Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Thread Tools Search this Thread Rating: Thread Rating: 49 votes, 4.98 average. Display Modes
Old 2012-07-22, 12:11 AM   #121
Nurse Ben
XC Muni
Nurse Ben's Avatar
Wire bead is economy model, it appears to have less durability, probably because theY "dumbed down" the casing to cut costs, so no snakeskin and no EVO, which means it may not be tubeless compatible. It will also be heavier, but less expensive.
Pacestar is the XC version, this is what I ride; I believe Claude has the same. It has been a great tire, no excessive wear, still looks fresh after a lot of rugged riding. Best 29" muni tire I jave ever ridden, hands down.
Trailstar is the sticky rubber version, might be a good choice for DH, but the Pacestar is a more durable choice and works well, so who needs more?
There is also a DH version coming out soon, so you might want to look for that if you can wait; chances are that I'll get one and then my Hans will be looking for a new home...
I have a 29 x 2.4 Ardent that is ~75% of new, it's not getting any use, so let me know if you're interested in it.
__________________
I dream of hamsters and elderberries
Nurse Ben is offline   Reply With Quote
Old 2012-07-22, 01:01 AM   #122
jbtilley
Muni Foot
jbtilley's Avatar
Thanks for the info. Slowly building up the knowledge base here.
I very well may be interested in the ardent. Where did you buy the hans? A LBS?
jbtilley is offline   Reply With Quote
Old 2012-07-23, 11:48 AM   #123
Nurse Ben
XC Muni
Nurse Ben's Avatar
On-line. All my LBS have to order fat tires (anythjingh over 2.25") and they charge retail.
__________________
Old 2012-08-03, 02:59 PM   #124
uniShark
muni commuter
uniShark's Avatar
I finally feel like I've ridden the Hans enough for a little review. Some disclaimers: I'm not as much of a gear ho -- ahem, expert -- as Ben, and I can only compare to the Stout, and I didn't ride the 29 at all for more than a year before switching to the Hans. I'm also running the tire on the KH XC rim, so maybe a little different than how it would feel on a wider rim. But for what it's worth, my review is that the Hans is good at low pressure (I'm over 200# with gear and run it at about 20 psi), has great grip in all conditions, and rolls well. I love it.
__________________
My 29er is my little wheel. Roll it, baby!
pLs forgve anu typist imak win positing forum my fone.
uniShark is offline   Reply With Quote
Old 2012-08-07, 07:53 PM   #125
Nurse Ben
XC Muni
Nurse Ben's Avatar
Ahem...It's spelled with a 'W'
Glad you like it, Hans is my buddy, I have yet to feel like it could be improved, even weight wise it's not that heavy.
I was thinking about upgrading to the Hans Dampf SG (Super Gravity) downhill tire when it comes out, but now I'm looking at the Surly Knard 29 x 3 to go on the Oregon
__________________
Old 2012-08-13, 06:07 PM   #126
Klaas Bil
Sir Prince of Newsgroupia
KH XC rim: which tyre doesn't blow off?
My post is not exactly a tyre review, but a set of questions I thought I'd ask where people are knowledgeable about 29" tyres.
I bought a new uni with a Kris Holm Cross Country rim (37 mm wide) in July 2011. To my order, it had the Schwalbe Marathon Supreme 28 x 2.0" on it. After about two months and probably less than 1000 km, the tyre blew off the rim with a loud BANG, on an otherwise totally uneventful stretch of straight flat road. I had pumped it that morning to 4.8 bar, so well within the rated pressure of 5 bar as printed on the sidewall.
Fast forward to July this year. I finally bought a new tyre (again a Schwalbe Marathon Supreme 28 x 2.0") since I wasn't sure the old tyre was undamaged, and a tube, and mounted them. Within a month (in fact, during the 100 km race at Unicon ) it blew off again! Again, I had pumped it that morning, to exactly 5.0 bar this time.
