#1 |
Registered User
First long route (300km) on 29" Muni
Hi! I'm going to have my first long route (300km, I added the profile in 2 images) on my 29" Muni in October. I have 15 days to complete it, so I think I have enough time, but I'm going alone and crossing forests, mountains and not very good roads so I'm a bit "nervous".
It would be great if someone could give me some advices. I'm used to commute with my Qu-ax 29" 10-20km everyday (on the streets) but I'm still a bit concerned about potential problems riding countryside and I would like to know advices to train myself this last month prior to the route. what kind of muscle or irritation problems I could have, how to avoid them and what to do if you get irritations or even wounds on your testicles and the zone of the legs surrounding them. My Qu-ax is also in factory status, so I would like to know which elements should I change and upgrade. I get a lot of discomfort from the saddle and I don't know what would be better getting a gel saddle or air-modding my Qu-ax saddle. Breaks and handle would be needed? On the other hand I would appreciate advices about clothes, shorts and shoes, the expected weather is 20/10ºC and 0.20cm raining and I would have to walk at least a 5-10% of the route because the terrain would be too difficult. Sorry if it's too much asking, I'm very excited with this route and I would like to plan it the best way possible. Thank you very much!
#2 | ||
Unicycle Advocate
Quote:
Quote:
Good luck! |
#3 |
J Myers
Have fun
Most will insist you get a brake and a handle. You don't really need either. Try some bike shorts with the least amount of padding you can find. Tri shorts will work also.
You should have plenty of time for your tour. Sounds like fun. Enjoy. |
#4 |
Registered User
Thanks! I'm always riding my muni with a 2-6kg full rucksack, but far sure I will need 6-10kg while I travel (at least 1-2 liter water and some food), I know the muscles won't be a big problem (I hope) but the testicles and "just behind them area" worries me, I got 2 wounds during last weeks and I was using shorts with normal padding. Btw, any suggestion to heal that faster? I still have one.
I don't know why, maybe I have very sensitive balls or maybe they are a bit bigger because I also have many problems with the paragliding harness. Also when I do freemounting the pain is sometimes unbearable, I squish them when I jump while supporting on the saddle. Should I try using "testicles protection" like those used in hockey or martial arts? Why less padding is better? I though about getting some shorts with gel padding and also external protective cushion in case of falling. Should I get more protections besides helmet, ankle supporters and gloves or would it be better to go with just the minimum? Thanks again
#5 |
ERIC P
A handle is great for getting some weight off your saddle. I like long and low for on the road but a higher shorter handle just past the stock lift handle for off road.
when it comes to saddle padding I am in the camp of less is more (to a certain extent) lots of padding will just make the padding push everywhere where saddles with less padding will have more localized pressure points. I also have a grove carved in the foam on all my seats. this helps a lot. edit: just noticed you mentioned converting your existing saddle to an air seat. Don't. They suck. modify the foam first. I carve away some from the front and back making it flatter then add a grove down the middle. If you are not used to a brake don't bother with getting one. Grabbing too much brake when you are learning to use it is a great way to hurt yourself, not something you want to do 100km from nowhere.
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton Last edited by saskatchewanian; 2010-09-01 at 02:52 AM. |
#6 |
Is it June yet?
In addition to the above advice, use (generouse amount) chamois creme. I like to reapply every 10-ish miles. It helps me a lot.
#7 |
J Myers
Are you having impacted sweat gland boils/abscess? They swell up like a large zit and can be really sensitive to sit on. It is important to maintain hygiene around the infected area. Try washing with warm/hot water three times a day might help you to keep from developing more.
If this seems to be what you are having you may find relief if you try soaking them with hot water three or more times a day. Also using an antibiotic cream after washing may help. |
#8 |
Reed Breuer
my problem with cycling is the seam in my bike shorts. notsomuch in the behind the balls region though. at the moment i have a red spot in the crease between my right leg and my pelvis region. it may be the shorts, the bike saddle, or me
__________________
"I'm probably not advanced enough to have thoroughly tested it while riding, but I'm unadvanced enough to have very thoroughly tested it while falling." -uniShark I ride for Christ-opher Walken |
#9 |
level 1 fat guy
Is it possible to make caches ?
A cache is a supply of food and stuff hidden in the woods. Study the route with google maps satellite. Then drive ahead with a vehicle and leave cool stuff for yourself. Fishing pole by the lake, that sort of thing. Magazines and batteries are great at night. Bears and coons leave canned food alone, so use canned food and drinks. Actually, I have heard of bears drinking canned beer, but in general, canned food caches work well.
