Unicyclist Community
Reply
Old 2010-04-21, 06:36 AM   #1
Sponge
ゴールデン!
Question Seats for trials: Impact Naomi vs KH Street 2010
Hola hola,
I'm stuck between the two. The only reason I'd lean towards the Naomi is the super super thin stock version it comes in. Other than that I prefer the KHU cover and the KH street is cheaper.
I once ran a 2006 original first release Fusion Street KH saddle... can anyone compare the 2010 updates to the first version so I get a clearer idea? What is the current foam like? Any other decent upgrades? I disliked how chunky the 2006 Fusion street foam was and the shape wasn't that comfy to hold.
If anyone can, please post up some close-ups detailing either your Naomi seat or KH 2010 Street saddle! I'd like to see how thick each foam is and the other features like underside for example. I can't view Flickr, Imageshack, Photobucket... so can you put them on this forum gallery please?
Cheers!
Contributors, if any of you are in England or visiting England any time this year later... I'll give you an Echo seatclamp of your colour choice (14 or so clean anodized colours!)
Sponge is offline   Reply With Quote
Old 2010-04-21, 07:07 AM   #2
TheJoker
Epic Downhiller.
TheJoker's Avatar
yesYesYES!!!!!!! Naomi!
light, comfortable, good looking.
__________________
Long Jump: 150cm
High Jump: 70cm
TheJoker = the most patriotic person on the forums.
-SirSkillz
TheJoker is offline   Reply With Quote
Old 2010-04-21, 07:26 AM   #3
Andrew Mell
Registered User
Andrew Mell's Avatar
2010 KH street saddle is terrible in my opinion.
i absolutely hated it. i now use the KH08 foam on a CF base with 10 cover.
works well.
my main problem with the 2010 saddle was the thickness of the foam, and the
deep cut away in the back of the saddle.
hope this helps.
Andrew Mell is offline   Reply With Quote
Old 2010-04-21, 07:36 AM   #4
Sponge
ゴールデン!
Cheers Andrew, I'm looking for some criticism of either to draw out the hidden weaknesses.
Can you share some more info and detail on why it's 'bad'? I'd like to know more about the foam. Is it the main thing that makes the 2010 seat not so good?
Old 2010-04-21, 09:26 AM   #5
OUK
An)-On Juncher
OUK's Avatar
I'm ridin' a custom saddle.. I've cutted down my Black Zebra and putted a KH cover on it and it's awesome to ride with!! But if you aren't going to do anything to you saddle I would say an Impact would be best..! I doesn't like the KH '10 saddle because it's too thick for me, but if you're putting Carbon base and cut it down it's AWESOME (much better than Impact in me upponion)
__________________
~An)-On
Ethjulet Cykel - UDC Denmark
Danish Trial Team
I ride one wheel cus it's way more sustainable than riding two!
OUK is offline   Reply With Quote
Old 2010-04-21, 10:09 AM   #6
Spencer Hochberg
Send a message via AIM to Spencer Hochberg Send a message via MSN to Spencer Hochberg
The Impact seat has the same "old" velo base that the k1, quax, old kh, old nimbus, etc have.
Since 09 the KH seats have had a redesigned base. The base is quite a bit stiffer and is a slightly different shape. The main difference I've noticed is that it feels more like the shape of my scott wallis CF base. The new KH base is much deeper underneath, so your fingers can wrap around the lip more securely. This could be good or bad depending on how you hold the seat. When I lift the uni, I curl my fingers around the side almost like making a fist, so the new base feels better to me in that way. If you hold your seat more like a sandwich then you might have a different opinion.
As far as the foam goes, its definitely preference. The impact is pretty minimalist and the KH has quite a bit more volume to it. When I ride my 2010KH seat I don't feel like it's huge and my grip is still pretty good. The KH foam also has a channel cut away through the center. So depending how you grip your seat it could be comfortable to rest your thumb inside.
Spencer Hochberg is offline   Reply With Quote
Old 2010-04-24, 09:07 AM   #7
brendan
Unicycling = trials
brendan's Avatar
I have a carbon base (udc) with a Naomi foam and kh cover since late summer 09. I used to have the the street foam with the same setup. the Naomi is great for trials. holding it sif is great. its very stiff and curves more than the kh street. its impossibly uncomfortable. I'm not sure I'd recommend it. great for pure trials but it gets to the point where I walk from spot to spot. if you want I can send you photos of both setups on Monday. I have the oh foam on a plastic base with a kh fusion cover.
