Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 2009-04-12, 04:19 PM   #1
scotthue
10k & Marathon World Champ
scotthue's Avatar
Send a message via Skype™ to scotthue
Will rubber cement work for vulcanizing tire patches
I have a bunch of tire patches left over because I have used up the glue. I found some replacement glue tubes for tire patches, but they are small and expensive. I was wondering if regular rubber cement such Elmers will work. Does it vulcanize?
scotthue is offline   Reply With Quote
Old 2009-04-12, 04:35 PM   #2
harper
768 - It's in your DNA
harper's Avatar
Tube patch kit glue is not a vulcanizing agent. It is simple rubber cement like Elmer's or other products. That stuff should work fine.
Vulcanization takes place at high temperatures with chemical additives. The molecular bonding is changed in a manner that strengthens the rubber and makes it resistant to chemical attack. It doesn't happen at room temperature.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
Change is good. Bills are better.
harper is offline   Reply With Quote
Old 2009-04-12, 05:05 PM   #3
saskatchewanian
ERIC P
saskatchewanian's Avatar
I don't even buy patch kits anymore. Regular rubber cement and regular cut-up tubes work great. I have not had a patch leak in 10 years.
saskatchewanian is offline   Reply With Quote
Old 2009-04-12, 11:41 PM   #4
mgrant
Ever hoping for the best!
mgrant's Avatar
Send a message via AIM to mgrant Send a message via MSN to mgrant Send a message via Yahoo to mgrant Send a message via Skype™ to mgrant
Quote:
Originally Posted by harper View Post
...Vulcanization takes place at high temperatures ...
Normally I would agree with Harper (because he's a lot smarter and older than me). But ever since he claimed that water is incompressible I've felt compelled to clarify/correct his mis-information.
Vulcanization does NOT take place at high temperatures. It takes place at a temperature slightly warmer than that of Earth (as Vulcan is a little hotter than Earth).
True Vulcanizing agents are VERY expensive since Vulcan is about 16 light years from Earth and neither UPS nor Fed-Ex ship from Vulcan.
-mg
p.s. I'm not really sure what developing pointy ears and an obsession with logic/lack of emotion has to do with patching leaky tubes.
__________________
The sun is the same in a relative way but you're older, shorter of breath, and one day closer to death.
michael_j_grant (at) yahoo (dot) com
Gallery: http://tinyurl.com/34my5c
mgrant is offline   Reply With Quote
Old 2009-04-13, 12:03 AM   #5
harper
harper's Avatar
-mg
You're right that is was foolish of me to post that water is incompressible when, much like tungsten, it obviously is not.
My part of the vulcanization discussion did not involve cost. I feel that including transportation costs to various alien places like Vulcan, Congo, or Utah for unicycle repair is entirely justified.
Long time, no see, mg. Are the peewees all riding by now?
__________________
-Greg Harper
Old 2009-04-13, 12:09 AM   #6
mgrant
mgrant's Avatar
Three of the four ride. My youngest daughter (4) is scared of her two-wheeler and won't even consider a unicycle yet.
-mg
__________________
Old 2009-04-13, 06:05 PM   #7
scotthue
scotthue's Avatar
Now I'm very confused. Thanks guys.
Old 2009-04-13, 06:45 PM   #8
mgrant
mgrant's Avatar
My apologies for the silly thread-jack.
Yes. Normal rubber cement should work fine.
-mg
__________________
Old 2009-04-13, 07:43 PM   #9
Mikefule
Bridge of Otherwhere: on Kindle
Mikefule's Avatar
Vulcanising patches work by chemically bonding the patch and the tube rather than by sticking the patch onto the tube with an intervening layer of glue.
No doubt purists would argue over whether it is true "vulcanisation", but "vulcanising patches" do work in a different way from the ordinary sort.
That said, I should imagine you can just stick 'em on in the old fashioned way.
__________________
My first novel, Bridge of Otherwhere, by Michael Wilkinson, now available on Kindle.
https://www.facebook.com/Michael-Wil...1026952194339/
Mikefule is offline   Reply With Quote
Old 2009-09-01, 02:31 AM   #10
Chrashing
O>OO
Chrashing's Avatar
Wow, I found this thread while googling ' Chemical Vulcanizing Cement'. Never thought I'd find a path back home to the unicyclist forum.
I've found products described to be vulcanizing rubber cement for tubes. I'm just not sure if these products only do their vulcanizes thing if you use the patches from the same manufacturer. Detailed descriptions describe the chemical vulcanization happens with the gum of the patch. Since I want to join a rubber tube to rubber tube without the patch material, I'm not sure the vulcanizing will happen.
I'll try to call REMA tomorrow.
__________________
Regards,
Ken
Unicycles are flying machines!
24", 28", 32", and 36" KH frame based mutts.
26" inexpensive travel.
Chrashing is offline   Reply With Quote
Old 2009-09-01, 02:51 AM   #11
jtrops
Unicyclist
I bought a can of patch cement at an auto parts store that is the same as the stuff in the tubes. I've used regular rubber cement, but this stuff definately works better. I have been making my patches from old tubes and cleaning them with acetone before applying the cement. The bond is very good, if not as good as using a factory made patch.
jtrops is offline   Reply With Quote
Old 2009-09-11, 01:22 AM   #12
Chrashing
O>OO
Chrashing's Avatar
I tried using REMA cold vulcanizing fluid. and it worked worst the Schwinn patch kit cement. There was no vulcanization, seems to be plain rubber cement.
__________________
Regards,
Ken
Reply
Tags
cement, patches, rubber, tire, tube, vulcanizing, work
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
click here for pele's theory on religion and arguments with/for/against it skrobo Just Conversation & Introduce Yourself 77 2009-04-29 08:24 PM
Do you make snake trails on cement? Dane M General Unicycling Discussions 9 2009-03-24 07:51 PM
Will 700 x 35c tube work in 29" tire? teachndad General Unicycling Discussions 7 2003-04-24 12:20 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 0.08653 seconds with 9 queries
