Thread Tools | Search this Thread | Rate Thread | Display Modes |
#16 |
BIG rides: 24"/36" on/off road
Justin, thanks so much for bringing the cycle over last night. Riding it up the hill on my street was the easiest climb of any hill anytime on any unicycle for me. It's a great creation. And it was great to meet you too. See you at U Games this summer!
---Nathan |
#17 | |
Mad Scientist Type?
Quote:
Justin |
#18 | |
Mad Scientist Type?
Quote:
Anyways, the ride experience ended up being pretty much what I was hoping for, in that you could cruise along with the motor giving a huge assist behind the scenes, but not overtly affecting the pedaling and handling experience of the uni. What happens is that you get acclimatized to it, so you can zip along easily up a hill, then let go of the throttle thinking you don't need it anymore and fall flat on your face because you didn't realize just how much the motor was boosting until letting go. The braking was really smooth, but unfortunately just a binary on/off lever rather than proportional control. So down a moderate hill it would peel off about 70-100 watts and put that into the battery and relieve your legs of braking duty, but on a steep hill it wasn't nearly enough regen torque to do it all electronically. But this is something that can be changed easily with a different controller. Also, the throttle control was a lot more touchy and sensitive than you would want on a unicycle, so you had to be careful to ease on the throttle gradually or else the sudden kick from the motor could throw you off. The plan was to play with a capacitive filter on the throttle line which will give a better soft-start to the system, but didn't get a chance to do that yet. Here are a few pictures from the fair. The flat parking lot busy with people wasn't the ideal testing grounds, no hills and not enough room to get it up to full speed, but those who were already familiar with big wheels had no issues: ![]() Corbin ![]() Trevor ![]() Unknown |
#19 |
Registered User
Very Nice!
Will you be traveling anywhere else to put on demonstrations? You could build a motor control circuit that only allows gradual changes to smooth out the transitions. It sounds like that is what you have in mind. I know my Prius has similar controls to keep me from punching the gas and wasting fuel. Scott |
#20 |
Registered User
Justin,by all accounts your power assist uni concept is a success.The mechanical part is working perfectly by the sound of it and you just have to make the control more user friendly.The choices for control electronics is almost endless and I'm sure you probably have the final control circuits already built in your head.Great job,I look forward to more developments.
john
__________________
once I was young and stupid....that was some time ago my videos http://www.youtube.com/user/betterforks |
#21 |
Sam Wakeling
Wow. I started reading this thread thinking that it couldn't possibly work well enough to be useful, but Corbin and Nathan's comments amazed me.
That is a seriously nifty toy. Great work! Next step: shiftable-on-the-fly gearing with handlebar controls and you're in business! ![]() The machined bearing side where the cables show how even a non-electric techno hub could have (multiple) gears controlled by handlebar cable-shifters. Sam
__________________
Unicycle.com |
#22 |
What do you see back there?
Justin-
That is a fantastic project. Great work and congratulations on what appears to be a complete success. Do you happen to have the full specs on the motor you used? I was interested in the complete wiring diagram and the mechanical drawings of the rotor and stator if they're available someplace. I originally thought that you had wound the coils yourself when first looking through the thread (at which time I was stupendously impressed). Did you design any part of the control circuit or modify an existing controller? Soft start features are usually just a simple time constant in the controller somewhere. Again, that is a truly remarkable project. Thanks for sharing this with us.
__________________
-Greg Harper "6 Beers? This is Africa, we have that for lunch, then we clear the lions out of the streets so we can pick up gold nuggets." - GILD |
#23 | ||
Mad Scientist Type?
Quote:
If anyone is coming through Vancouver and wants to give it a try then feel free to give me a heads up! I've been taking it down to our regular wed. evening unicycle meet ups at Science World too. Quote:
The idea for this is that it will have bidirectional torque control, so you can dial in exactly how much torque you want the wheel to produce (forwards or reverse) and the controller will adjust it's output to maintain this torque regardless of your speed. It should be more hands-off that way. Regular ebike controllers are generally implemented with direct PWM control, so you have to keep adjusting the throttle up and down as your speed changes in order to maintain the right amount of power at the wheel. It takes a bit more concentration than is ideal. |
#24 | ||
Mad Scientist Type?
Quote:
http://www.ebikes.ca/store/photos/M2807F26.jpg http://www.ebikes.ca/store/diagrams/M2800F.pdf and you can see the torque, power, and efficiency curves by selecting the NineCont 2807 motor option with the simulator page: http://www.ebikes.ca/simulator/ Quote:
![]() Justin Last edited by Justin LE; 2010-05-28 at 01:47 AM. Reason: Bad Link |
#25 |
Unicycles on my mind...
