#1351 |
jelle G
this video is from jelle and jelle G
http://www.youtube.com/watch?v=0hwqq...ature=youtu.be Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Due at 23:59 in your time zone on Jan 3. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Trick 4: will be set on Jan 12 O U _ Jakob O U _ Trevor _ _ _ Tom* _ _ _ Jelle _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O _ _ An)-On O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G O _ _ UniPsyco O _ _ Vince O U _ Kropivsek Visuals |
#1352 |
slc uni
Mark yourself as landed, or everyone will forget that you did. Which of you is going to set next? Is it Jelle, since he was the first in the clip?
Markus - is there any limit on the width of the skinny? A couple of games ago people were claiming some pretty wide things as "skinnies". It's up to you. Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: will be set on Jan 12 by Jelle. O U _ Trevor _ _ _ Tom* _ _ _ Jelle (landed) _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O _ _ An)-On O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G (landed) O _ _ UniPsyco O _ _ Vince O U _ Kropivsek Visuals O U T Jakob |
#1353 |
Registered User
I'll set the next trick
Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: will be set on Jan 12 by Jelle. O U _ Trevor _ _ _ Tom* _ _ _ Jelle (landed) _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O _ _ An)-On O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G (landed) O _ _ UniPsyco O _ _ Vince O U _ Kropivsek Visuals |
#1354 |
An)-On Juncher
O U _ Trevor
_ _ _ Tom* _ _ _ Jelle (landed) _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G (landed) O _ _ UniPsyco O _ _ Vince O U _ Kropivsek Visuals O U T An)-On Tricks are betting too boring, so count me out
__________________
~An)-On Ethjulet Cykel - UDC Denmark Danish Trial Team I ride one wheel cus it's way more sustainable than riding two!
#1355 |
Registered User
Skinny must be thinner than tire.
#1356 |
Registered User
I'll set the next trick Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: will be set on Jan 12 by Jelle. O U _ Trevor _ _ _ Tom* _ _ _ Jelle (landed) _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G (landed) O _ _ UniPsyco O _ _ Vince (landed) O U _ Kropivsek Visuals |
#1357 |
slc uni
Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: will be set on Jan 12 by Jelle. O U _ Trevor _ _ _ Tom* (landed) _ _ _ Jelle (landed) _ _ _ markus*(set) O U _ TimoG _ _ _ Gila* O U _ Moth _ _ _ jesperb52 _ _ _ Jelle G (landed) O _ _ UniPsyco O _ _ Vince (landed) O U _ Kropivsek Visuals |
#1358 |
Registered User
I'll film something tomorrow, everything was weth, so I couldn't today
#1359 |
Registered User
I filmed it I upload it in 30 minutes
#1360 |
Registered User
http://www.youtube.com/watch?v=65dJK...ature=youtu.be
gap 96cm up from skinnie (43cm high) to skinnie (90cm high) max skinnie width=10cm, if someone can formulate it better just do it! ![]() Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: gap (96cm) up (47 cm) from skinnie (43cm high) to skinnie (90cm high), set by jelle Trick 5: set by ? _ _ _ Tom* _ _ _ Jelle* (set) _ _ _ markus* O _ _ Gila* O _ _ jesperb52 _ _ _ Jelle G O U _ UniPsyco O _ _ Vince O U T Trevor O U T Kropivsek Visuals O U T Moth O U T TimoG Is the list correct? |
#1361 |
slc uni
The list looks fine. I'm assuming someone else will land this before the deadline, but if no one does, then Jelle G would set next.
Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus Trick 4: gap (96cm) up (47 cm) from skinny (43cm high) to skinny (90cm high), set by jelle, due at 23:59 in your time zone on Jan 20 Trick 5: set by ? on Jan 21 _ _ _ Tom* (landed) _ _ _ Jelle* (set) _ _ _ markus* O _ _ Gila* O _ _ jesperb52 _ _ _ Jelle G O U _ UniPsyco O _ _ Vince Last edited by tmoyer; 2012-01-16 at 07:29 PM. |
#1362 |
Registered User
here is mine
http://vimeo.com/35272762 Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus Trick 4: gap (96cm) up (47 cm) from skinny (43cm high) to skinny (90cm high), set by jelle, due at 23:59 in your time zone on Jan 20 Trick 5: set by ? on Jan 21 _ _ _ Tom* (landed) _ _ _ Jelle* (set) _ _ _ markus*(landed) O _ _ Gila* O _ _ jesperb52 _ _ _ Jelle G O U _ UniPsyco O _ _ Vince |
#1363 |
slc uni
Last day to land this. If no one else lands it, then Jelle G sets next.
#1364 |
jelle G
The new trick : pedalgrab (75) on skinny (max widdth 10 cm) Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: gap (96cm) up (47 cm) from skinnie (43cm high) to skinnie (90cm high) Trick 5 : pedalgrab (75cm) on skinny (max width 10 cm ) Trick 6 : set by ? _ _ _ Tom* _ _ _ Jelle* (landed) _ _ _ markus* O U _ Gila* OU_ _ jesperb52 O _ _ Jelle G* (set) O U _ Vince O U _ UniPsyco OUT Is the list correct? |
#1365 |
Registered User
thats mine: http://vimeo.com/35463439
@jelle g: the list is ok Trick 1: one rev on skinny (10cm max width) to 45cm forward hop, set by Gila. Trick 2: 45 cm drop to skinny and one rev on skinny, set by Tom. Trick 3: one rev on skinny, then one rev on skinny backwards, set by markus. Due at 23:59 in your time zone on Jan 11. Trick 4: gap (96cm) up (47 cm) from skinnie (43cm high) to skinnie (90cm high) Trick 5 : pedalgrab (75cm) on skinny (max width 10 cm ) Trick 6 : set by ? _ _ _ Tom* _ _ _ Jelle* (landed) _ _ _ markus*(landed) O U _ Gila* OU_ _ jesperb52 O _ _ Jelle G* (set) O U _ Vince |
| Tags |
| beginner or intermediate, best out the gamer ever, game, otg, out the game, sambohdee, trials |
Similar Threads
| **OUT the Game Flat** Beginner/Intermediate | Julia B | Challenge Each Other | 1275 | 2012-09-23 12:49 AM |
| * Out the Game * | Matti M | Challenge Each Other | 132 | 2011-07-24 10:53 AM |
| *Out The Game - Freestyle* | SamGoodburn | Challenge Each Other | 153 | 2011-04-04 10:42 PM |
| **OUT of the game Flat** Super Beginner | Pimpinpete | Challenge Each Other | 446 | 2010-08-31 03:15 AM |
| ++FLIPS++ Out The Game | Emile.m | Challenge Each Other | 109 | 2009-12-23 08:02 PM |
