Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2008-10-29, 06:53 AM   #16
Jerrick
King of Carnies
Jerrick's Avatar
Send a message via MSN to Jerrick
Quote:
Originally Posted by skrobo View Post
really... just adjust your tension a little.
when they break off you can cry about it.
Adjust the tension? As in loosening it to weaken the wheel, putting the rim out of true?
Its pretty bad to unbend the flanges just to pull the spokes in and out of the hub when lacing the wheel up. Its also bad when the flanges crack and start to rip away from the hub.
__________________
Just bumming around MR~~~~~~~~~Team Forrest~~~~~~~~~Team Dirty Bird!~~~~~~~~~~~~~~~
Check out my Band.~~~~~~~~~~~~~~~!Quack!~~~~Team Spencer!~~~Member of the MRIS.
Want some advice? Do better.
~Jerrick
Jerrick is offline   Reply With Quote
Old 2008-10-29, 12:48 PM   #17
skrobo
jumps stuff
skrobo's Avatar
Send a message via AIM to skrobo
how many sets of flanges have you heard of doing that?
one?
__________________
><> Unicycle For Christ <><
MY VIDEOS
World Record
94cm Highest Hop (rolling)
308cm Longest Hop (10 feet)
210cm Static Flat Gap
skrobo is offline   Reply With Quote
Old 2008-10-29, 09:43 PM   #18
Jerrick
King of Carnies
Jerrick's Avatar
one?
Having the rim pull out of true? Too many to count.
Needing to bend the flanges out to get the spokes? So far, everyone who I have talked to with a KH hub, even some with the Koxx hub.
Cracking and pulling away? 3.
__________________
~Jerrick
Old 2008-11-07, 01:06 AM   #19
Michaelgoround
John 15:13
Michaelgoround's Avatar
I was wondering... The flanges are the circle shaped things the spokes go through, right?
Michaelgoround is offline   Reply With Quote
Old 2008-11-07, 01:11 AM   #20
Jeremy R
onceuponatimetherewasaper son
Jeremy R's Avatar
Send a message via AIM to Jeremy R
Quote:
yes.
__________________
661
MountainUni
or make it a dinglespeed - saskatchewanian
Jeremy R is offline   Reply With Quote
Old 2017-08-27, 11:17 AM   #21
Wennn
Unicyclist
Just bought a 125mm nimbus isis disc hub (the aluminium one). Strangely, unlike the steel hubs, this hub isnt drilled through, the crank bolt holes are drilled 60mm deep from each side, leaving a solid 63mm of untouched aluminium in the center.
For a weightweenie hub, this is unacceptable! (Roger or anyone involved in the design, was there a reason for this, be it cost saving or strength?) With the m12 thread, even if the center section was drilled through then not threaded, this would mean a 14g weight saving on a 207.75g (exc bearing & spacer) hub!
Wennn is offline   Reply With Quote
Old 2017-08-29, 02:11 PM   #22
superfunk
vegetable powered
What are you using that hub for? Muni? Let us know how it goes
superfunk is offline   Reply With Quote
Old 2017-08-31, 03:06 AM   #23
Wennn
Unicyclist
Yes I am, however my unicycle and I only weigh 67kg and I havent been able to break the Qu-ax aluminium cranks, so perhaps I'm not too harsh on equipment.
Will certainly uodate as time goes on though!
Reply
Tags
hub, isis, product, review
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Product Review: Wellgo MG1 isaac steiner Unicycle Product Reviews 2 2008-08-03 06:22 PM
Uni product review video segment. gabetheunicycleman General Unicycling Discussions 6 2007-02-08 12:20 PM
Check out New Product Review Resource! Sofa Unicycle Product Reviews 0 2003-12-27 01:02 AM
Product Review Forum concerns... andrew_carter General Unicycling Discussions 7 2003-01-26 05:12 AM
Product Review Forum andrew_carter General Unicycling Discussions 0 2002-10-21 05:13 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.07962 seconds with 9 queries