Light is right. If you cache a day apart, all you will need is a fanny pack for your rain gear. Attach the flat kit and water bottle to the frame and you are good to go. I agree that the KH freeride saddle is best. I hate the look of those super tight fitting spandex looking bike shorts, but I wear them anyway on long rides, less friction. Not wearing a backpack is the best upgrade you can do for your trip. Some water purifiers are very light, and could save weight by allowing you to carry less water, while improving safety. Almost everything else is to much junk to be worth touring with on a unicycle. Riding in the rain will launder your clothes. So don't pack any clothes. Cut your tooth brush in half and drill holes in the handle. Cut down the bristles, they are twice as long as what you need. Pull out every other tooth from your mouth. Just kidding, but really, get rid of everything that won't kill you when it's gone. Uni riding isn't backpacking. You will be able to ride much further and have a better time if you don't carry any real load. 40 lbs is OK for me backpacking, on a uni, I would try to keep it under 5, water and everything. |
#10 |
Registered User
Well,the caches won't be possible. The place is about 1000km far from my city and a lot of people do the same route. Backpack is not such a problem for me, I use to travel with 5kg(11lbs) everyday. One of my concerns is bringing protections with me, I mean, I'm not so used to bad terrain, I can do it in parks and countryside, but mountains and altitudes 2x-3x higher than in my city is making me a bit nervous... How much weights a full pack of arms and legs protections (rigid or soft)? Does the extra weight compensate with the extra protection?
#11 |
Look mum, no training wheel!
A bit of advice I can give that you will not likely get from elsewhere (for the simple reason that what I suggest is something that few will have tried).
I am talking about a sheepskin cover for the seat. You cut a long tongue of plush sheepskin - enough to go from the front of your seat to the back fold over and back to the front. Double sided wool padding. You shape it so it reasonably matches the shape of the seat without being anal about it. ie Full width at the back tapering to a waist before widening out a little to the front. Fitting it is easy - A dozen lacky bands - some at the front, some at the waist ans some at the back. You can work out the length and type yourself. It is good for easily 500km a side but in your case you may care to reverse it so the down side is the upside half way thru your journey. Make sure you have another handful of lackies in your pack for the job. Unlike air cushions and stuff you do not need to change your technique or practice with it. Though you will have to drop the seat post maybe 8 or 10mm and then readjust it up a bit a couple of days later as the padding gets a little compressed. I do several thousand miles a year and this has proven far better than ointments and stuff. And it is fairly cheap. |
#12 |
You can get ointments that are a silicone sealing type - must be put on dry, not immediately after drying down.
You can also get antifungal ones. And y ou can ones that are both. See a chemist. You will get the good stuff at a third the price of stuff that is sold for cyclists. And maybe the chemist will know what he is giving you and not just the manufacturers blurb. |
#13 |
With the distance you state, then at least you will have fairly toughened tissue at the crotch.
You could dispense with the underpants and just have the chamois of bike shorts in direct contact but I have no experience of that. I ride with underwear under my padded bike shorts. Undershorts - High level of cotton or wool and make sure they have some leg to them. Otherwise you will chafe the soft tissue either side at the crotch. You will not get far if that happens. |
#14 |
Registered User
Thanks for the advices, could you post a photo of the customised saddle? It seems a cool idea but I would like to do it right.
I also wear underpants always with my bike shorts Btw, did you experienced anytime pain right above you knees? I sometimes do a special training going up and down 20 times on a 70m 25 degrees slope... 30 minutes after that I have some pain and it disappears next day, but I would like to know if there is any way to reduce it while riding... I don't care about the pain but about not hurting my legs. Thanks
#15 | |
The Univiking
Quote:
![]() You don't ride recumbent bicycles too by the way? Or play the flute? I second your theory that guys with saddle problems just have bigger balls. It's a curse we have to live with
__________________
Experienced noob with nimbus 24" muni, nimbus 29", and nimbus impulse 36" http://twitter.com/glye http://www.flickr.com/photos/gunnste...tags/unicycle/ |
| Tags |
| muni |
Similar Threads
| how long before balance becomes "second nature" | ganfax | General Unicycling Discussions | 22 | 2009-02-23 01:56 PM |
| It's MUni Time, Just One Wheel's Long Island MUni Ride Saturday January 6th, 2007 | JustOneWheel | General Unicycling Discussions | 0 | 2006-12-21 07:27 PM |
| Another really long post (not by paulie pavlic) with the word "Unicycle" in it. | sendhair | General Unicycling Discussions | 0 | 2003-06-09 03:08 PM |
| My 20" monty is en route...ques? | Sofa | General Unicycling Discussions | 8 | 2002-11-15 11:26 PM |
