Unicyclist Community
Reply
Old 2012-07-06, 11:10 PM   #1006
munirocks
money rocks too
munirocks's Avatar
There might be some triples with 163/145/127 or a little less coming. I'm going to wait and see if it happens before ordering anything else.
I'm quite happy with 140mm Tensiles on both the G26 and G36 but I would love the triple option.
__________________
µ-knee
munirocks is offline   Reply With Quote
Old 2012-07-06, 11:21 PM   #1007
danger_uni
Kris Holm
Not from KHU in the near term, if that's what you're thinking about, and it may not happen at all because so few riders (this forum notwithstanding) really want this in quantity. Even if it did, it would likely not be within a year. So it would be better to drill out existing cranks, for anyone wanting this quicker.
danger_uni is offline   Reply With Quote
Old 2012-07-06, 11:31 PM   #1008
munirocks
money rocks too
munirocks's Avatar
Well, that's what I was hoping for. The thing is there is no Spirit crank that would allow for drilling a hole between 150 and 137mm unfortunately. 150 would be OK for most things, but really what I'm looking for the most is something halfway in between 165 and 150 for steep guni and around 140 for normal conditions both on the G26 and G36. The length of less than 137 wouldn't be that interesting for geared riding IMHO. So maybe a dual 160/142 crank would be perfect.
__________________
µ-knee
Old 2012-07-06, 11:37 PM   #1009
danger_uni
Kris Holm
I won't completely say never, but currently, I unfortunately can't see that length combination happening. Already there are so many models, and ultimately the divisions get too fine. The current lengths are pretty carefully picked to span the range for most riders. Sorry about that =(
Kris
Old 2012-07-06, 11:44 PM   #1010
munirocks
money rocks too
munirocks's Avatar
So Kris, do you run 150/127 on your geared 26er or 165/137? Any thoughts about it? I used to have the dual 150/125 Moments on my 26er but I didn't like the 125mm setting much and 150 seemed a little too much for most conditions.
For me 140 (maybe a little more) seems like a great all-round length but for steep uphill something longer around 160 would be useful.
__________________
µ-knee
Old 2012-07-07, 12:00 AM   #1011
danger_uni
Kris Holm
I use 150 mm on my G26, currently. If I lived somewhere with smoother trails I might well switch to 137. In first gear, I'd never personally want longer than 150.
Kris
Old 2012-07-07, 12:15 AM   #1012
munirocks
money rocks too
munirocks's Avatar
Thanks, I'll think about it some more. Maybe 165/137 will be okay but it seems to be too long and too short while 150 would be longer than necessary for the DH and the flat high gear riding. Got to get some sleep now.
__________________
µ-knee
Old 2012-07-07, 02:40 PM   #1013
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Quote:
Originally Posted by danger_uni View Post
Ideally, the KH/Schlumpf hub should have a solid crank stop between the bearing and crank. Because it doesn't, there's the potential for variability in the crank position. Because the ISIS spline has a 1 degree taper, simple trigonometry means that the slightest variation in spline diameter has a discernable effect on lateral crank position.
Here are pictures of 137mm Spirit cranks on my geared 36er. The right crank looks good (plenty of clearance just like the 150mm Moment crank it replaced) but the left Spirit crank is much closer (not rubbing, but less than a credit card's width of clearance). I don't see this posing a problem unless it creeps in down the road.
First time using my torque wrenches I've set the crank (using an Extra Long Bolt to "set" it) at 40Nm and the bearing housings at 5 Nm.
I used my Wiha factory preset torque screwdriver to reinstall the buttons and they do have a little bit of play underneath. By mistake, I totally "removed" instead of just "loosening" the tiny bolt (I think Florian calls it the M1 bolt) from inside of the first button that I removed but I quickly but it back in. Now I get the concept of "loosen" the bolt just enough so you can unscrew the button. Putting the buttons back on I had to deepen the insertion of the M1 bolt to get the button "pushed in" flush with the crank. I would assume this (the M1 bolt) is how one would go about creating more play underneath a "pushed in" button.
Took it out for a test ride today and I'm happy to report that (moving from 150mm Moment to 137mm Spirit) the heal of my size 10 FiveTen shoes can finally reach the shifting button without needing to ride on my toes though an accidental shift is now a distinct possibility. The Spirit has a nice angle just above the button whereas the Moment was square. Shifting is a breeze! Now, all I have to do is master high gear with shorter cranks. Thanks Kris! Good stuff!
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is offline   Reply With Quote
Old 2012-07-07, 07:04 PM   #1014
Tucson Uni
Andy
Tucson Uni's Avatar
Quote:
Hey David, I am probably going to upgrade my 36 guni too. I too have been riding 150s and thinking about switching to 137s. Giving it a try with some 137 Moments I have before buying new Spirit cranks (and a disc brake). Yes, much easier to shift (but a little worried about accidental shifts).
