, 06:42 PM   #13
pitbullanduni
Registered User
If you decide to make more and possibly sell. I'll take one for my 29'er please. A man is worthy of his hire, so let me know how much. :-)
Bump.
__________________
"Punish the Deed, not the Breed"
"When the ocean dies, surfing dies"
pitbullanduni is offline   Reply With Quote
Old 2011-11-07, 02:07 PM   #14
Nurse Ben
XC Muni
Nurse Ben's Avatar
Well, since I need to make a couple more for rides, I may just make a bunch and sell them as a kit with bar ends, let me think on it.
And Bert, for you, anything
Old 2011-11-07, 04:13 PM   #15
Tirving
Portland Chiropractor & Unicyclist
Tirving's Avatar
I needed to post my handle, brycer1968 made it for me, it's a curved bar (to the right, I hold my handle with my left hand, mostly) with a delrin ball end. The handle fits into the existing KH handle mount on the seat. There are a few advantages to doing it this way as opposed to bar ends.
Much stronger, especially with torsional stability.
I can have different handles that fit into the system
The Delrin ball protects the end and also serves as a "nub" to rest my other hand on when I am on flats and cruising.
I can adjust the angle, how far out the bar extends, etc.
Tirving is offline   Reply With Quote
Reply
Tags
custom, grab, handles, post
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What camera do you use? Casper Just Conversation & Introduce Yourself 15 2012-07-09 07:09 PM
School Teachers... What do you teach? 57UniRider Just Conversation & Introduce Yourself 76 2011-07-10 12:21 AM
what unicycles have you owned? knoxuni General Unicycling Discussions 4 2011-04-25 09:59 PM
What sort of rider are you? slackercruster General Unicycling Discussions 8 2011-04-04 12:11 PM
What fender are you using? bb23 General Unicycling Discussions 9 2010-12-06 11:55 PM
Copyright © 2001-2005 Gilby
Page generated in 0.13186 seconds with 11 queries
