Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycling Articles and Tutorials > New Article/Tutorial Request
Reply
Old 2010-08-30, 06:38 PM   #1
Richard12
Registered User
HELP my uni crank is loose
my crank is loose. please help. is it called a crank anyway? ive been unicycling for about 5 days in a row now inspired by a cyclist in the next town who has not (or more than 1 wheeled) bike. i realised the crank wont come tighter unless i get a grip but its a tight fit. also if i do that it doesnt look aligned. look on my photos to check it out more. thanks everyone
__________________
Rock on and peace out
Richard12 is offline   Reply With Quote
Old 2010-08-30, 09:18 PM   #2
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
You need a socket wrench to tighten the nut that holds your crank on.
Before you put the crank on you should clean the inside of the crank and the square taper of the hub and add a bit of grease. Those old steel crank arms can be tough to seat properly so it might help to also set the other side of the hub where it connects to the crank on a chunk of wood and put another one on the crank you are installing. Give it a couple good whacks right over the hub to get the crank firmly on there before tightening.
If it still comes loose after that your hub/crank interface might be too worn and you may have to get a different set of cranks.
you could also try blue locktite on the treads of the nut to keep things tight.
__________________
saskatchewanian is offline   Reply With Quote
Old 2010-10-05, 01:15 AM   #3
UNIDRAGON212
Trials...Jumpy Jumpy
UNIDRAGON212's Avatar
This has happened to me before. There is a chance the seat is on backwards. Try turning the seat around. Either that or locktite does work well.
UNIDRAGON212 is offline   Reply With Quote
Reply
Tags
crank, loose, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help! My Schlumpf half-shifts by itself. What is going on? naturequack General Unicycling Discussions 12 2011-12-04 12:00 AM
Is my tire backwards?? Schrodinger General Unicycling Discussions 11 2010-07-22 01:47 PM
My unicycle is clicking.... RancidTurnip General Unicycling Discussions 6 2010-07-11 02:32 PM
Need help with my feet Galluni Just Conversation & Introduce Yourself 12 2010-05-24 06:02 AM
Today, my heart is crushed... ITEMNO530 Just Conversation & Introduce Yourself 27 2010-02-12 12:07 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08832 seconds with 10 queries
