#61 |
Registered User
#62 |
Is it June yet?
I used the Marathon Supreme 28x2 on my 47mm rim and it worked great. I have since switched to the Maxxis Ardent for off road rides. I really like that too. I'm thinking of having another 29 wheel built for my road tire so I can easily swap between the two. Actually, I should just get another 29" unicycle
#63 | |
Registered User
Quote:
I have the 2" Marathon Supreme. Bert, we should try it again sometime. Now that you are a guni guru, I will ask you to take it easy on me. Scott |
#64 | |
Registered User
like minds think alike?
Quote:
Having two wheelsets would allow for quick swaps between commuting and XC/muni, and would also encourage me to keep those bottom/bearing bracket bolts properly torqued for doing the commuter guni thing. Right now the things that are holding me back from building the new wheelset are the wait for the new Freeride rim with "improved spoke offsets" (see http://www.unicyclist.com/forums/sho...highlight=2011), and the UDC-US backorder status of the Moment Hub with 150/125 dual-hole Moment cranks (which I would likely swap out with the 150 single-hole Moments on my "commuter rig"). In the meantime I'm having fun with the Ardent on the geared hub/XC rim. In fact, if I keep having as much fun as I have been with the current set-up, I might just decide to give up on the concept of the second wheelset altogether. But before I do, I'd still like to experience the ride of the direct-drive KH29 with wider Freeride Rim and Ardent 29x2.4 for the XC/muni I enjoy locally. Decisions, decisions. Oh well -- extra wheelset or not I know I'm gonna have some new fast fun when the trails finally do dry out. And Scott, let it be known I'm no guni guru ...... yet! And I'd be happy to ride with you again whenever/wherever. (Keep me posted on your next visit to SLC.) Cheers to All, Bert Last edited by UPD in Utah; 2011-04-27 at 05:35 AM. |
#65 | |
ERIC P
Quote:
General rule is that your tire should not be narrower than your rim 2.0" is ~51mm so should work fine with a wide rim but if used off-road or in loose gravel your rim will be susceptible to damage from rock strikes etc. I haven't used a skinny tire on a wide rim yet so can't comment on ride characteristics. Can't help you too much on the other points other than to say that if I was going to have a mixed use tire that was mostly dirt and part pavement I would not hesitate to use a WTB Prowler SL. Not sure about mostly pavement and part dirt though.
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton Last edited by saskatchewanian; 2011-04-29 at 07:41 PM. |
#66 |
Registered User
The last few months I had my 29er I was mostly using it for a short commute over mixed terrain (more pavement than dirt). I really liked the Geax Saguaro 29x2.2 for this use. It feels very quick on pavement and is good in most off-road conditions as long as it isn't too wet. Tread life is surprisingly good too. When I sold my 29er I kept the Saguaro to use on the rear of my bike.
#67 |
XC Muni
Still rocking the Ardent 29 x 2.4, running a 26" DH tube at 20psi, no snake bites to date, though occassionally I do get a rim hit.
I was running 18psi, but once the tire broke in I found I could still get a nice ride at higher pressures. I would even consider 22-24psi in some conditions ![]() Great tire for 29er muni. |
#68 | |
Sir Prince of Newsgroupia
Quote:
#69 |
XC Muni
The Karma has a 120tpi casing which may make it feel more supple in comparison to the Navegal, also the Karma seem to have a tighter pattern so better for road. The Stout is a fine tire too. Karma is also the lightest, I believe.
#70 | |
Didier
Quote:
__________________
http://monocycle.info http://teamcdkmonocycle.blogspot.com/ MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank ![]() my goal : a 3 geared 29" to have only one uni for all kind of rides :-) |
#71 |
Mainly XC Muni
I've got a WTB Prowler 2.1 on my 29er at the moment. I bought it a year or so ago as an emergency "mud" tyre for racing if it was too sticky for the Racing Ralph 2.4 (which clogs quite easily in sticky mud and doesn't have much frame clearance). Haven't needed it until this year's Mountain Mayhem 24 hour race, which was threatening to be muddy (although actually wasn't that bad in the end), and I'm really impressed. It handles very well on mud, grass and roots. Haven't tried it on rocks yet. An excellent xc tyre - slightly heavier than the Ralph, but not by too much.
