#61 |
XC Muni
Maxxis Minion DH 26 x 2.7
Measures out to 2.25" wide (outside to outside of knobbies) and 2.25" tall (rim edge to top of knobbies). Compare with a Intense DH 24 x 3 measuring 2.5" x 2.5". So a hair smaller all around. I didn't get a weight, but Maxxis says it's 1320gm. I compapred it my Duro 26 x 3" and it did seem lighter. How does it ride? Well, my goal was to find a tire that was similar to the Intense DH. I wouldn't say that the Minio is similar, though the Minion does has a consistent hard knobby edge like the Intense and Gazz Jr. The first thing I noticed with the Minion is how fast and light it seems, like quick even, so not sure if it's because of the weight and volume or tread pattern. In dry and wet conditions, traction was comparable to the Duro and Intense. I initially ran it high pressure (18#), then lowered it (14#), but found I was hitting the rim on hard impacts, so I put it at 16# and it felt good. I'm 200#. I could see bumping up or down by 2# depending on air temp. Sidewall strength is higher than the Duro as evidenced by the tire holding an edge on off angles, esp when I'm starting on a sidehill. So less sloppy at low pressures than the Duro, though still not quite as firm as the Intense. The Intense and Gazz Jr really have the best sidewall design for muni, but sadly neither is made anymore ![]() In comparision to the TRY ALL Stiky, this tire has more width, more volume, and more sidewall strength, so I'd vote for the Minion over the Stiky. The Minion didn't seem to be any worse with crowns than other tires I've tried. Rebound was good, though the lack of volume compared to the Duro was telling; it is a smaller tire. The ride was good overall, though at times it felt like a tractor tire as it doesn't have as clean a centerline as some other tires. Overall it is one of my new favorites as I felt like my riding was stepped up a notch by riding the Minion over the Duro. The best thing about the Minion: They are still being made!!!!!! Last edited by Nurse Ben; 2009-10-20 at 03:06 PM. |
#62 |
Mainly XC Muni
Sounds quite promising (although I'm pretty happy with the Duro for the riding I tend to do, and haven't like the "sacred" Gazz 3" at all when I've ridden other people's munis). Is that a rear Minion you're testing? The front one looks like it wouldn't be nice at all.
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) Last edited by rob.northcott; 2009-10-20 at 03:26 PM. |
#63 | |
weather is a fiend
Quote:
one more question, is it the sticky compound?
__________________
android power. |
#64 |
Hartman Rocks, Uncompahgre beyond..
@Nurse Ben: Nice review. Since I've been getting more experience riding with my Schlumpf KH24 MUni I've been thinking that perhaps I should experiment with a thinner tire than my current 24x3 Nokian Gazz. I love the Gazz and have a brand new replacement for when my current one goes. However I've noticed that riding in high-gear the advantages of having such a wide tire go out the window; it would be better (nicer?) to have a tire with a bit less rolling resistance. Anybody out there using a 24" MUni tire that isn't 3" wide that does pretty good? I'm now starting to see Kris Holm's logic with going with the 26" tire of less than 3" width...!
__________________
munisano Last edited by MuniSano; 2009-10-22 at 12:41 AM. |
#65 |
XC Muni
I have the DHF 26 x 2.70 with wire bead. The DHR would work, though it might be slicker side to side...
I don't know that a narrower tire is a replacement for all uses, they certainly don't help with hopping, but for more of a rolling XC use the narrow tires work fine. The Minion is nice beause it has a stiff sidewall, like the Intense ro Gazz, so it can be run at low pressures, unlike MTB tires which fold unless you pump them up over 20#; at least at my 200# weight. KH is a lightweight, that's why he can get away with riding MTB tires, well that and he's an exceptionally skilled rider ![]() Next thing I'll try is one of the wider Intense 26" tires... Hey Munisano, good luck with finding a narrower tire for your 24", they just aren't making that size in many tires these days, which is why I ride a 26": Lots of rim and tire choices. Last edited by Nurse Ben; 2009-10-22 at 05:43 PM. |
#66 |
ERIC P
Are you calling the Minion, Gazz and Intense non MTB tires? If they weren't made for Mountain bikes I don't know what they were made for.
I temporarily used a Continental Gravity 26 X 2.35 on a DX32. It was really light and responsive with good grip. It was a decent XC combo but I missed the flotation of a wider tire and switched back to my Gazz.
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton |
#67 |
Mainly XC Muni
Thanks for clarifying that - from just looking at them I would have guessed the front pattern would be horrible to ride, but nothing beats actually trying it!
