Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
crank question . not 180 degrees a part ...
i got to ask . just got a cheap uncycle a month ago and have been riding it . did not think i would pick it up as fast as i did . thats why i got a cheap one . i just looked at the cranks and they are not a 180 degree apart is this a unicycle thing or is it just cheap . maybe i just bent them i don't know . thanks !! jw
#2 |
I'd rather be unicycling.
Congratulations on the quick progress! It is likely that you have bent the hub axle or cranks. This is common with cheaper unicycles.
__________________
My Website: www.Unitips.ca for trick tips and gear advice! Visit Municycle.ca Canada's online unicycle source! Check out the Municycle.ca Blog for news, tutorials and more! Last edited by unihopper; 2011-06-13 at 01:48 AM. |
#3 |
North Shore ridin'
If it's a cottered axle, the cotter pins might just be in wrong. If they both face the same way (both heads up at the same time), that'll do it. If you can't find cotter pins in your cranks, that's not the issue. Then go to the bent (twisted) axle theory. If the cranks are noticeably out of alignment with each other, your axle may be fatigued and ready to break at any time. Be nice to it. Then again, it might not be cracked/fatigued, in which case you can keep riding it for a long time.
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#4 |
Registered User
they are bent . thanks for the help . its all good though because now i can get me something better .
#5 |
Registered User
#6 |
Thanks, I'm glad you like it!
__________________
My Website: www.Unitips.ca for trick tips and gear advice! Visit Municycle.ca Canada's online unicycle source! Check out the Municycle.ca Blog for news, tutorials and more! |
#7 |
ɹǝsn pǝɹǝʇsıƃǝᴚ
This happened with my first unicycle. The hub twisted. If you start hopping off of stuff this is probably in your future.
| Tags |
| 180, crank, degrees, part, question |
Similar Threads
| 180 Unispin....Finally!...Wheel Walk too | Shug | Unicycling Videos | 30 | 2011-05-06 03:16 PM |
| Part Question | e39m5 | General Unicycling Discussions | 11 | 2005-05-10 08:18 PM |
