#1 |
show me the muni!
Lower Back Muscle Fatigue from Muni
I've been riding for two years now, and it's probably been about a year since I've been getting lower back muscle fatigue on some of my rides.
I've seen some threads about lower back fatigue from very new riders, and lower back pain from hopping, dropping, or injury. But my problem seems different. I'd like to think I've become a fairly strong muni rider and should have gotten passed the initial aches and pains long ago. And I don't do any significant hopping or dropping. At times I've thought my fatigue correlated with bumpy trails. Other times hilly trails. I do push myself pretty hard. But I can tell my lower back fatigues much earlier than other muscles. I've had some thoughts of what might be the cause. - Maybe my back was super weak before unicycling, for whatever reason, and is still playing catch-up. - Maybe I have a posture problem. - Am I somehow using the wrong muscles? - Perhaps I am involuntarily tensing my lower back. - Or maybe my seat is too low. I do notice that I'm not usually sitting perfectly straight up when I ride. But that's because I'm usually trying to move quickly and so I lean forward. When I consciously sit up straighter, it does releive some of the fatigue. I also notice when I'm on bumpy ground, going too slow, shifting into my high gear can exacerbate the fatiguing feeling. It in that wobbly correcting stage that I feel it. Maybe that's an indication that I'm using my core muscles too much to keep balanced, and I should moving my wheel more instead? I'd appreciate any suggestions, and especially anyone who has had similar issues! |
#2 |
Stupidity gets you 2 of these:
Well sit up streight and don't lean forward
![]() Or strengthen those muscles. You can do "supermans" - lay on your stomach and ceeping your limbs relativey streight raise your arms and legs. Don't lift your head, keep it inline w/ your spine to avoid stress in your neck. Or "swimming" same thing, but opposite arm, oposite leg, kind of like the freestyle stroke. Machines IMO at your local gym like one of these work a bit better. I preffer the first one, I feel it puts less stress on my back, plus you can flip over work your abs or sideways and work your obliques. If its too easy you can hold a small weight to your chest (I've done them w/ up to 25 lbs, but IMO higher reps w/ up to 15 lbs is better). ![]()
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist What's next? Learn2Ride&doTricks TrialsClasses&Building Last edited by skilewis74; 2011-07-14 at 05:47 PM. |
#3 |
Ischial Tuberitus
Focus on Core Stabilizers
The multifidus (mull-tiff-a-dus) muscle, at a minimum, is weak.
Good read on how to strengthen low back stabilizers. In general your unicycle conditioning program should focus on the entire core muscle groups, not just the area of pain. Someone that walks 10 miles a day with one shoe will eventually develop pain in the knee (or back, hip and even neck). Knee surgury will not solve any problems if he doesn't wear two like shoes.
__________________
Kung fu/Kungfu or Gung fu/Gongfu is a Chinese term referring to any study, learning, or practice that requires patience, energy, and time to complete. Often used in the West to refer to Chinese martial arts. Also known as Wushu and Unicycling. |
#4 |
is what it is
There are two ways you should be looking to attack this problem, IMO.
One is making sure your muscles are in balance. Having overdeveloped abdominal muscles can lead to increased risk of strain to the lower back. This isn't just a problem with the back, it can also cause problems in other joints, especially the knee! Balance your front - back core muscles and life will become much easier for your back. I am no sports trainer or physical therapist (but I play one on TV!) so I won't give you advice here... I suggest you talk with a trainer to see what is appropriate. The other thing to correct is your riding posture. If you're hunched over while riding, of course your back is going to take a pounding! Fix that posture now, even if it forces you to learn new riding techniques...
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell |
#5 |
...feeding the machine...
Buzz -
Roland and I both experience tired/sore lower backs when we do hard muni, or climbing major hills on the road, for that matter. Having ridden with you, I think your riding position is fine. It's simply that pedaling a hard down-stroke, like up a steep hill, or slow, twisty pedaling over roots and obstacles, uses the lower back muscles intensively. Those muscles are pretty closely connected to that hamstring that's pushing/pulling your leg from bent to straight down. I do front planks and side planks EVERY morning, along with occasional other core exercises and stretches, especially a good psoas stretch (here's the one I usually do). Just 5 minutes of these daily gets from stiff and sore to a state of creamy goodness.
__________________
steveyo ...like having your own personal rollercoaster... - a few uni race write-ups - muni and kokopelli uni t-shirts, mugs and stickers Last edited by steveyo; 2011-07-15 at 12:50 AM. |
#6 |
Flex Your Head
Happens to me if I am tense. I usually get the back pain on descents when I am holding onto the handle and tensed up. I think the backpack also amplifies the soreness when tense.
__________________
-James |
#7 |
Portland Chiropractor & Unicyclist
Ok, I deal with weak low backs every day. Please don't do the back extension exercises..... They put a huge shear stress on the discs and really only strengthen the extrinsic back muscles. For exercises, look up "McGill's big 3" and do those daily.
