Unicyclist Community
Reply
Old 2008-07-03, 01:07 PM   #1
tobbogonist
Patronus unicycleus
tobbogonist's Avatar
Nimbus 24 Isis. Crank compatibility
quick question. if i purchase this: nimbus muni
can i fit these: moment cranks on to it.
I would have thought yes but nothing will surprise me.
That being said, once my question is answered, i guess, depending on the outcome, i can fit/or not fit any other ISIS crank to that hub..
Thankyou
Tom
__________________
Your life is a storm, thunder is your music and lightning is your electric dancing legs, groove on friends. Groove on.
tobbogonist is offline   Reply With Quote
Old 2008-07-03, 01:47 PM   #2
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
That's a pretty common upgrade. The Nimbus ISIS hub is pretty much exactly the same as the KH apart from the cutouts in the flanges.
Koxx1 cranks used to be a bit funny with compatibility (although I don't know if that's changed now), but Nimbus and KH mix fine.
Rob
rob.northcott is offline   Reply With Quote
Old 2008-07-03, 05:06 PM   #3
kington99
Registered User
Send a message via MSN to kington99
yes moments on a nimbus hub is a very popular upgrade with the trials guys
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2008-07-04, 03:23 AM   #4
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Any true ISIS crank other than Kox should fit on the KH/Nimbus hubs.
I now someone who put 170 Echo cranks on his KH and they went on fine, but I've heard heard people having problems w/ other brands (I think it was Truvativ).
Onza Tensiles, Qu-Ax ISIS aluminum (not too strong), and Qu-Ax ISIS Cro-mo definately do fit.
UDC has Tensiles in 140 mm that have been reinforced for uni, still I've heard they can bend from a lot of big drops w/ static landings. I've also seen them in 165, 170, & 175.
If you like more Q-factor, I'd consider the Tensiles or Qu-Ax Cro-mo cranks.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2008-07-05, 04:26 AM   #5
tobbogonist
Patronus unicycleus
Thankyou very much for your help, all of you
I figured that was the go but i wanted to make sure first.
and now i know there is even more options crank wise. cranktabulous!!
thanks everyone,
Tom
__________________
Reply
Tags
compatibility, crank, isis, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Torker DX 24" Muni or Nimbus 24-inch MUni w/ isis kommanderkoji Unicycle Product Reviews 7 2008-04-23 12:59 AM
Nimbus ISIS v.s KH ISIS Hubs oneisenough General Unicycling Discussions 50 2007-11-02 04:43 PM
Udc Price: Nimbus isis 20" v 24" qhxakg General Unicycling Discussions 2 2007-09-11 04:47 AM
Torker DX Crank compatibility zfreak220 General Unicycling Discussions 2 2007-05-28 03:24 AM
Moment Hub & ISIS cranks - compatibility? entropy General Unicycling Discussions 16 2006-11-17 11:06 PM
Copyright © 2001-2005 Gilby
Page generated in 0.06370 seconds with 10 queries