On the subject of using bike XC tyres, I sometimes use a 2.1" Ritchey Z-Max on my 26er for _really_ muddy XC races where the mud is sticking to the tyre and a lot of the bikers are using 1.5" mud tyres. It works well for that, although it does have to be run at higher pressure and takes more concentration to ride when half asleep. It's not good if it's rocky or very rooty. It's what I used to use all the time when I was riding mountain bikes (which is why I've got one lying around), but on a unicycle I prefer something a bit fatter for general off-road use. Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) |
#68 | |
weather is a fiend
Quote:
My current really bad weather tire is a 2.35 maxxis swamp thing. It has decent bounce for it's size and it rides wet trails like it has tentacles. This tends to make it horrible on pavement because of that, if i'm riding in heavy snow and ice around town, i'll usually take something more road friendly.
__________________
android power. |
#69 | |
Quote:
(My first MUni was a 26er which I had to piece part together with quite a bit of effort) Now the pendulum has swung the other way! That is all within a few years, a sign of how quickly our sport is changing! Still, I've got a slightly used 24x3 Duro, and a brand new 24x3 Gazz waiting for me so I should be good in the 24" realm for a while longer. After that I'll look into throwing some more $$$ at a 26" KH frame and rim set. If I do that I'm pretty sure I'll go with a narrower 26" tire. I'm really starting to think Kris Holm is on to something (surprise, surprise). Still I want a MUni set-up that is nimble and tight for the rough trail system I have to ride all the time; I think a 26x3 would be too much (more like a 28er). You wouldn't think a couple of inches would make a difference but I can tell when I ride the tight and buff single track around here. I'd love to have a 29er too, but that would be a nightmare to ride around Monte Sano!
__________________
munisano |
#70 |
XC Muni
Got a few more rides in the Minion, what can I say, the tire is awesome! I was able to descend to hills I'd never made with at least one UPD, the bigger hill is long, very rooty, rutted, some drops, and I cleaned it no problem. The biggest thing I notice about the Minion is that it feels very light and it is quick, way quicker than any other tire I've ridden. Even my son liked the feel and he's used to riding an Intense DH 24 x 3. I run mine at 16# for my 20# body weight, this works well for everything, though a lower volume would be less bumpy when I'm tires. Sticky tread, climbs anything, I won't go back to the Duro or any other 3", I'm with Chris on the narrower tire thing, it works.
Did you all read about the new WTB Dissent? Loks nice for 29ers if you get the the HD version. |
#71 |
weather is a fiend
Cool! I'll have to pick one up! Sounds like the tire i've been looking for.
__________________
android power. |
#72 |
Registered User
anyone know where to get a good 26 tire? my duro 26x3 is already showing wear only after 1 week of riding.
__________________
Your head lives in your gut. Listen to your gut
#73 | |
Mainly XC Muni
Quote:
![]() The last few posts have been about the 26" Maxxis Minion front DH tyre. Apparently it works well. The only other tyre I've used on my muni apart from 3" Duros (which I like, BTW) is a 2.1" Ritchey Z-Max, which is nice and light and works well in mud (good frame clearance with a narrow tyre) but is really a bit too puny for anything but very light xc. Rob
__________________
#74 |
ERIC P
If this is going to be the "official" MUni tire thread we might as well link to some existing MUni tire threads.
Wanted: 24X3 comparisons Duro Wildlife vs Intense DH Duro Leopard 26 X 3.0 tire Of-course info in each thread is wider than their title since we tend to wonder off topic a bit here.
__________________
#75 | |
Alex Grierson
Quote:
Anyway I love my holy roller. It seems to grip everything pretty well except loose pine needles. I like having a 2.7 not a 3". I will probably get a 2.5 for my next tyrel. 3" is too wide, it's just too heavy, the small amount of extra grip isn't worth it, and in muni you never need that much air in your tyre unlike trials. You're not dropping to flat concrete or anything flat even if you are doing drops. |
| Tags |
| muni, official, page, review, tyre |
Similar Threads
| The Official 19" Trials Tyre Thread | Sponge | Unicycle Product Reviews | 423 | 2013-02-09 03:15 PM |
| The official "uncover the mole" game thread | habbywall | Just Conversation & Introduce Yourself | 55 | 2006-02-27 09:59 PM |
| Best 28" rim and tyre for muni? | Cumbria_Muni&Trials_Club | General Unicycling Discussions | 17 | 2004-11-18 11:46 AM |
| UNICON 11 "Official T-Shirt Competition" | Trade Winds | General Unicycling Discussions | 6 | 2002-07-23 01:03 PM |
