#61 |
Seniorenklasse!
yes it happens, at least it did for me, not just once, several times... that's why on don't ride a schlumpf at the moment on my 26" (for a time i took the caps out and shifted gear bay hand...) an other reason was the weight, because i do alot of hiking in my muniing... ...but it looks like i'm going back to a schlumpf on the 26er...
__________________
If everything's under control, you're going too slow I trust in those: Triton Mountainuni Brake System Schlumpf |
#62 |
reads trails rather than books
Am I right if I assume that UPDs because of shifting by accident can be quite nasty? Another reason for wearing my protection gear
__________________
Beschleunigungen werden in m/s^2 gemessen. m^2/s gibt vielleicht die Arbeitsgeschwindigkeit eines Fließenlegers an, aber sicher keine Beschleunigung. (Yeti) |
#63 |
Seniorenklasse!
i'm not sure, but mostly when i shifted by accident it was from low to high gear, when it was really technical, with hopping, so it wasn't that nasty (means not in highspeed, but maybe nasty because of the unfriedly upd-terrain... if you know what i mean
), and it kinda shocked me everytime, because i wasn't ready for that...
__________________
#64 |
Yes, I know what you mean
What I was thinking about was the half rev (or how long does the shifting process last?) you are coasting after shifting. Isn't that an issue when you have a lot of pressure on the pedals?
__________________
#65 |
Igloo ceiling
I've had two unintended shiftings in the two years I've had my Schlumpf. Both from low gear to high, and both with 165mm cranks. On the first one I was just riding down the street at a very modest speed and my heel hit the button just right. There was a fair amount of slop in the gears on that shift so I landed flat on my butt. Fortunately, I had my backpack on with my laptop in it. So my computer protected my valuable equipment (my butt) from serious damage.
![]() On the second event I was riding pretty fast through town when I accidentally shifted into high gear. There was virtually no slop in that shift and I seemlessly shifted into high gear and kept riding. Woo Hoo! What a feeling! Geoff
__________________
monocycle monstrosity ![]() Mustn't sleep! Clowns will eat me! |
#66 |
money rocks too
A couple of things I have come across with my Schlumpfs:
- Serious mud can be problematic because it fills up the little screw in the shifter buttons. The dirt has to be taken out of there before any adjustments are tried on the screws. - Accidental shifts haven't happened often but I think they are more likely to occur in technical terrain, which is where they are the most unpleasant... - Sometimes the shifting happens at an unexpected time, quite a bit later than initiated, which can lead to UPDs. This is usually when shifting up. - On my now retired 26er hub (waiting forever for the replacement) I noticed that sometimes when I did small drops (in low gear) the cranks would slip one slot further or something like that. I haven't ever heard of anyone else who experienced that, though. - The 150mm cranks are fine for most of my rides but I am thinking about getting some 165s for steeper climbs. Accidental shifts would be pretty much impossible on those too, I guess, especially with not so large feet.
__________________
µ-knee |
#67 | |
Flex Your Head
Quote:
Shifting is very easy for me now. Your pedal choice and your shoe choice will also affect how easy/hard shifting is.
__________________
-James |
#68 | |
always slightly damaged
Quote:
I guess that you don't want to shift in rough terrain, usually you will stay in low gear and use the high gear only on nice surfaces where you can go fast. I suggest you simply try it. You will need to make your own experience and simply get used to the way how it works. |
#69 | ||
Quote:
![]() Quote:
__________________
#70 |
But there's no guarantee for that. If you just release the pressure for a moment, to balance or whatever, it will shift.
#71 |
If it gets a bit more technical or for riding single trails I will wear my fullface helmet. I will have to deal with that if it happens
__________________
#72 |
Hartman Rocks, Uncompahgre beyond..
As best I can recall I've only had a few accidental shifts. Like everybody else it was from low to high gear. Most often its because I'm concentrating while I'm riding rough terrain and my feet and ankle tend to "cheat" closure towards the cranks as I ride. I guess they move in enough that the side of my shoe begins to rub against the shift button and "pop" gear change! Typically no problem, it's just another UPD. And as its' from low-to-high I'm not going very fast anyhow...
I've had the opposite problem as well; not being able to shift into high gear. It is important to check your equipment periodically (if don't already). I was trying to shift up on the fly and I could tell the shift rod was moving but the high gear refused to engage! Turns out the frame bearing clamps on the knurled side of the hub were a tad loose so the high gear couldn't engage! It was a subtle thing as the wheel didn't feel loose in the frame. Riding in high-gear I've never had a accidental down shift (now that could be dangerous).
__________________
munisano |
#73 |
__________________
munisano |
#74 | |
Quote:
Unfortunately a torque wrench that starts at 2 or 3 Nm is quite expensive
| Tags |
| discussion, general, hubs, mumpitz, schlumpf |
Similar Threads
| Schlumpf hub setup discussion thread | steveyo | General Unicycling Discussions | 153 | 2011-11-20 11:13 AM |
| New Forum for General Discussion | bcmate2008 | Requests, Questions, and Bugs on this site | 1 | 2008-10-29 10:03 PM |
| Discussion Threads Discussion Thread | unifreak7 | General Unicycling Discussions | 21 | 2008-07-25 07:56 AM |
| Kris Holm Schlumpf Muni Hub vs Schlumpf Road Hub | osmundo | General Unicycling Discussions | 5 | 2008-03-19 03:42 PM |
| Coker, Schlumpf 29er, or Schlumpf 36er | siafirede | General Unicycling Discussions | 9 | 2005-11-11 11:37 PM |