What we really need to know is: Do you have a handle? if not, getting one may help Watch your riding posture, are you bent over? If so, you need to figure out a way to straighten yourself up. For dynamic exercises, kettlebell swings and snatches help to strengthen your entire body, especially your core muscles. Ideally, your glutes should be keeping you upright and your low back muscles should be spared for everything except the fine adjustments that you need as you're riding. For mobility, search for MobilityWOD, Dr. Starett does a kick ass job of showing you daily mobilizations to keep your joints and soft tissue mobile so the right muscles can fire at the right time.
__________________
Unicycling Chiropractor Portland, Oregon |
#8 | |
Quote:
Buzz's riding posture seems fine to me, as I mentioned. And I don't think a sore lower back indicates a weak lower back. I think most of us have relatively strong cores, just that hard muni places a high demand on these areas. Working and strengthening muscles naturally leaves them feeling somewhat sore, just as doing sprint intervals or hill repeats leaves the thighs sore as they get stronger.
__________________
steveyo ...like having your own personal rollercoaster... - a few uni race write-ups - muni and kokopelli uni t-shirts, mugs and stickers Last edited by steveyo; 2011-07-15 at 11:50 AM. |
#9 |
NAUCC 2013 Course Architect
I'm with Steve- I do planks too- typically 5x a week. Before I was uni riding, I was riding around on singlespeeds and fixed gear bikes on and off road.
Now, mixing it up with the uni and bike seems to keep things a bit more balanced muscularly. Even though they're both pedaling, they still seem to work different muscles. I'm not doctor, so this is by no means an expert opinion.
__________________
dave krack 2013 North American Unicycling Convention and Championships http://www.surlyspeedgoat.wordpress.com http://www.butlerwobble.com |
#10 | |
Quote:
![]() Your exercises are good, the plank is one of the Big 3. A sore back occasionally is OK, if it happens the majority of the time after muni, it suggests a weak core, not necessarily a weak back. The back muscles shouldn't be primary movers, they should support an upright posture, the primary movers involved should be the glutes, adductors and abs. The small micro-adjustments should be performed by the intrinsic back muscles with the extrinsic back muscles being saved until this system fails. A sore low back indicates that the endurance of this system is in question. The interesting thing is it hasn't always been like this. This fact led me to ask about posture while riding because it seems some stress has accumulated over time to break down the system.
__________________
Unicycling Chiropractor Portland, Oregon Last edited by Tirving; 2011-07-15 at 04:05 PM. |
#11 | |||||||
show me the muni!
Quote:
Quote:
I've been thinking about this. Aside from being frugal and a major DIY'er, I can't get past my belief that 5 trainers would give me 5 different diagnoses and suggestions. But I'll be keeping that advice in my back pocket. Quote:
The backpack comment is interesting. I hadn't thought of that. I wear my CamelBak with probably 3 lbs of water/gear. Perhaps that's part of the equation. Quote:
Quote:
Quote:
Quote:
In the past month I've raced muni in 5 mountain bike races (another one tomorrow and Tuesday), and rode 6 good muni rides. I've also been pushing myself on those rides, seeking out steeper hills to climb and more technical trails. Perhaps I'm pushing too hard too soon. But old man winter is never too far away... and I need to get my fill before it's too late! ![]() Thanks for all the suggestions! I know it's hard to diagnose and treat these things over the internet. |
#12 |
Registered User
My lower back also often feels fatigued after riding (especially when riding multiple days in a row). I found 2 things that helped me most:
- handles. I often found that I was riding with my upper body slightly twisted towards one side or the other. Putting my hands on the handles helped me keep my back aligned better. - stretching, in particular the it band muscles. I don't know if it's because it pulls on the lower back, or what, but that seems to be the stretch that does the most good to relieve my back. |
#13 |
Sore during or after..... Basically the same advise; there might be slightly different thongs going on, but I'd treat them the same. Try doing the McGill exercises daily and check into MobilityWOD for some daily mobilizations and stretching. You should be able to adapt to the added intensity over time.
__________________
#14 | |
show me the muni!
Quote:
Is there any reason I shouldn't do exercises/stretches at the end of the day? My morning schedule is tight, but I could probably do them in the evenings in front of the TV. |
#15 | |
Quote:
![]() Do them whenever you can, it doesn't make much of a difference.
__________________
| Tags |
| back, fatigue, lower, muni, muscle |
Similar Threads
| major back muscle imbalance | manon1wheel | General Unicycling Discussions | 11 | 2009-12-02 03:14 AM |
| Lower back pain - is it just me? | patmoore | General Unicycling Discussions | 21 | 2006-08-06 04:46 PM |
| Lower Back Protector Pad | teachndad | General Unicycling Discussions | 2 | 2004-07-13 09:40 PM |
| lower abdominal muscle damage | onewheeldave | General Unicycling Discussions | 3 | 2003-07-22 12:48 AM |
| ouch, my lower back | teachndad | Unicycle Product Reviews | 2 | 2002-12-30 03:28 PM |
