Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
I am really getting close to pulling the trigger on a 36" Uni and I want to get a handle and brakes.
I like the Coker Big one because it has the lowest price point with everything I want. My only concern is that with anything I buy the upgrades later could rally jack the price up buying things like a new seat. This Unit is over $150 cheaper than a Nimbus Nightrider equipped the same way (on sale) with the upgraded T7-2 handle and brakes, and far less than a Nimbus Nightrider pro Isis on sale. The Coker seems like a good value. Any big issues with it based on experienced folks who have ridden them? If a few bucks will buy a vastly superior Uni I am all for it, but so far I don't see compelling reasons to pay more for my first 36. I am planning on doing all street cruising with it. thanks!
__________________
Nimbus: 24 / 29 / 36 (Titan) Kris Holm 24 (my baby) Twenty years from now you will be more disappointed with the things you did not do than by the things you did. - Mark Twain - |
#2 |
is what it is
Even after having gravel embedded in a kneecap after a high-speed dismount, I won't talk you out of a Big One. It is an absolute joy to be able to cruise comfortably at 10-15 mph and cover great distances on such a simple machine.
All the bells and whistles you see on the newer models are just what one would expect from any product that's been on the market this long. Innovate or die, it's what marketing people do. But it doesn't always make a product better; sometimes it just sells more units to the hardcore enthusiasts. Get yourself on a Big One, with some gloves, kneepads and a helmet, and get comfortable with it. Don't worry about upgrades at first! You'll be plenty entertained just trying to handle the beast. Even after years of 36er riding I still mess up my mounts, especially at traffic lights where everyone's staring at me. ![]() When you want to ride further, consider getting a slimmer saddle and handlebars. Play with different crank lengths; start with 150s, then graduate to 125s or 110s when you're solid on the 150s. If you want to cruise lots of hills, consider adding a rim brake off an old 10 speed. Talk you out of a 36er? You're going to bleed. You're going to bruise. You may even sprain something. But you'll be smiling the whole time. DO IT! Tell us how it goes.
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell |
#3 |
Registered User
I think you can get the Nightrider on sale for less money than the Coker. It comes with a handle and you can buy brakes later for ~$90 from the forums.
I've done some research before pulling the trigger on the Nightrider Pro and the bottomline is that the Nightrider tire is much better than any of the Coker tires, the handle/seat are about the same and if you get ISIS you can easily swap components with your other unis in the future. Last edited by Igor; 2010-12-30 at 07:54 PM. |
#4 |
...feeding the machine...
I've got several uni's, including a KH29/Schlumpf. But for a quick cruise around town, or a casual ride with my family, I still often pick my Coker Big One out of the stable. Simple and oh so much fun. If you like it (which you will), an easy upgrade you might want is a KH seat.
__________________
steveyo ...like having your own personal rollercoaster... - a few uni race write-ups - muni and kokopelli uni t-shirts, mugs and stickers |
#5 |
Registered User
What don't you like about the coker seat compared to others?
I thought the new coker XLR tire was pretty nice better than the coker button tire for street, and doesn't attract stones like the Nightrider tire?
__________________
#6 |
The KH seat has the nice groove down the middle. The Coker seat (at least mine) doesn't, so you feel a bit more pressure on the taint over a long ride.
__________________
#7 |
Registered User
Can you put regular cheapo brakes on the Nightrider or do you have to use the Magura HS33's?
__________________
#8 | |
Registered User
Quote:
http://www.unicyclist.com/forums/showthread.php?t=81006 |
#9 |
Registered User
I have a Nightrider frame, and I used to have an old steel Big One frame (much like the Nimbus Titan). between the two the Nighrider frame is more flexy side to side, and with a brake the flex was immediately apparent. I had an Odyssey Pit Bull brake on my Coker frame and it was great with no rubbing. I can only imagine that the aluminum frame is stiffer than the old steel one.
