Unicyclist Community
Reply
Old 2010-09-21, 08:12 AM   #46
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
Quote:
Originally Posted by muniing sam View Post
I wonder why not regular bicycles
People Tearing their shins open? I wonder why not unicycles. Sure, they're not going to hold up to pedal grabs, but I can't see them failing on a coker.
Max_Dingemans is online now   Reply With Quote
Old 2010-09-21, 10:46 AM   #47
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
Its interesting how they now say "Additional Information
Not suitable for use on 'normal' bicycles or unicycles." http://tartybikes.co.uk/product.php?...category_id=23 I wonder why not regular bicycles
That is a bit freaky - they're working fine on my muni (after swapping a few pins to get more grip). They're probably just worried about people getting nasty pedal bites and then moaning - DMR pinned pedals come with a warning saying "competition use only".
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski)
"I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule)
rob.northcott is offline   Reply With Quote
Old 2010-09-21, 03:22 PM   #48
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
I'm using my Echo's on my Muni too now, I used them on my trials for like 2 week and I bent the body on a pedal grab. I'd like to have Echo pins on my Trials though, I need more grip on my pedals.
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2010-09-22, 05:44 PM   #49
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Quote:
Rob
So did you put in longer pins? Where'd you get the pins and how much $?
(every pedal I've tried needed to do likewise to get sufficient grip for me)
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2010-09-23, 09:56 AM   #50
rob.northcott
Mainly XC Muni
I just swapped the four corner pins for plain grub screws like in DMR or Wellgo pedals. They're no longer, but have a sharper top (the Echo ones are very nicely made but are much less sharp - almost rounded edges). Didn't cost me anything because I had a load of them lying around, but they're the same as the ones used as pins in other pedals so you could salvage some from a dead pair of pedals, or buy a pack of DMR replacement pins. They're cheaper if you just buy them from a hardware shop (have to check the thread - I'd guess they're M4).
Because the holes for the pins go all the way through the pedal body on the Echos, you can't do plain grub screws up tight and need to fix them in with something to stop them unscrewing. I did mine with threadlock, but that wasn't enough. They're superglued now.
BTW - I think what we call "grub screws" are known as "set screws" in the USA. Causes all sorts of confusion because a "set screw" here is the same as a bolt (i.e. with a head), but with the thread all the way up the shaft (a bolt has a plain shaft with thread only at the end). Anyway, what you want is the things that have no head - you've probably seen them on other pedals anyway.
Rob
__________________
Old 2010-09-23, 10:40 AM   #51
redwelly
Sam Wakeling
redwelly's Avatar
Rob
I wonder why they don't use grub screws already. Wouldn't they be lighter than the ones with the external hex flange? It might save 10g or something, and as they are meant to be pimpy light pedals, that would seem useful.
Sam
__________________
Unicycle.com
redwelly is offline   Reply With Quote
Old 2010-09-23, 11:18 AM   #52
rob.northcott
Mainly XC Muni
Quote:
Sam
I think the idea is that the Echo design is better for people who mash their pedal pins against things (trials and street riders). The flange gives a more stable attachment to avoid them getting ripped out, and they don't rely on the allen key hole for removal so are easier to replace when smashed up. Makes no difference to me as a muni/xc rider, so I'm happy with plain screws. The Echo pins are actually very nice, just not as sharp as I'm used to.
Rob
__________________
Old 2010-09-23, 01:47 PM   #53
unicyclerman
jarin erickson
unicyclerman's Avatar
Send a message via AIM to unicyclerman Send a message via MSN to unicyclerman
i just got some blue TR pedals. there sick. and probably the lightest pedal out there for under 80 bucks. ive heard about people breaking the SLs with the Ti spindle so im not so sure about those. i think joe H and mike padial are riding the TRs as well.
if your looking to get some in the US get them from HBtrials.com there located in canada but i got mine within a week.
__________________
WWW.EBUNICYCLES.COM top end uni parts.
street carbon frames now $400
unicyclerman is offline   Reply With Quote
Old 2010-09-24, 04:22 AM   #54
erick
Registered User
erick's Avatar
Thanks for the website, I was looking for somewhere I could get these pedals, I bet they're awesome. They don't have blue in stock anymore
__________________
erick is offline   Reply With Quote
Reply
Tags
2010, components, echo, make, save, stand, uni, weight
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How to save weight when uni'n [pic] AccordNSX General Unicycling Discussions 1 2003-01-12 03:00 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07689 seconds with 10 queries
