Unicyclist Community
Reply
Old 2011-01-23, 07:06 PM   #1
Vee
The Unsung Uni-Hero
Vee's Avatar
Installing Disc Brakes
So I was thinking of buying a disc brake for a 24" Uni, but was wondering what all was involved with the installation. Would I need a different hub or frame? Before I buy a disc brake (I was thinking of the one from UDC called 43" Bengal Helix 1.1 Disc Brake White for $160.00) I want to know what I am getting involved in price and work-wise.
Thank you in advanced for helping.
Vee is offline   Reply With Quote
Old 2011-01-23, 08:27 PM   #2
kb1jki
Unicycles on my mind...
kb1jki's Avatar
a retrofit kit with mount is in the works...
http://www.unicyclist.com/forums/showthread.php?t=83260
__________________
Retrofit Disc Brakes to your existing unicycle today!
kb1jki is offline   Reply With Quote
Old 2011-01-24, 04:05 PM   #3
Nurse Ben
XC Muni
Nurse Ben's Avatar
There is only one disc compatible uni hub being made and it is for touring unis only. It has an aluminum alloy spindle which would not hold up under anything but road riding.
UDC is supposed to release a steel spindled disc compatible hub in the next six months, not sure about adapting a frame for disc brakes, but it's certainly possible. Probably be cheaper and easier to buy a new frame since these will liekly be available when the hubs are released.
There is also a crank mounted disc brake system, do a search for more details.
Nurse Ben is offline   Reply With Quote
Reply
Tags
brakes, disc, installing
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Disc brakes on a uni Pigs on Unicycles General Unicycling Discussions 16 2009-06-17 09:13 PM
Installing Brakes necro-daddy Unicycling Articles and Tutorials 2 2008-05-08 12:14 AM
disc brakes on a uni zachjowi General Unicycling Discussions 13 2006-08-04 06:10 AM
disc brakes nb General Unicycling Discussions 14 2003-02-16 10:45 AM
Installing brakes jeff d tuttle General Unicycling Discussions 12 2001-04-19 01:45 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.05824 seconds with 9 queries
