Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2008-06-24, 07:41 PM   #1
Russtynail
Registered User
Russtynail's Avatar
Send a message via MSN to Russtynail
Crank Puller
So I have a ISIS/splined crank puller and went to my LBS today to grab a puller for my square tapered cranks. They guy at the store said I don’t need a separate one, and that all I needed to do was to take the little nut off the crank puller (the end piece) and then put a dime over top of the square hole, and just use the puller as if it were a square tapered puller.
So I went home and tried it out, and it worked great! Although, you lose a dime in the process so after a few years it could get costly
Has anyone else heard of this secret? If so has anyone heard of any bad coming from it? Both the crank and puller looked fine afterwards, no visible signs of damage.
__________________
><> Unicycle For Christ <><
Russtynail is offline   Reply With Quote
Old 2008-06-24, 07:51 PM   #2
zfreak220
Polska Możność
zfreak220's Avatar
Send a message via AIM to zfreak220
I've heard of doing this before and for most it seems to work well, but I do remember somebody saying that their crank puller just punched right through and screwed up their crank bolt threads, so just be sure to put in enough dimes that it won't punch through.
__________________
-Conrad
zfreak220 is offline   Reply With Quote
Old 2008-06-24, 07:54 PM   #3
Ducttape
I unicycle for Donuts
Ducttape's Avatar
Send a message via AIM to Ducttape Send a message via MSN to Ducttape Send a message via Yahoo to Ducttape Send a message via Skype™ to Ducttape
Quote:
somebody I know(can't remember who right now though curse my memory) has done it and their cranks were so stuck that they put multiple dimes under the crank puller and I think lost about 40 cents in the process of removing their cranks.
Ducttape is offline   Reply With Quote
Old 2008-06-24, 08:02 PM   #4
lpounds
Registered User
lpounds's Avatar
Send a message via MSN to lpounds
That's awesome. Could have used this trick the night before the first stage!
lpounds is offline   Reply With Quote
Old 2008-06-24, 08:04 PM   #5
Russtynail
Registered User
Russtynail's Avatar
Well, I only have tried it on one set of cranks, and it punch through the dime last minute on both cranks! but it didnt break anything, thas for sure, I guess multiple dimes would make sense...!
__________________
Old 2008-06-24, 08:46 PM   #6
maestro8
has a pointy head
maestro8's Avatar
Send a message via AIM to maestro8 Send a message via MSN to maestro8 Send a message via Yahoo to maestro8
As some have found, this "trick" has resulted in damaged threads.
So... what's cheaper... the proper tool, or a new set of cranks (plus lost time waiting for new cranks)?
Always use the right tool for the job.
__________________
Spencer Hochberg fan club
Those are my principles. If you don't like those, I have others. -- Groucho Marx
The only way to comprehend what mathematicians mean by Infinity is to contemplate the extent of human stupidity. -- F.-M. A. de Voltaire
maestro8 is offline   Reply With Quote
Old 2008-06-24, 09:57 PM   #7
Russtynail
Registered User
Russtynail's Avatar
I wasnt trying to imply that there is no need for a square tapered crank puller; but was questioning the method itself, I didnt want to continue with the method if I knew that it would damage, although as in my case , it does work if you are caught and dont have one. I wouldnt recommend using it like that 100% of the time, in time I will be getting the other crank puller as well, but my lbs didnt have any in stock and thats why he suffested this method.
__________________
Reply
Tags
crank, puller
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Crank Puller Question fluxusmaximus Rec.Sport.Unicycling 8 2009-01-20 03:25 AM
Removing cranks without a crank puller? unisteez Rec.Sport.Unicycling 10 2006-05-05 04:08 PM
New Park Crank Arm Puller daino149 Rec.Sport.Unicycling 4 2003-10-21 10:29 PM
Park CWP-5 Crank Puller rhysling Unicycle Product Reviews 2 2003-09-19 11:23 AM
Crank puller problems. Odd size? zamley Rec.Sport.Unicycling 3 2002-08-05 04:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.20582 seconds with 10 queries