Nice stator! did you hand wind it? Hey, I think the cranks on your giraffe version were recalled for breaking in '98... eyeball it for stress fractures on the crank arm itself. It was a shimano altus, or the model before it, can't remember.
__________________
Retrofit Disc Brakes to your existing unicycle today! |
#26 |
Mad Scientist Type?
Energy Consumption Stats
So I had a chance to ride the electric unicycle on some round trips here in Vancouver on the weekend, and was surprised at how little net energy it draws from the pack when one rides at just a comfortable pace. That means using the motor on the uphills, and having the motor behave as a brake on the downhills, and riding unassisted and unhindered on the flats.
For the latest trip, which didn't involve any super steep hills but wasn't totally flat either, these are the details: Trip Distance = 9.44 km Max Speed = 23.1 kph Avg Speed = 16.2 kph Positive Amp Hours = 0.496 Ah Regen Amp Hours = -0.238 Ah Net Energy Usage = 1.1 Wh/km By comparison, a regular electric bicycle typically uses 8-10 Wh/km of energy (but also goes at a faster speed). As well, the amount or energy returned to the battery from braking on the downhills was half again what was used on the uphills, while on an ebike this figure is usually around 5-10%. It's not too surprising since on a bike you only use the brakes when you are coming to a stop, while on the uni it was useful on any downhill grade more than about 2%. At that rate at just 1.1 Wh/km, it means that even with this fairly tiny 5Ah battery pack I'd need to go over 160km before depleting it. Crazy. -Justin |
#27 |
Registered User
That is a great set of numbers Justin.What is the weight penalty and do you think a smaller motor would be possible.
john
__________________
#28 | ||
Mad Scientist Type?
Yeah, it's been surprisingly consistent. This evening I rode it from our shop down to the Science World unicycle meetup and back.
Main St. to Science World The way there is pretty much all downhill, and so I only used the brake (no throttle) and put 0.239 amp-hours into the battery. On the way back, I didn't touch the brake and only used the throttle, and consumed 0.458 amp-hours. Averaged 18 kph. Round trip was 7.4 km and the net statistics were again 1.1 Wh/km with the regen energy recovered on the downhill being about half what was used to go back up again. Quote:
Quote:
You could also use an internally geared motor concept and make something lighter still with the same torque, but usually there is a lot drag in that arrangement if the freewheel is locked (as you would need to do regen) and this would make it less fun to ride when you aren't using the assist. Justin |
#29 |
Mad Scientist Type?
Any photos from U games or Muni weekend?
Hey, is there a chance that anyone here has either videos or pictures of the electric uni assist uni being ridden either at the U games or the vancouver muni weekend? If you do and are willing to share, please send me a PM or an email to justin - at - ebikes.ca
It turns out that a camera man from CNN was at the ElectraFest electric vehicle show here in Vancouver on Sunday and wanted to do a small piece on this, and asked if I had any other images or clips. But asides from the original build pictures I don't have very much. Thanks, Justin |
#30 |
muni commuter
From CNN:
Video at: http://ireport.cnn.com/docs/DOC-491972?hpt=C2 iReport — By now we're all familiar with the various forms of electric vehicles, including some bicycles. Taking this to it's logical endpoint, Justin Lemire-Elmore has developed and tested the worlds first electric unicycle. You'd be making a big mistake if you thought this was an attention getting novelty toy because Justin is about to smash several transportation records by being the first person to cross the United States from Canada to Mexico on a unicycle, while using a power source and motor that is not much bigger than your average home electric drill.
__________________
My 29er is my little wheel. Roll it, baby! pLs forgve anu typist imak win positing forum my fone. |
| Tags |
| assist, electric, faire, maker, sat, sunday, unicycle |
Similar Threads
| First day commuting or why I suck at this | underdog | General Unicycling Discussions | 64 | 2010-06-12 05:21 AM |
| Coker group ride this Sunday, 5/23 (LA County beaches) | MuniAddict | General Unicycling Discussions | 2 | 2010-05-21 04:01 AM |
| Muni race in Upstate NY, this Sunday, 2nd May | rolandisimo | General Unicycling Discussions | 6 | 2010-05-11 02:14 AM |
| Becky and Kaori at Portland Juggling Festival | scorpio | Unicycling Videos | 2 | 2009-11-30 05:01 AM |