Today I mounted a Schwalbe Big Apple 28 x 2.0" on the same rim. The Big Apple is a non-foldable tyre whereas the Marathon Supreme is a folding tyre. I assumed (admittedly with no basis at all) that a non-folding tyre might be stronger. On the tyre sidewall the print says pressure MIN 2.5 bar, MAX 5.0 bar. Confusingly, in the instruction leaflet is a picture of the tyre's sidewall that stated MIN 2.5 bar, MAX 6.0 bar! Next to it is a drawing of a rim without an inner holding protrusion (I don't know the name, it is apparently intended to "hook" the bead under it). In that picture it says MAX 5 bar. As if the protrusion makes for a higher max pressure, which makes some sence. Maybe on the XC rim (which does have this protrusion) the max is 6 bar? By way of precaution, though, I pumped it to no more than 4.5 bar.
I should add that both types of tyre mounted very easily on the rim. The Big Apple mounted even easier than the Marathon Supreme. No force at all, it just "flopped" in place. I found that actually disturbing, in light of my experiences.
Questions:
  • Does easy mounting of a tyre indicate that the tyre is more prone to blowing off the rim?
  • Is the Kris Holm Cross Country rim known to be a bad combination somehow with the Schwalbe Marathon Supreme 2.0"?
  • Can it be true, as someone suggested to me, that the 37 mm wide rim is actually too wide for a 2.0 tyre?
  • Pressure recommendation for the Big Apple, in light of the above?
  • Suppose this combo fails again. Being stuck with the rim, would it be better to mount a wider tyre? I have some experience with the Big Apple 28 x 2.35 and did not like the sideways rolling effect on slanting roads. Any other tyre suggestions for road use that are more stable on this rim, both in terms of sideways roll, and in terms of not blowing off?
Klaas Bil is offline   Reply With Quote
Old 2012-08-17, 11:50 AM   #127
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
@Klaas, I don't run road tyres on my 29er, but FWIW from my general experience:
A 37mm rim is certainly wider than people would normally use for a 2" tyre on a bike, but as long as the tyre is wider than the rim it shouldn't slip off. I run a 2.1" tyre (WTB Prowler) on my KH29 XC rim with no problems, but not at such high pressure (it's an XC machine, so usually around 25psi). 5 bar is around 70psi according to a quick google.
I would say 70psi is an extremely high pressure for a 2" tyre though. Are you sure you really need it that hard? I would say it would feel pretty firm even for road riding at 50psi (3.4 bar).
On the other hand, I run 1.5" tyres at 85psi on my tandem - obviously different rim and tyre, but still wide-ish tyres at high pressure.
Perhaps the hook (that is indeed what it's known as) on the KH rim is a bit small or not "hooky" enough for running such a high pressure, even if the tyre is rated that high.
Another thing that comes to mind is that sometimes a catastrophically failed (split) tube can blow the tyre off the rim as the air escapes, making it look like the tyre was the cause of the failure. Could you perhaps have a sharp bit of swarf or something on the inside of your rim that's bursting the tubes? Or could the tubes have been pinched on fitting? (not meaning to suggest you can't fit tyres properly )
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski)
"I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule)
rob.northcott is offline   Reply With Quote
Old 2012-08-19, 02:39 PM   #128
Nurse Ben
XC Muni
Nurse Ben's Avatar
If I was Riding road and wanted to run high pressure, I'd get a narrower rim with a better "hook". The KH rims are not designed for high pressure road use. What is probably happening is the rim is wide relative to the tire, so it's spreading the tire and you are not getting a good "hook" on the bead. You probably want to get a road bike rim, one designed for touring or tandem use. I'd suggest a Stan's tubless set up, make sure and coat the tire bead and rim edge with Stans, that'll increase grip at the bead. Take a look at the new Nimbus Stealth 2, the 36er version has an excellent hook, so maybe the 29er version is made the same?
__________________
Old 2012-08-20, 07:23 PM   #129
Klaas Bil
Thanks Rob and Ben, that gives me something to work with.
