Unicyclist Community
Reply
Old 2010-08-19, 09:51 PM   #1
Milosboy
Live every week like its shark week
Milosboy's Avatar
Cool Velo/Nimbus Gel Saddle Modification?
Hello users of the forum,
Just curious -- is there any cheap way to modify this saddle to make it more comfortable? I know I listed two, but they are essentially the same. The problem I have isn't with the width, but that it puts too much pressure on my crotch and makes me go to sleep, if you know what I mean, lol. I saw a modification for a different saddle (Don't remember brand) and they cut a strip out of the foam down the middle, but I'm not sure if this would be possible on this saddle, considering it's gel.
Thanks!
Milosboy is offline   Reply With Quote
Old 2010-08-19, 11:47 PM   #2
unireed
Reed Breuer
unireed's Avatar
there is a searh feature in the toolbar. use it and search for saddle comfort modify etc. there are many threads that will answer your question.
__________________
"I'm probably not advanced enough to have thoroughly tested it while riding, but I'm unadvanced enough to have very thoroughly tested it while falling." -uniShark
I ride for Christ-opher Walken
unireed is offline   Reply With Quote
Old 2010-08-20, 09:54 PM   #3
ezas
Registered User
I think that was MuniAddict who hogged out a channel in a saddle. I've only had the cover off of a Fusion Free Ride so I can't really help with a gel saddle. Some people like the channels, for me they don't do much. More better, I learned to stand up and pedal when my taint needs a break.
__________________
The only constant in nature is Dr House's epiphany 10 minutes before the end of each show.
ezas is offline   Reply With Quote
Old 2010-08-20, 10:03 PM   #4
Hung Like Saddam
Proper Job!
Hung Like Saddam's Avatar
Send a message via MSN to Hung Like Saddam
I've on modded a Qu-Ax saddle by removing some foam, adding softer foam on top and cuttting a channel down the middle. This resulted in not perfect but a vast improvement on the standard saddle.
I also have a nimbus gel and I know what you mean about pressure on the crotch. I have never opened it up to see if it could be modded effectively, try searching to find about mods for the nimbus gel.
__________________
The mountains’ my playground, a place to unwind
Where negative thoughts are left far behind - Terry Peterson
"I'll be racing the clouds home"
Hung Like Saddam is offline   Reply With Quote
Old 2010-08-20, 11:23 PM   #5
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
I've modded my Muni saddle that used to be a Coker Saddle (like the Nimbus High Top) and it's the most comfy seat I have! I tried to cut it like a Freeride and it ended up better than my freeride
I just took a knife and started to cut through my foam.
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Reply
Tags
gel, modification, saddle, velo or nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Nimbus Gel seat for Torker CX Thomasina General Unicycling Discussions 4 2010-08-22 10:10 PM
KH street vs Nimbus gel seats the rickety parrot General Unicycling Discussions 4 2010-04-26 06:59 AM
velo gel saddle xONExLIFEx General Unicycling Discussions 0 2008-08-27 12:41 AM
Velo Saddle nikkifrog General Unicycling Discussions 31 2002-10-21 12:50 AM
Velo saddle anyone? Neil General Unicycling Discussions 18 2002-10-17 11:26 PM
Copyright © 2001-2005 Gilby
Page generated in 0.06181 seconds with 10 queries
