Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
What gears would you like on a 29er or 36er?
If you could choose any gear ratio for your geared 29er or 36er, what would it be? And why?
Many people are thrilled by their Schlumpf offering 1:1.5. Is this enough or would you prefer more choices? |
#2 |
Registered User
A 1:2 for the 29er would be awesome, or like 1:2.5.
Lighter, more rim/ tyre combo's. If somebody made a strong isis hub, worked on any frame pretty much, had 1:2 I would get one for sure. Take me a while to get the cash, but yes, the more options the better. Last edited by wickedbob; 2009-05-12 at 02:58 AM. |
#3 |
Sometime one-wheeler
I want a hub with 1:1, 1.5, 2, 2.5.
While cranking up an incline on the 36 last weekend, I kinda wanted 1:0.5 or something, but I'm not really sure it'd be worth it. Maybe. So yeah, I'll take a hub with all of those, please. When can I expect delivery? Why limit myself to just 2 speeds?
#4 |
GranPa goes-a-wobblin'
O.7 ; 1. ; 1.5
I am not sure about the 0.7 but I want something to help me climb inclines ... so need to experiment; not sure either of the 1.5 I don't really need big speed but I spin slowly. Ideal would be a CVT : I will accept some loss but I think the way to go is CVT with smooth rollers ....
__________________
One Wheel : bear necessity |
#5 |
Totally Doable
On the 29er, if I had just two gears I would like to see them at 1:1.3 and 1:1.8 or something like that. You'd have a low gear that's a little bigger than a Coker, and a high gear that 's bigger than a geared Coker, without all that rotating weight. 1:1 on a 29er is only really useful for MUni and extremely steep hills (>10% grade).
#6 |
Registered User
Interesting replies - interesting that one suggestion is to gear a 29er to mimic a geared 36er.
Does this imply that a Schlumpf geared 36er is an ideal set-up? |
#7 |
10k & Marathon World Champ
In gearing, it is pretty close to right, but it is very heavy, which is why a 1.3/1.8 29er would be nice.
#8 | |
Totally Doable
Quote:
Really ideal would be about a five-speed, 29/36/44/54/70 or 36/44/54/70/90 or something, with a 29er wheel for light weight. |
#9 |
Registered User
Tholub - I would agree with you, but I'm not sure about the 90. A virtual 90" on a 29er would be a ratio of roughly 1:3. Would riding this be possible?
Also - what's your reasoning for the 44? |
#10 | |
Totally Doable
Quote:
44 is approximate; it just would be good to have smaller gaps in between the gears than we see with the Schlumpf. A 50% jump in gearing makes shifting expensive. |
#11 | |
Sam Wakeling
Quote:
1:1 with 150s on a 36 is also about as low as I want to go. It would be nice to have less of a jump between them though, as especially when downshifting it is like dumping straight into a granny gear. Sam
__________________
Unicycle.com |
#12 | |
Totally Doable
Quote:
#13 |
Ride hard; Stay young
I've never ridden a guni, and I have only a few hundred km on a 36. I can only relate to a change of crank length.
My question is with regard to a "point of no return", or even the point that gearing becomes dangerous? ie I put 114 cranks on my 36er to try out. Aside from the extra effort starting, the ride with the wind was fun, but not so much fun into the wind. I also found (possibly due to the differences) that I was using quite a lot more energy in balance adjustments, more so into the gusty wind, so overall I felt my speed was not all that much greater and I used quite a lot of energy in comparison to 125cm cranks I thought. Is there a practical limit to max gearing? Last edited by IUni; 2009-05-15 at 04:08 PM. |
#14 | |
Totally Doable
Quote:
It also helps to have relatively small steps between gears. On a bike, typically you'll get up to speed in a lower gear and shift up as you go faster. So you're not trying to push a 90" gear from a standing start; you're trying to shift up to it when you're already moving almost fast enough to ride in that gear. Quick calculation: A 90" gear at 100 RPM is moving 43.1 kph, 26.7 mph. Unis have already gone that fast; the speed should be sustainable for a strong enough rider on a good setup. Dangerous? Certainly the faster you go, the higher your kinetic energy. But it also seems that you get more stable at high speeds; I don't think anyone at RTL had a high-speed fall, except in the criterium. A fall at 40kph+ is relatively likely to cause an injury, but perhaps less likely to occur. |
#15 | |
Uni - The Unicycle Magazine
Quote:
__________________
Uni - The Unicycle Magazine www.unicyclemagazine.com http://twitter.com/UnicycleMag Last edited by mikepenton; 2009-05-18 at 06:17 AM. |
| Tags |
| 29er, 36er, gears |
Similar Threads
| Would you carry on Unicycling if... | SamGoodburn | General Unicycling Discussions | 137 | 2009-06-30 10:04 PM |
| Koxx choco brown, what do you think?? | toniruckschloss | General Unicycling Discussions | 0 | 2009-04-26 11:19 PM |
| 36er, or 29er | uni1320 | Unicycle Product Reviews | 5 | 2009-03-08 09:07 PM |
| Which to buy 36er or 29er ? | rui | General Unicycling Discussions | 9 | 2008-08-12 11:54 AM |
| 29er vs 36er | sxbud138 | General Unicycling Discussions | 9 | 2008-05-06 03:28 AM |