Quote:
It's not really that I need it, but generally I like high pressure for road riding, because of the associated low rolling resistance.
Is there a way of checking if the hookiness is sufficient. E.g. should it be "this size"?
I did a quick inspection before mounting the new tyre and tube and saw nothing, so this looks not too likely to me. And no, tubes have not been pinched on fitting - at least not the second one; the first one was mounted by municycle.com and they surely know what they do. And then again, not only do I know how to fit a tyre properly, but it went on with terrifying ease, in view of the earlier blow-off. So there was not the least temptation to use tools.
Quote:
I think you're onto the root cause there. I'm not a big fan of tubeless in view of the trouble that people sometimes have with it (until it's properly set up, that is). But I'll look at a more road-oriented rim. Not too narrow a rim though, I used to have a Big Apple 28 x 2.35 on a quite narrow rim, and its sensitivity to road camber was quite uncomfortable.
Old 2012-08-23, 05:26 PM   #130
muni123
Unicyclist
muni123's Avatar
a bit off topic here, but has anybody ever built a 700c road bike wheel for their 29er?
muni123 is offline   Reply With Quote
Old 2012-08-23, 07:21 PM   #131
davidp
Unicyclist
davidp's Avatar
Quote:
I built a wheel using a Velocity Dyad and Resist Nomad 700x45 tire. It's quick and comfortable with 114mm cranks. See this thread for more: http://unicyclist.com/forums/showthread.php?t=92920
davidp is offline   Reply With Quote
Old 2012-08-23, 07:45 PM   #132
muni123
Unicyclist
muni123's Avatar
that sounds sick but i was thinking more along the lines of 700 x 20-25
Old 2012-08-23, 07:51 PM   #133
davidp
Unicyclist
davidp's Avatar
Ah, in that case check this thread out: http://www.unicyclist.com/forums/showthread.php?t=77230
Old 2012-08-24, 01:54 AM   #134
Nurse Ben
XC Muni
Nurse Ben's Avatar
I much prefer my 36" for going fast on the road, but if you want a lightweight road 29" (700c), then you could probbaly just get a mtb rim and choose a wider road bike or tandem touring tire, say 35-40c, so a rim width of 25-28c.
One thing to consider is tire profile and how that is affected by camber. A wide rim and relatively narrow tire will have a flatter tire profile, which seems to reduce the affects of road camber.
@Klaas,
My 36er is my first dedicated tubeless, so I put a lot of thought into how the tire and rim work together. The Nimbus Stealth 2 has a very aggressive "hook" which grabs the tire bead and helps prevent tire blow off. Nimbus built this rim specifically to address tire blow off on the 36" wheels, but when the design was successful they decided to apply the design across all sizes. The 29" rim is 800gm and 42mm, so kinda heavy and big for a super light set up, but for running a 2" or large tire, it's a good choice.
If you search MTBR under rim reviews, you can see what is popular and then use that info to search for rim profiles to find one that has a strong hook. Tubeless ready rims seemed to be designed with better hooks.
KH rims do not have a very strong hook.
__________________
Old 2012-09-11, 12:54 AM   #135
BrickMan
Unicyclist
BrickMan's Avatar
Anyone know what is the projected date for the new Hans DH to hit the market? I read all I could find.
BrickMan is offline   Reply With Quote
Reply
Tags
29er, official, reviews, thread, tire
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The "official" Muni Tyre Review Page Nurse Ben Unicycle Product Reviews 466 2020-01-30 07:35 PM
The Official 19" Trials Tyre Thread Sponge Unicycle Product Reviews 438 2017-02-23 08:13 PM
The Official "What's up this weekend, brah" thread CottonAnatomy Just Conversation & Introduce Yourself 24 2009-12-21 08:36 PM
WTB Dissent, new 29er x 2.5" tire brycer1968 General Unicycling Discussions 1 2009-11-10 04:05 AM
The official "uncover the mole" game thread habbywall Just Conversation & Introduce Yourself 55 2006-02-27 09:59 PM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.12259 seconds with 11 queries
