Unicyclist Community
Reply
Old 2011-01-18, 06:19 AM   #1
daveykim
Registered User
handle bar for nimbus 29
So i am planning on getting a nimbus 29 for light commuting and I wanted to know what handle bars to get. I am planning to get 125/110 double hole KH cranks and eventually some breaks.
do i get
http://www.unicycle.com/t-7-touring-handle-black
or
http://www.unicycle.com/nimbus-shadow-handle-set
they both seem to be meant for 36 but i dont think i will be getting a 36.
thanksss
davey
daveykim is offline   Reply With Quote
Old 2011-01-18, 06:21 AM   #2
DSchmitt
Human Gyroscope
DSchmitt's Avatar
i only got the t-7 handle.
and it sucked. i got it so i could distribute some of the weight to my hands...but it turns out the regular old plastic handle works better than the t-7 for that.
DSchmitt is offline   Reply With Quote
Old 2011-01-18, 07:28 AM   #3
juggleaddict
late-night rider
juggleaddict's Avatar
Send a message via AIM to juggleaddict
use the search, plenty of handle threads
I have the T7, pi bar, and I have the shadow on now (very versitile)
I've ridden with the KH bar on someone elses once. If I had my pick, I'd go with the coker pi bar on a 29er, it's extremely adjustable, short enough it doesn't get in the way on a smaller wheel, and still super useful. It's also lighter than a T7 and definitely stronger.
I really enjoyed the T7 when I had it, it's a little flemsy, but great as the first handlebar, I wouldn't pay full price, they used to have them for 35 bucks. Eventually the rails will bend a bit, and some have had them break with excessive falls.
__________________
Steel is real! => I ride a Nimbus!
juggleaddict is offline   Reply With Quote
Old 2011-01-18, 02:55 PM   #4
SqueakyOnion
likes to debate things :D
SqueakyOnion's Avatar
Send a message via AIM to SqueakyOnion
I have the Coker Pi bar on my Nimbus 29" and really like it. Never used the T7 or Shadow, but for me the Pi bar leaves nothing to be desired. It's lightweight, highly adjustable, sturdy, and not very expensive.
__________________
Nimbus 29 with Pi bar
Nimbus 36 with T7
Koxx-One Domina II
Live with intention. Walk to the edge.
SqueakyOnion is offline   Reply With Quote
Old 2011-01-18, 03:50 PM   #5
davidp
Registered User
davidp's Avatar
I had a Pi Bar for a short time and now have a Shadow bar. I got the Pi Bar when I was planning on building a 36er with a 25.4mm post but I ended up using a KH frame and 27.2mm post so wasn't able to use it. I did ride with the Pi Bar on my 24" for a while to try it out and really liked using it.
The Pi Bar would be a good fit on a 29er. It's a good length and has good adjustability. The Shadow set gives more options in how it can be setup but is probably overkill on a 29" wheel. It's also more than twice as much money.
davidp is offline   Reply With Quote
Old 2011-01-18, 09:35 PM   #6
daveykim
Registered User
awesome!
i did actually do some search threads but i seem to have the worst luck with them...
this is awesome that the coker pi bar is cheaper then the t7 and more reccomended.
so i found the pi bar at
http://www.cokercycles.com/accessori...ring-handlebar
is there anything additional i need to install on a nimbus 29???
im so excited!!!
Old 2011-01-18, 09:37 PM   #7
daveykim
Registered User
and also do you guys think breaks would be a necessary addition to the 29 with handlebar? i personllay have never ridden a 29 and im sure its much faster than my 20 trials. the coker site also sells these breaks so im thinking if i should save up a bit more and get em
http://www.cokercycles.com/accessori...pull-brake-kit
Old 2011-01-18, 09:47 PM   #8
davidp
Registered User
davidp's Avatar
The Pi Bar comes with everything you need to mount it.
If you end up with 125s a brake will be helpful on hills, but Coker wants way too much for that V-brake. The Nimbus 29" has Magura mounts so check out this thread for a way to mount an inexpensive V-brake on them (a V-brake plus lever and cable shouldn't cost more than $25). Since you can mount the brake to the Pi Bar you won't need to buy the $18 under-saddle brake lever mount.
Old 2011-01-18, 11:47 PM   #9
juggleaddict
late-night rider
I don't even run brakes on my 36" wheel. Most people that run them offroad have brakes. I would try it out how it is first, and then see for yourself, everybody has a slightly different setup.
You may want to get some cheap grips, that bar tends to be a little slick (and in my opinion too skinny) if you aren't wearing gloves or have grips.
__________________
Old 2011-01-19, 05:47 AM   #10
TheWheelThing
Registered Unicyclist
For light commuting of a few miles in each direction, I think the portability of a plain unicycle (barless? unbarred? disbarred? abarred? antibarred?) outweighs the benefits of a bar. I actually enjoy my 36er more without the bar than with. I only put it on if I plan on riding a good distance. I imagine that if I had a 29er, its greater portability would be something that I'd not want to spoil with a bar.
TheWheelThing is offline   Reply With Quote
Old 2011-01-19, 06:43 AM   #11
johnfoss
North Shore ridin'
johnfoss's Avatar
Pi Bar or Nimbus Shadow FTW. Both are great, or the KH handle. As for a brake, I'd recommend nothing yet. After you've ridden the new cycle for a while you'll have a much better idea of whether you need a brake.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-01-19, 08:24 AM   #12
daveykim
Registered User
Quote:
thanks for the opinion!
Im pretty sure what you said makes sense too.
Unfortunately I can never really try out a unicycle before i buy em. The thought of riding a unicycle at faster speeds with a bar makes me so excited. the pi bar is only 50 so im thinking of getting it and if i dont like it, ill save it for the 36' ill get in the future many years ahead!
Reply
Tags
bar, handle, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
29" or 36" for road cruising bluesman General Unicycling Discussions 39 2011-05-17 03:19 AM
Looking for advice on what I should now buy - 24" for commuting colinoldncranky General Unicycling Discussions 13 2011-01-22 02:40 PM
Nimbus Monster for snow riding? uniShark General Unicycling Discussions 20 2011-01-18 11:00 PM
Nimbus 29" crank arm choice bigwhite138 General Unicycling Discussions 9 2011-01-17 09:13 PM
[For Sale] Nimbus T7 handle bar, Nimbus gel saddle. mmenghe Trading Post 0 2010-08-22 06:05 PM
Copyright © 2001-2005 Gilby
Page generated in 0.08093 seconds with 10 queries