I had V brakes on my Nightrider, and I used a simple hardware store adapter that cost me under $6 to put together. That brake worked very well. If I hadn't put a disc brake on that uni it would certainly still be happily sporting the V's. The saddle on the Coker is the same as the Nimbus Hi-Top or the old KH Fusion. I have one that I pulled the cover off of, and cut a groove in the foam through the middle. It's very comfortable now, and truthfully, I find it more-so than the Fusion Freeride. I have been reading very good things about the new Fusion Street saddle for long distance, and I think it may be my next move, or maybe the Nimbus Gel. I have a Wheel TA tire that is very (very) similar to the Coker XLR. It is a very nice road tire, and fairly light as compared to the weights of Nightrider tires that people have posted in the past. I have read that the Coker version doesn't wear as well as the TA, but otherwise it should be similar. I can't speak to the Nightrider tire and picking up rocks, but the TA certainly picks up its fair share. Nothing too problematic, but don't expect it to be clean after a stint on a crushed limestone bike path. I really like my Coker Pi-Bar. The T7 doesn't have any adjustability, and so the Pi is a real winner between the two for me. I'm happy with my 36er, and I'm not inclined to change it. If I was getting a new ride and choosing between a Nightrider and a Coker Big One I would get the Coker in a heartbeat.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes |
#10 |
Registered User
The T7 is handle is definitely not great. One option I considered is a Nimbus Uni with a KH seat and KH touring Handle upgrade which seems like a good combination as it goes higher than the PI bar, although the Pibar looks really solid as well.
__________________
#11 |
Unicycle Daze - Rob Campbell
It's definitely not my preferred uni but I wouldnt talk you out of it because it is still amazing. So fun to get on when I feel like doing a nice relaxing cruiser ride. I would recommend handlebars for distances.
__________________
The most incomprehensible thing about the world is that it is all comprehensible. The most beautiful experience we can have is the mysterious. -AE |
#12 |
One wheelin' the Wasatch Front
Hey Bluesman, thanks for starting this thread!
I am still struggling with the decision myself, though I really don't need to make it until next year sometime. Here are 2 sites that sell the Big One for pretty cheap;http://www.jazzygearsports.com/Produ...big&click=3775 ($450, Free shipping!) http://www.bikemania.biz/ProductDeta...oker_TheBigOne ($400, Shipping calculated at $75 to Utah) Another option is that UDC has the Nimbus Titan on sale right now for only $350, and it looks very similar to to the Big One. Steel frame instead of Alu, different wheel, tire, saddle, but still an elegant design. (Free shipping available) I really appreciate all the positive posts on this thread. Some of the older posts I have read do a fair amount of Coker bashing. Let us know what you go with Bluesman!
__________________
If you always do what you always did you'll always get what you always got. |
#13 |
North Shore ridin'
Big One with Pi Bar ftw! Stiffer frame than the Nimbus, and a handle with all sorts of adjustability. Nimbus Titan is a good choice also, for a great price.
Main difference between the two is the wheel; 48 spokes on the Coker and 36 on all the others. This adds some weight to the wheel, which is heavy enough already, and most would probably argue that 36 seems like enough on 36" unicycles. Unless you plan to beat on it. Tires: TA is an awesome road tire, and goes forever. All 36" tires are heavy, with the Coker Button being a little lighter than all the others. But the downside of that is a shorter tread life (though still very long). As the buttons wear down they get more and more sensitive to road camber, which matters a lot if you're a roadie. Brakes: Don't bother unless you know you'll be riding very steep hills, or long mountain descents. You don't need one for "regular" terrain. And ignore the Coker web site's suggestion that the brake is a safety feature. Though it can help you stay in control on steep descents, mostly it's there to preserve your knees.
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#14 |
Registered User
The titan looks like a decent option to get started for cheap money. The rim and tire are both pretty nice for the money and the overall weight is actually pretty light. Even though it's steel cranks, I wonder what they are and how you would replace them, are they just standard bycycle cranks. Because they are steel. After lots of UPD's instead of the softer aluminum cranks bending would the hub possibly have a problem??
__________________
#15 | |
Quote:
I am seriously considering buying this one today while it is still on sale. The only thing I don't like is the club saddle - so if I make the purchase I will do it over the phone and upgrade to the Nimbus Gel. Later I will probably buy a PI bar from Coker. I will report back if I do buy it
__________________
| Tags |
| 36", 36er, big, big one, buying, coker, talk |
Similar Threads
| [For Sale: Australia] Clean out sale | knighty | Trading Post | 6 | 2011-02-04 01:45 PM |
| Coker "The Big One" or V2? | Flyjeffva | General Unicycling Discussions | 7 | 2010-12-24 01:45 AM |
| In need of full working copy of dreamweaver cs4 or cs5 | LucasWintercrane | Just Conversation & Introduce Yourself | 5 | 2010-12-18 04:23 AM |
| Buying that first 36er | monocyclism | General Unicycling Discussions | 9 | 2009-01-15 09:44 PM |