I am also thinking of getting the Slim saddle (or maybe a Street saddle). How do you like the Slim?
__________________
http://www.tucsonuni.com
Tucson Uni is offline   Reply With Quote
Old 2012-07-07, 08:55 PM   #1015
Nurse Ben
XC Muni
Nurse Ben's Avatar
There is of course a lot of differing opinions on crank length, but as I have gradually increased in wheel size and tire width, I find a longer crank helps generate the extra leverage to propel the unicycle. This all for off road, muni:
For a 26er, guni or fixed, I found 137's were fine for XC, but 150's were better if there was a lot of steep climbs, 165's would be too long for anytng but the steepest muni/DH, though I rode with a set up like that when I was learning.
For a 29er I have run as short as 137's for XC, but 150's were better for all around, though for the kind of riding I do (rocky, rooty, teep ups and downs) I have since gone to 165/137.
For my 36er muni I am currently running 175's trials cranks which work amazingly well, but I started with 165 Moments, then transitioned to 170 QuAx Chromoly Street Cranks, before going to the Try All trials cranks. I just found some old stock Truvativ Luftalarm 180mm ISIS Jump Bike Cranks
I find that long cranks on a big wheel spin as well as shorter cranks onn a smaller wheel, at that's the sensation, so for me the 36er with 175's spins very similar to a 29er with 150's.
__________________
I dream of hamsters and elderberries
Nurse Ben is offline   Reply With Quote
Old 2012-07-07, 09:25 PM   #1016
MuniAddict
Not "2" Tired
MuniAddict's Avatar
I prefer 110/125's for 29er MUni, and 125/150 for G26er-ing. For extreme technical I still ride my 24 with 150's for the added control doing 6+ foot drops and navigating through rock gardens.
Hiker: That's badass dude!
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2012-07-07, 09:28 PM   #1017
DavidHood
DavidHood's Avatar
Quote:
I've heard good things about the Street. That is what Kris recommends for distance touring. Not too much to the Slim (very thin, much less padding) in comparison to the Freeride saddles on my MUni's. Then again, padding is the enemy after so many miles. I might steer you into the direction of the Street so you get the new (for June of 2012) leather seat cover though the mesh cover on my Slim does a much better job of utilizing the relief channel. And that, is what is really important after long periods in the saddle.
Quote:
I would need a thumb shifter mounted on the handlebar with 180's.
Old 2012-07-07, 10:32 PM   #1018
Tucson Uni
Andy
Tucson Uni's Avatar
I ride 150s for almost everything - 24 DH, 24 guni, 36 guni, 29er. Anything longer than 150 would be too hard to shift gears with. I tried 125 on my 24 guni. It was doable, but too easy to shift and too hard on the rough stuff. I ride my 36 guni primarily on pavement with some excursions on easy off-road. I am pretty happy with 150s, but want to give 137s a try for easier shifting (hopefully not TOO easy), and faster speed (maybe a good idea or maybe not).
__________________
Old 2012-07-07, 11:45 PM   #1019
knoxuni
wes style!!
knoxuni's Avatar
Send a message via Skype™ to knoxuni
would a more rounded area around the shiftier button make it easier to shift?
__________________
Be a dumbass
experience dumbass consequences
its full circle of dumbass
And then, do it again. That makes it an infinite loop!
knoxuni is offline   Reply With Quote
Old 2012-07-07, 11:48 PM   #1020
Nurse Ben
XC Muni
Nurse Ben's Avatar
Now I understand why your 26er gets more trail time, those cranks are way to short for 29er muni! Minimum for managing that big wheel is 137's and even then there are lots of unclimbable hills, 150's create a nice balance without being wonky, but for real power you need a long crank which is why I run a 137/165.
Terry, are you still riding a 36er off road?
No, you don't want it too easy or too hard, works fine as it is, but a remote shifter mounted on the grab handle would rock!
__________________
Reply
Tags
discussion, general, hubs, mumpitz, schlumpf
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Schlumpf hub setup discussion thread steveyo General Unicycling Discussions 153 2011-11-20 11:13 AM
New Forum for General Discussion bcmate2008 Requests, Questions, and Bugs on this site 1 2008-10-29 10:03 PM
Discussion Threads Discussion Thread unifreak7 General Unicycling Discussions 21 2008-07-25 07:56 AM
Kris Holm Schlumpf Muni Hub vs Schlumpf Road Hub osmundo General Unicycling Discussions 5 2008-03-19 03:42 PM
Coker, Schlumpf 29er, or Schlumpf 36er siafirede General Unicycling Discussions 9 2005-11-11 11:37 PM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.10594 seconds with 11 queries
