Unicyclist Community
Reply
Old 2008-08-21, 05:05 PM   #1
lpounds
Registered User
lpounds's Avatar
Send a message via MSN to lpounds
Can one use a 2.5/2.7 inch tube in a 3.0 inch tire?
All I can find at shops around the city are 2.5/2.7 inch tubes.
Will it work with my 26 x 3.0 inch Arrow tire?
__________________
Unicycle Dot Com Canada
lpounds is offline   Reply With Quote
Old 2008-08-21, 05:23 PM   #2
joemarshall
dumb blonde
Almost certainly - I've used 26x2.1 in 26x2.6 before, and that was running a non-downhill tube in a downhill tyre - here you're just running a slightly less massive tube.
Joe
joemarshall is offline   Reply With Quote
Old 2008-08-21, 05:23 PM   #3
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Yes, but it'll stretch the tube out a bit, making flats a bit more likely.
Don't get that tube. You want one that has a Shrader valve stem, not a Presta. It's possible to use a Presta valved tube but you would have to put a shim in the valve hole.
I'd get a full 3" tube. Your LBS probably won't stock any, but they can order one.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2008-08-21, 05:27 PM   #4
tholub
Totally Doable
tholub's Avatar
Presta valve is way better than Schraeder valve for cycling. Just ask the shop for the little donut.
tholub is offline   Reply With Quote
Old 2008-08-21, 05:36 PM   #5
lpounds
Registered User
lpounds's Avatar
Found a three-point-oh downtown.
Thanks guys.
__________________
Old 2008-08-21, 06:53 PM   #6
joemarshall
dumb blonde
Quote:
Why? For a muni - no advantage of high pressure, no advantage of weight, disadvantage of not being able to use petrol station air pumps on it, disadvantage of being easier to break if you have to pump it up with a mini pump on the trail.
Joe
Old 2008-08-21, 07:08 PM   #7
tholub
Totally Doable
tholub's Avatar
Quote:
Joe
Have you ever been on the trail with someone, trying to blow up a Schraeder value with your mini-pump, only to find that due to the geometry of the tire, the tube, the valve, and the pump, you just can't get air into the tube? I have, more than once. Even with my floor pump at home there are Schraeder valves that don't sit quite right and leak air while you're filling.
The ideal setup is a Schraeder-drilled rim with a Presta-valve tube with a Schraeder adapter.
Old 2008-08-21, 08:33 PM   #8
skilewis74
skilewis74's Avatar
My MUni has a threaded Shrader valve stem like this one.
It definately makes pumping up easier. I can tighten down that ring and pump real vigorously w/o fear of damaging the stem. Also makes it a lot easier to fill when only partly inflated - the stem dousn't squish into the tire.
...disadvantage of not being able to use petrol station air pumps on it...
I used to always carry an adapter w/ me on my mtb.
__________________
What's next?
Learn2Ride&doTricks
Old 2008-08-21, 09:47 PM   #9
pkittle
NorCal Riding Project
pkittle's Avatar
Re: the original question ...
I've found lots of places that stock tubes for cruisers that are 26x3, and they're pretty burly ones, too. Always schrader, though, but I've not run into any of the mentioned problems on the trail (yet). It's funny, I don't have a schrader valve on any of my bikes, but they're on all my unis.
__________________
Peter Kittle * Chico, CA
"The Revolution is just a t-shirt away."
--Billy Bragg
pkittle is offline   Reply With Quote
Old 2008-08-21, 11:33 PM   #10
lpounds
Registered User
lpounds's Avatar
Just managed to pick up an IRC "Torque Tube". It's 2.35-3.0 with a Schrader valve.
I like this one because it seems to be a tad lighter than the tubes branded, "Heavy Duty".
mmm it smells so good.
__________________
Old 2008-08-22, 06:09 AM   #11
412
Cold blue steel and sweet fire
I've been using a 2.7" tube (really thick) in a 3" gazza for a few years now. I run 1 bar pressure and weigh 90kg... and the rim has some dents but no puncture yet.
412 is offline   Reply With Quote
Old 2008-08-22, 03:42 PM   #12
forrestunifreak
is in college. and on magazines.
forrestunifreak's Avatar
Send a message via AIM to forrestunifreak Send a message via MSN to forrestunifreak Send a message via Skype™ to forrestunifreak
I use a 2.125" tube in a 3" tire.
__________________
[SIGPIC][/SIGPIC]
forrestunifreak is offline   Reply With Quote
Old 2008-08-22, 05:11 PM   #13
mscalisi
Registered User
I did that a few years back. It worked, but not very well. My tire was always either too hard or too soft.
Quote:
__________________
><> Unicycle for (reducing the) Buddha <><
mscalisi is offline   Reply With Quote
Old 2008-08-22, 05:46 PM   #14
entropy
Dropped
entropy's Avatar
I always use a 26"x3.0" in my 24", but I have a 65mm rim and I inflate it to about 35 psi. What really makes it nice is that I can use the same tube in my 29er, so I don't have to remember to swap out spares in my hydro pack.
__________________
Shut up and ride.
entropy is offline   Reply With Quote
Reply
Tags
inch, tire, tube
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
29 inch tire for road dondi Unicycle Product Reviews 2 2008-06-24 04:17 PM
Will a 2.1 inch tube last in a duro tire? Monocyclist General Unicycling Discussions 3 2006-10-07 10:13 PM
48/50 inch tire... musclebeach191 Unicycle Product Reviews 3 2004-07-27 01:56 AM
Re: Mikefule's ratio & seat comfort [was Re: 56 inch big wheel with 4.5 inch cranks!?] Ken Fuchs General Unicycling Discussions 0 2003-09-07 04:34 AM
Alex DX32 Rim = 3 inch tire? Erin General Unicycling Discussions 12 2002-12-28 07:29 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11543 seconds with 10 queries
