Unicyclist Community
Reply
Old 2011-07-14, 05:07 PM   #76
Julia B
Flatland!
Julia B's Avatar
I tried it today and the first time I got into the stall but when I went to get back up I felt like my frame might snap... Also the frame got all scratched where I did it, I don't think I'll be trying that anymore.
Quote:
Originally Posted by Dane M View Post
Perfect!! No need to change it at all. What are you going to call it? I think you should call it a Tubular Grind
It isn't a grind yet. Like I said, the stall doesn't seem very difficult at all, but if anyone can manage a decently sized grind like that I'll give them huge props. Also, a trick in or out of the stall/grind, stall/grind on a higher rail, or if you can make the stall look good, I'll be impressed.
__________________
Women's Flatland World Champion
Team Mad4One
Team Unicycle.tv
Team Elevated Clothing Co.
Truth
Monarch
Julia B is offline   Reply With Quote
Old 2011-07-16, 06:35 AM   #77
johnfoss
North Shore ridin'
johnfoss's Avatar
I'd call that a seat post balance, or seat post see-saw. Like Julia said, that wasn't a grind. But it's easy enough to see how that could lead to one.
And of course it will tear up the unicycle. But the people who pioneer these tricks are not likely to be engineers. They will learn by doing, and also figure out what's needed to make the unicycle last longer for their version of the trick. The "problem," if any, will be self-correcting.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-07-16, 06:44 AM   #78
Dane M
Muni Crash Test Dummy
Dane M's Avatar
well if you could fix a sort of flat plate that snaps on and distributes the weight of the grind more evenly through the frame.... the flat plate will assist in grinding, and you'd be less likely to break your uni.
__________________
It's not as steep as it looks, just go!
www.DaneMehlPhotography.com
www.YouTube.com/DaneUni
Dane M is offline   Reply With Quote
Old 2011-07-16, 08:44 AM   #79
cyco
let the good times roll
cyco's Avatar
GOT IT!!
Call it a Fracture because everybody seems to be worried about breaking their unis while trying this trick!
well if you could fix a sort of flat plate that snaps on and distributes the weight of the grind more evenly through the frame.... the flat plate will assist in grinding...
That sounds like cheating to me.
__________________
"Two hundred years of American technology have unwittingly created a massive cement playground of unlimited potential. But it was the minds of eleven-year-olds that could see that potential"
-Craig Stecyk
cyco is offline   Reply With Quote
Old 2011-07-16, 04:15 PM   #80
Dane M
Dane M's Avatar
Quote:
Sounds like innovation and progression in the sport to me.
__________________
Old 2011-07-16, 04:29 PM   #81
deadbeatpope
Some call me Kevin
deadbeatpope's Avatar
I'd like to see someone idling on top of a trotting camels hump.
__________________
Art is a misspelled rat.
"The unicyclist is the purest form of rebel"
deadbeatpope is offline   Reply With Quote
Old 2011-07-18, 09:50 AM   #82
stingingkneeben
Ben Glynn
stingingkneeben's Avatar
+1
__________________
when life gives you lemons say " hey thanks free lemons "
stingingkneeben is offline   Reply With Quote
Old 2011-07-18, 02:51 PM   #83
Unigrant96
Registered User
Quote:
Originally Posted by riverman View Post
5. not sure if this has been done, if it is a simple crappy trick or what not, but transition the uni to its side, one foot on the seat, the other on a pedal, and balance on the pedal that is touching the ground, maybe doing some cool spins or something. sounds kinda lame, but kinda fun.
You Mean something like this at 1:03?
Unigrant96 is offline   Reply With Quote
Old 2012-08-16, 08:45 PM   #84
cwipnip
Registered User
3. in another similar vein, a small hop up to a tall rail, catching the top of the seat on the rail while the uni hangs below, sit on the seat like a champion, ride it down, and maybe pull a sweet unispin on the way down. this sounds like a bit of a party trick, but it also sounds fun.
has anyone seen this done/ heard it being done before
cwipnip is offline   Reply With Quote
Old 2012-08-16, 08:54 PM   #85
wrapmaster
J
wrapmaster's Avatar
I saw a video of someone on youtube who was stalling that way but I don't know aboput grinding
wrapmaster is offline   Reply With Quote
Old 2012-08-17, 01:21 AM   #86
knoxuni
wes style!!
knoxuni's Avatar
Send a message via Skype™ to knoxuni
I wana see a maxwhip on a 24+
__________________
Be a dumbass
experience dumbass consequences
its full circle of dumbass
And then, do it again. That makes it an infinite loop!
knoxuni is offline   Reply With Quote
Reply
Tags
things, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Returning back to riding my unicycle ....question on crank length ? Tim Coin General Unicycling Discussions 11 2012-12-25 02:56 PM
Do you need Brakes on your 36er? POLL bluesman General Unicycling Discussions 33 2011-01-05 02:44 PM
how do you bend nightrider frame to fit coker wheel? delta 224 General Unicycling Discussions 1 2010-12-09 02:32 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08468 seconds with 11 queries