I think I would prefer the koxx thin foams.
And my fusion foam is the 08 model with the gel insert.
__________________
I'm a soldja.
brendan is offline   Reply With Quote
Old 2010-04-24, 09:10 AM   #8
Sponge
ゴールデン!
yeah that'd be great thanks!
Old 2010-04-24, 01:21 PM   #9
Isaac Conyers
unicycle.com.au
Isaac Conyers's Avatar
Send a message via MSN to Isaac Conyers
i hav both. naomi is ultra thin and quite comfortable too. kh however does hav a much better base. the solution to this decision: get a naomi with a cf base. done
edit: comfort of naomi is personal preference but ive even heard of coker riders saying how nice it is
__________________
TEAM DIRTY NEEDLEZ!!!
Isaac Conyers is offline   Reply With Quote
Old 2010-04-24, 01:33 PM   #10
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
What do you want to use it for?
The Naomi is the best long distance road/Muni saddle out there.
I've been cutting down the KH Saddles for years, and they are still at least two or three times thicker than they need to be. Low profile=increased comfort.
There are a couple of minor drawbacks with the Naomi- you won't be able to fit a KH T-Bar on it easily, and it needs a narrower profile seatpost clamp as the bigger ones is hard to clamp on.
Ken
GizmoDuck is offline   Reply With Quote
Old 2010-04-24, 04:11 PM   #11
maximus unius
Registered User
maximus unius's Avatar
I have a KH 2010 street, and last weekend I got a chance to try the Impact saddle for a couple minutes.
The KH foam is a little too thick for me, but I don't want to cut it down because I like the cutaway in the center. The base is also a really nice shape and seems stiffer than my old Velo base. The allen head bolts are also a plus.
The Impact saddle was nice too and would be really great for trials since it's so thin. That's the advantage it has over the KH, but the KH also has really nice features like I mentioned.
Tomorrow I may have a chance to take some pictures of both. If I do I'll put them up here.
maximus unius is offline   Reply With Quote
Old 2010-04-24, 08:21 PM   #12
Naomi
Stupid Asian tart riding that thing
Naomi's Avatar
I may well be all three of those, but let me assure you. I am not available for sitting on, no matter what the distance.
Nao
__________________
The dress in which I unicycled was not THAT short, but in retrospect, I think that maybe the blue one would have been more appropriate to the terrain.
Naomi is offline   Reply With Quote
Old 2010-04-24, 08:44 PM   #13
siafirede
Flex Your Head
siafirede's Avatar
Quote:
Ken
What handle are you running on the Naomi?
__________________
-James
siafirede is offline   Reply With Quote
Old 2010-04-25, 02:24 AM   #14
GizmoDuck
GizmoDuck's Avatar
Quote:
Just the standard plastic ones that come with it. It would be nice to swap it over to something like the KH T-Bar though
Old 2010-04-25, 06:51 AM   #15
juggleaddict
late-night rider
juggleaddict's Avatar
Send a message via AIM to juggleaddict
would someone mind posting some more detailed pics of the naomi saddle? (different angles and such) I'm looking at getting one for distance. I've seen some pictures that kinda looks like it has a small trench in it like the kh, but I can't tell for sure. Hopefully this will be the saddle will be good for touring multiple days in a row. The only thing I'm worried about is it not being flat enough front to back, I don't like the nose of it to bend too far up.
__________________
Steel is real! => I ride a Nimbus!
juggleaddict is offline   Reply With Quote
Reply
Tags
2010, impact, naomi, seats, street, trials
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
KH Trials vs Nimbus Trials iAmVincent General Unicycling Discussions 52 2010-05-04 10:45 AM
KH street vs Nimbus gel seats the rickety parrot General Unicycling Discussions 4 2010-04-26 06:59 AM
KH models 2009 vs 2010 - which to buy? unikas General Unicycling Discussions 9 2010-04-02 05:13 PM
IMPACT vs KH catch1 General Unicycling Discussions 21 2010-03-03 03:09 PM
Saddle weights KH '08 vs KH '09 vs CF base rob.northcott General Unicycling Discussions 4 2010-01-15 03:49 PM
Copyright © 2001-2005 Gilby
Page generated in 0.09097 seconds with 10 queries
