Unicyclist Community
Reply
Old 2011-03-19, 02:33 AM   #1
BoffyTheUnicyclist
Unicyclist Chris .
BoffyTheUnicyclist's Avatar
Location: On my laptop doing something unicycle related.
Drilling KH Moment Cranks?
Hiya all!
Found this vid with awesome looking drilled moments.
You can see them at 1:50
Im looking at drilling my old Moments to save tome weight.
How do you do it? what machinery is required and is there a special method?
__________________
-Clean Swabs
"The only way to becoming a great unicyclist is to get back up and do it again" - B.S.
BoffyTheUnicyclist is offline   Reply With Quote
Old 2011-03-19, 02:45 AM   #2
JacobSpera
Street
JacobSpera's Avatar
i havent done it myself but i have seen some that just have holes drilled in them. I would say that a drill press would be a tool that would help out tons and help keep the holes nice and straight.
__________________
Team MAD4ONE
JacobSpera is offline   Reply With Quote
Old 2011-03-19, 03:06 AM   #3
gohabsgo333
max
gohabsgo333's Avatar
Send a message via MSN to gohabsgo333
I got drilled cranks from Will Riley on my flatland uni now, it doesn't feel like the strength has been weakened at all..
__________________
max
gohabsgo333 is offline   Reply With Quote
Old 2011-03-19, 03:47 AM   #4
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
I drilled my moment (150's), with five 5/8" holes in each crank. I used a drill press a clamped the crank down. I had a little trouble with the bits moving so the holes aren't perfectly centered, but they're certainly close enough.
Max_Dingemans is offline   Reply With Quote
Old 2011-03-19, 04:56 AM   #5
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I drilled a set for a second pedal hole and found that if you drill from the back the drill does not wander as much. I drilled in 4 steps to get to 1/2" but feel I could have easily done it in 3.
__________________
saskatchewanian is offline   Reply With Quote
Old 2011-03-20, 12:38 AM   #6
kb1jki
Unicycles on my mind...
kb1jki's Avatar
I was thinking of getting 150s and drilling 130 & 110 triple holes.
Would that be good for a 36er in most circumstances?
__________________
Retrofit Disc Brakes to your existing unicycle today!
kb1jki is offline   Reply With Quote
Old 2011-03-20, 04:01 AM   #7
Dane M
Muni Crash Test Dummy
Dane M's Avatar
For those of you drilling for pedal positions: Do you guys change pedal positions during rides? Or just before a ride? Seems like it would be annoying to switch pedals around very much during a ride.
__________________
It's not as steep as it looks, just go!
www.DaneMehlPhotography.com
www.YouTube.com/DaneUni
Dane M is offline   Reply With Quote
Old 2011-03-20, 04:41 AM   #8
Tirving
Portland Chiropractor & Unicyclist
Tirving's Avatar
Quote:
I've switched mine in a ride before. This has been great on my 36-er when riding on road and coming to an off-road xc section. I have done it once or twice on my Muni but now I just stick to one length.
Tirving is offline   Reply With Quote
Old 2011-03-20, 06:05 AM   #9
kb1jki
kb1jki's Avatar
just got these... I cut the cage on the inside toward the cranks so it would pass the second "chuck" and when I get my 36er back from where it is, I'll give it a try.
__________________
Old 2011-03-21, 07:23 PM   #10
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
Quote:
Originally Posted by BoffyTheUnicyclist View Post
Hiya all!
YouTube - Elias Pöham - September 2009 - Unicycle
Here's how:
http://www.corbinstreehouse.com/blog...moment-cranks/
Tools required: milling machine, end mill, vise.
Also:
http://www.corbinstreehouse.com/blog...chined-cranks/
-corbin
__________________
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2011-03-21, 11:28 PM   #11
agentQ
Sam Haber
agentQ's Avatar
Send a message via AIM to agentQ Send a message via MSN to agentQ
A Milling machine is hands down the way to go.
The idea is to Mill out a channel rather than just drill holes.
Or in my case both:
I lost somewhere between 35-40% of the weight. Ive been riding nothing but these cranks for over two years now and they haven't bent, cracked or failed in any way, yet.
__________________
Uneed Films
Whats up with Street and Flat?
the Unicycle Lab
agentQ is offline   Reply With Quote
Old 2011-03-22, 02:52 AM   #12
BoffyTheUnicyclist
Unicyclist Chris .
Cheers Corbin! Yeah Sam I love yours! what length are your cranks and what diametre holes?
A Drill Press will do the trick right? just take them to metal work...
__________________
-Clean Swabs
Old 2011-03-22, 08:25 AM   #13
jogi
vegetarian rider
jogi's Avatar
be careful to keep the right angle and best you use a center punch,
the koxx are also mine
http://www.unicyclist.com/forums/sho...1&postcount=18
__________________
bei tierquälern hört die toleranz auf.
wer elfenbein konsumiert tötet elefanten,
wer fleisch ißt quält und tötet
www.ridetriton.com
jogi is offline   Reply With Quote
Old 2011-03-24, 08:42 AM   #14
KcTheAcy
Ohh Baby
KcTheAcy's Avatar
Saves some weight in an important place. Just did it on the 29er, 19 and 14 are still undrilled...
KcTheAcy is offline   Reply With Quote
Old 2011-03-24, 10:38 AM   #15
redwelly
Sam Wakeling
redwelly's Avatar
Quote:
You went all the way through (I think? Pic isn't too clear) - haven't seen that before! How much do they weigh now?
Sam
__________________
Unicycle.com
redwelly is offline   Reply With Quote
Reply
Tags
cranks, drilling, moment
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[For Sale: USA] KH Moment Cranks: 150 | $55 shipped (US) Tirving Trading Post 3 2011-03-21 02:37 PM
[For Sale: USA] KH Moment Cranks: 125/150mm dual hole | $60 shipped (US) Tirving Trading Post 5 2011-03-20 04:04 AM
[For Sale: USA] KH Moment Cranks: 125mm | $55 shipped (US) Tirving Trading Post 2 2011-03-19 07:50 PM
[For Sale: Australia] KH Moment Cranks 137mm NEW lunicycle Trading Post 1 2011-02-23 10:45 PM
Drilling cranks for Dual holes jtrops General Unicycling Discussions 22 2010-11-28 08:48 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11053 seconds with 12 queries
