Unicyclist Community
Reply
Old 2010-04-21, 11:49 PM   #1
Luderart
Registered User
Luderart's Avatar
Do you use your hands while turning? How?
I was trying to make a u-turn in a diameter of about 3 meters and found that I was having to trace the way I wanted to move with my arms first. Is that the way you do it too? And what is the smallest diameter circle in which you can move or make a u-turn
Luderart is offline   Reply With Quote
Old 2010-04-22, 01:09 AM   #2
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Yah I tend to pint with my arm the way I want to go if I am riding rough terrain or if I was to make a sharp turn. I think it just automatically lines up your upper body to make the turn better.
I sometimes feel myself steering the unicycle with the hand that is on the handle bar as well.
I guess I can do a U-turn in half a revolution if I am going pretty slow. Doing swoopy turns across a street can be fun too.
__________________
saskatchewanian is offline   Reply With Quote
Old 2010-04-22, 01:44 AM   #3
Freak3
life rolls on
Freak3's Avatar
I've been wondering about this, too. Working on uni level two stuff, lol...their "tight 180 degree turn." I don't know how tight they want it to be. Anyone (sorry to thread hijack slightly, but it's kinda on-topic), how do you interpret that?
As for small turns, thus far I've been leaning my whole body over so I'm not quite centered over the uni. I never figured out what to do with my arms for little stuff...But tracing it sounds about accurate to bigger (well, counting 3m as bigger) circles. I think my arms end up in sort of an L shape, one to the center of the circle, one pointing straight in front of me.
__________________
Current uni: Torker LX 24"
Hey, I saved up for it, don't diss it...
Freak3 is offline   Reply With Quote
Old 2010-04-22, 02:40 AM   #4
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
Quote:
Like 10.4.1 Here: http://unicyclingusa.org/levels/
Max_Dingemans is offline   Reply With Quote
Old 2010-04-22, 02:43 AM   #5
Freak3
life rolls on
Freak3's Avatar
Quote:
Originally Posted by Max_Dingemans View Post
Yay, thank you! *bookmarks*
still new to navigating the unicycle worlds of the net.
__________________
Old 2010-04-22, 04:57 AM   #6
juggleaddict
late-night rider
juggleaddict's Avatar
Send a message via AIM to juggleaddict
when I started out, I used my hands a lot to "paddle" my turn. Now I tend to lean into it and pedal through the turn instead, if the turn is super tight and I have on large cranks I tend to do one full rotation at a time with more umphf on the inside pedal to twist the uni. I'm working on smoothing it out.
__________________
Steel is real! => I ride a Nimbus!
juggleaddict is offline   Reply With Quote
Old 2010-04-22, 07:00 PM   #7
blueharmony
Kenny Cason
blueharmony's Avatar
If turning right, reach behind with your right hand and touch the back of your seat. Ditto for the left.
Eventually you won't even think about it but for getting smoothed out this helps most people a lot. Also, for making that u-turn within a 1 meter space pay attention to where your pedals are when you start the turn. Try starting the turn with your "inside" pedal up, then push it down to make the turn. Also try it with the "outside" pedal up...it works differently for different people.
This sequence also helps:
  1. Ride forward
  2. Pause for a micro-second with the pedal "up"
  3. Push the pedal down to make the turn
The key is the pause. This gives you a chance to lean ever so slightly into the turn.
__________________
- Kenny
blueharmony is offline   Reply With Quote
Old 2010-04-22, 07:33 PM   #8
EwokChieftain
rides like an egyptian
EwokChieftain's Avatar
Thank you very much for this post.
Let's see if that advice helps me to outdate my signature
__________________
..:: Wer im Steinhaus sitzt, sollte nicht mit Gläsern werfen ::..
Ergänzung für Keynesianer: Außer bei Nachfrageschwäche.
EwokChieftain is offline   Reply With Quote
Old 2010-04-23, 01:02 AM   #9
1wheelwill
Registered User
Thanks for the tips Bluearmony. I can make a fairly reliable 90 degree turn to the left, but to the right even a more wide turn often results in wobbling and a series of "scallop" turns. I'm hopeful that the seat grab technique will help me get my position correct for the turns.
1wheelwill is offline   Reply With Quote
Old 2010-04-23, 01:37 AM   #10
Boethius
6th century one wheeler
Boethius's Avatar
As you are making use of the Search feature that is highly valued here, type in "counter steer". There are some old posts that are good reads.
Boethius is offline   Reply With Quote
Old 2010-04-23, 06:13 AM   #11
johnfoss
North Shore ridin'
johnfoss's Avatar
"Sushi in my left hand, cell phone in my right." -- paraphrased from David Stone, commuting through New York City
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Reply
Tags
arms, circle, diameter, hands, turning, u-turn
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How do you define atheism? Where do you draw the line? phlegm Just Conversation & Introduce Yourself 88 2010-04-04 07:24 AM
What Camcorder do you use? that is under $300 aidanteleki General Unicycling Discussions 27 2010-03-30 10:37 PM
Forum Moderators: What do you do? How often? BillyTheMountain Just Conversation & Introduce Yourself 11 2010-03-15 03:49 AM
What is the heaviest thing you've ever carried while riding your Uni? kb1jki General Unicycling Discussions 42 2010-03-15 02:33 AM
how do you you pedal grab torkerdx2010 General Unicycling Discussions 0 2009-11-07 02:21 AM
Copyright © 2001-2005 Gilby
Page generated in 0.07944 seconds with 10 queries