I'll leave it on and see how it handles my local rocky/gravelly trails (where the Ralph is excellent - no clogging problems round here). I'm running it with a tube BTW, although I am a fan of tubeless on the 29er - I was intending to swap it back after the race so didn't want the faff and mess of setting it up tubeless. Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) Last edited by rob.northcott; 2011-07-08 at 10:36 AM. |
#72 |
Registered User
Ardent vs Dissent
I just switched out my WTB Dissent for the Ardent 2.4. What a great ride in comparison! it's noticeably lighter and more nimble and much less rolling resistance. The Dissent had this characteristic of rolling so straight that you could lean out to the side with no effect on your direction. As interesting as that may sound, it was pretty tiring actually; since correcting/turning meant LARGE movements. I know MountainUni1 was experiencing similar.
Only a couple of negatives for the Ardent that I've seen. It's not great in mud, as expected. I'm a bit concerned with the amount of sidewall actually contacting the ground during regular spinning. I've got a pretty good amount of pressure in there, no bottoming out on the rim when hopping. I've literally got a 1cm wide strip of dirt around the outside edge of tread. Anyone else notice this? Pluses for the Dissent: Awesome in loose rock and mud! It feels a lot like the Maxxis Minions I have on my DH bike. The Dissent truly is a DH tire. If I was going to take my 29'er to a lift accessed park, I'd probably put the Dissent back on for the day. All in all, unless I slice my sidewall open on a sharp New England rock, I'll keep the Ardent on!
__________________
Nimbus 24 MUni Nimbus Trials Triton 29'er w/MountainUni disc brake system. |
#73 |
XC Muni
Hey Jay, I have the the Ardent 29 x 2.4 EXO and the Ardent 26 x 2.6 DH.
The 2.4 has half the weight and a much softer sidewall than the 2.6, but it is a durable EXO kevlar sidewall so it is more cut resistant than similar 29er tires. To make it more "resilient", I run a 26 x 3" Duro HD tube, really makes a difference. I weigh 200# and running 18-20psi with no snakebite issues. I don't think they'll make the 2.6 for the 29er due to the high weight, but in comparison, I run a thinner DH tube in the 2.6 and I can still get away with running 16psi, so the sidewall is much more resilient. I'd take a 29 x 2.6 if they made one ![]() Try the super duty tube, it's the same one that KH and Nimbus put in the 26 x 3 " munis, I think UDC has them for ~$10 or so. I also use this tube in my Larry 26 x 3.8 and it works awesome! |
#74 |
Registered User
Thanks Nurse Ben! I'll give that 26" Duro tube a shot.
__________________
#75 |
Registered User
Interesting you guys bumped this thread up yesterday & today....
I was just trying to figure out which of those two tires to mount up on my Nimbus-hubed, Freeride-rimed, fixie 29er wheelset to go check out some trails in advance of Ben's visit to Utah next week. Josh talked me into buying a Dissent for the new wheelset, and it definitely blasts through the loose rocky stuff, but the Wasatch Crest trail (where I'm headed on Sunday) is a pretty earthy rolling ridge ride. I'm thinking of going with the Ardent because there will be climbing and it's the ridge runs at 9500' plus, so lighter should be waaay better. However, I was also a bit concerned about rock-stab punctures too, despite the "Exo" protection. ... of course the Dissent would give me a better workout and will get me in better shape for Ben's visit. Plus, if I switch to the Ardent before next week, after pushing the Dissent this week, those climbs will seem like nuthin' next week. (The goal being to have Ben crying "Uncle" and begging for mercy next week. -- Nah, not really. -- The goal being to ride as many of the ups as my old pumper will allow both weeks.) Still, it would be interesting to compare the two on the same trail at altitude, so maybe I'll leave the Dissent on this weekend, and swap out before Ben gets here. Either way, I'll try and post a semi-controlled comparison of the two ... one of these days. Cheers from Utah. (Ben, did you find out if there was an opening in the hypobaric chamber schedule early next week? You might want to plan an overnight stay. )
| Tags |
| 29er, official, reviews, thread, tire |
Similar Threads
| The "official" Muni Tyre Review Page | Nurse Ben | Unicycle Product Reviews | 303 | Yesterday 06:45 PM |
| The Official 19" Trials Tyre Thread | Sponge | Unicycle Product Reviews | 423 | 2013-02-09 03:15 PM |
| The Official "What's up this weekend, brah" thread | CottonAnatomy | Just Conversation & Introduce Yourself | 24 | 2009-12-21 08:36 PM |
| WTB Dissent, new 29er x 2.5" tire | brycer1968 | General Unicycling Discussions | 1 | 2009-11-10 04:05 AM |
| The official "uncover the mole" game thread | habbywall | Just Conversation & Introduce Yourself | 55 | 2006-02-27 09:59 PM |
