#1 |
Registered User
What fender are you using?
I've seen some references to Topeak Defender as a good choice. Any others that I've missed? Has anyone adapted a front fender designed to insert into the bottom hole of a bike's fork stem? I'm on a 36" Nightrider. Thanks.
#2 |
Didier
I have de same concern and Geoff from Australia recommand me to use a Zefal Swan Plus to be fitted on the seat post or directly on the frame (this fender is compatible up to 32mm).
http://www.zefal.com/zefal/produit.p...29a318c5efd29a ![]() This fender has 2 joints to be adjusted close to the tire
__________________
http://monocycle.info http://teamcdkmonocycle.blogspot.com/ MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank ![]() my goal : a 3 geared 29" to have only one uni for all kind of rides :-) |
#3 |
Registered U(ni)ser
SKS X Blade MTB Mudguard
http://www.evanscycles.com/products/...guard-ec005804 ![]() Perfect for my 26" and 29". Simple to attach and detach from the seat post (no tools needed), easy to adjust, durable. Don't know how well it works for larger wheels though, when I bought my X Blade it was specified for 26"-29" (and works well with wide tires). |
#4 |
Proper Job!
Zefal XXT Rear Mudguard on the 29"
![]() Nice and wide, stops all the muck but does not follow the contour of the wheel, I have not found this to be an issue. Withstands UPDs by folding up or detatching itself on rough UPDs (not sure if its meant to do that )
__________________
The mountains’ my playground, a place to unwind Where negative thoughts are left far behind - Terry Peterson "I'll be racing the clouds home" Last edited by Hung Like Saddam; 2010-12-03 at 07:16 PM. |
#5 |
Registered User
Thanks for the input. They all look pretty similar - seatpost mount for easy on, easy off.
#6 |
Not "2" Tired
I'm pretty sure you attach these to the seat *tube*, not seat post, unless it's for a bike.
#7 |
Registered User
Good point. I was using the term loosely to simply mean "that vertical thingy that attaches the seat to the wheel part"
Thanks for including the pic - that looks like a nice fender. I'll visit the LBS this week, as the snow here has been frozen at night and sloppy wet during the day.
#8 |
Meat popsicle
I chose a model with as few joints as possible in the hopes that it would survive riding (read: UPDs) longer. It doesn´t follow the contour of the wheel at all but seems to do its job in terms of keeping my lower back free from mud.
The name of the fender is SKS X Tra Dry X3 Last edited by minkuni; 2010-12-06 at 08:43 PM. |
#9 |
is what it is
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell |
#10 | |
Surf the Turf
Quote:
http://www.unicyclist.com/forums/sho...=83212&page=12 I have set the front mudguard (fender) close enough to the tyre to catch stones and knock them out of the tread on each revolution of the wheel. Its seems to work before the stones have time to be pushed deeper into the tread. Bicycles used to have stone catchers like a wire framework - dont know if they are still available.
__________________
1 wheel, 1 day, 100 miles, 63 years... |
| Tags |
| fender |
Similar Threads
| [For Sale: USA] Feeler: Cranks, fender, bottle holder for sale | BillyTheMountain | Trading Post | 3 | 2009-10-13 03:31 AM |
| Multi speed geared hub, awesome fender, sweet red color and cottered cranks!! | Tim | Just Conversation & Introduce Yourself | 7 | 2005-05-20 07:18 PM |
