#16 | |
Registered User
Since I haven't really done any head to head comparisons, I don't really have any way of quantifying the difference in speed between my riding geared and ungeared.
It's also hard for me to say that I know a 36er is faster than a 29er. Between the two of us, Tom was faster on his 29er, but overall he is a stronger rider than me anyway. It makes sense that the 44-inch gear should be easier to push uphill and that the 56-inch gear should go faster downhill. It's also evident that it's easier to control a 44" gear on a steepish decline than the 56". A brake should eliminate that difference, but I have yet to find a brake solution that I'm comfortable using geared up. (I fit a caliper brake that seemed fine when 1:1, but super sketchy in high-gear) One thing I like about my current setup is that with 127mm cranks, I have two useful gear ratios. A 29er with 127mm cranks isn't often useful in 1:1, except for maybe in the dirt. Of course you could always drop down to 114mm cranks, which Tom was considering doing. He probably won't now though since he's going to convert his ride into a ride-to-the-trail and then ride-the-trail cycle. If I could go back in time and make my decision again, I'd be very tempted to go the 29er route, especially when you factor in weight and portability. Quote:
__________________
><> Unicycle for (reducing the) Buddha <>< Last edited by mscalisi; 2008-06-26 at 11:06 PM. |
#17 | |
Uni Hour Record Holder 29.993km
Location: Wellington, New Zealand/ Middle of NSW, Australia
Quote:
I haven't used it since Laos though, so I guess it's time to dust it off. Looks like it's had a good testing period since the new design came out. It's not a good idea to be one of the first people in the world to try new things
#18 | |
Registered User
A couple more things on the geared 29er vs. geared 36er while I'm fleshing out my opinions on the two:
Probably the main reason I chose a 36er over a 29er is that it still feels more 36er-y. This is to say, it's a more comfortable ride. It's less nimble, but more forgiving. Also, I feel that it's easier to land on your feet when you UPD. Since you're a little higher up, you have just a tiny bit of time more to get positioned to run out. Quote:
__________________
><> Unicycle for (reducing the) Buddha <>< Last edited by mscalisi; 2008-06-26 at 11:42 PM. |
#19 | |
Dan Hansen
Quote:
My first try on the Schlumpf for that lap was about 45 minutes. This was within the first 50 km of riding this Schlumpf/Hunter 36" build. I was clumsy with it when I did this ride, and didn't then feel nearly as fast as I do now. Now I have 400+ km on it . I'll try it again within a couple weeks though it sounds like you've made your decision. You'll be fearsomely versatile!
#20 | |
Quote:
I think I would definitely be faster, but how much remains to be seen. I'm more of a spinner than a gear masher, so not sure if I have what it takes to push it as fast as some of you power animals out there (eg Chuck). |
#21 | |
Dan Hansen
Quote:
#22 | |
Treehouse Muni Rider
Quote:
12.8 miles, 0:51:11 time, 15.00 avg A week later I did it again on my geared cycle: Geared, via my cycle computer: 12.32 miles, 0:43:46 time, 16.9 avg In general, the geared 36'er makes me 2mph faster. corbin
__________________
http://www.corbinstreehouse.com Last edited by corbin; 2008-06-26 at 11:59 PM. |
#23 | |
Quote:
You might land from higher up, but hopefully more gracefully on a 36" Sclumpf. |
#24 | |
Quote:
corbin
__________________
http://www.corbinstreehouse.com |
#25 | |
Registered User
The thing that's a little disturbing to me is that a freewheel mode is possible. If you hit the button and it engages a little, but not all the way, this can be activated. It's a little unusual since the hub really wants to be in one gear or another, but I've experienced it while shifting. Tom experienced it while hill climbing with a loose ISIS crank.
I think a UPD because of a free-wheeling incident is far more dangerous than a typical UPD. In a typical UPD, you come off forward of the unicycle, and your body weight is somewhat ahead of your legs. Either you run out, or you fall forward. With a freewheel UPD, you can come straight down. It's possible that you fall slightly backwards. My hypothesis about what happened to you is that your leg came down at a slightly awkward angle ahead of your body weight, and then had all the force of your body push into at 30kmh Had you simply had a regular UPD, you would have fallen forward and gotten scraped up, but not forced your leg into an awkward position. Frankly, I'm not sure that a 36er could have prevented it. Quote:
__________________
><> Unicycle for (reducing the) Buddha <>< Last edited by mscalisi; 2008-06-27 at 12:26 AM. |
#26 | |
New York Unicycle Club
Quote:
As for Ken's Q about speed: I reached 21 mph as a max speed on my Coker with 110s. Without a steepish hill, my cruising speed was no greater than about 16 mph for an extended period. With my 29" guni and 125s, I can reach 22.5 mph (35.6 kph) and was able to maintain 18 mph (just under 30 kph) at RTL under the right circs. So I'd say that the 29" guni added about 5-10% to my speeds without costing too much in work.
__________________
Dictator for Life, NYUC Check out my blog (or else): http://newyorkunicycle.blogspot.com/ |
#27 | |
Quote:
_____/O______ Try this- ride a bike really fast. Now tilt to the side and plant your leg at about 45 degrees into the ground at 30km/hr.
__________________
Adventure Unicyclist Induni: The India Unicycle Tour Uninam: The Vietnam Unicycle Tour SINZ: The South Island, New Zealand Unitour The Laos Unitour Last edited by GizmoDuck; 2008-06-27 at 05:13 AM. |
#28 |
dumb blonde
I don't think the schlumpf 29er gives me a massive advantage in terms of speed compared to a coker. The high gear doesn't feel massively different - with 125s (as pretty much everyone was running) it's quite similar to 102s on a coker. For me, it's primarily a very convenient coker which can also be an okay muni, ie. a to the trails and ride the trails machine.
I think that now I'm used to it, and have a lightweight(ish) road tyre on it, it is more relaxing to ride for long distances though - you are just spinning a lot less weight around - approx 1500g weight at the rim vs. ~3000g at the rim on a coker. It seems from RTL that the 36" schlumpf does give a noticeable speed advantage though, which I guess is unsurprising, as it is a so much higher gear and still has a usable low gear. Although having said that, there are I think 2 teams in the top 10 who only had 29er schlumpfs? Maybe there is an advantage to the 29er schlumpf for faster riders than me. Joe |
#29 |
Totally Doable
During our training, we kept time on a number of specified runs for different people with different setups. We also did one particular hill (Tunnel Road) multiple times with different setups; this provided some data to analyze about the efficacy of different setups. The conclusions we came to were:
Tons of data in Google Docs spreadsheets: Totally Doable training rides Bay Area training rides |
#30 | |
Going places on wheel.
Quote:
I found myself catching the only gunis that we were riding with on long, gentle uphills and downhills. They'd take off on the flats and most steep hills (up or down). I hope that if RTL happens again, there will be separate categories for geared and fixed unicycles, since there is a significant mechanical advantage at a price that not everyone can afford.
__________________
| Tags |
| nongeared, ranking, rtl, teams |
Similar Threads
| Who will win RTL, Geared or Non-Geared Teams? | unicycle6869 | Rec.Sport.Unicycling | 44 | 2008-06-23 12:30 PM |
| RTL Teams | munimag | Rec.Sport.Unicycling | 1 | 2008-05-09 06:18 PM |
| Twelve teams registered for RTL, Team Nova Scotia included. | RTLjune2008 | Submit Unicycling News! | 0 | 2008-03-17 06:06 PM |
| RTL update: eight teams now registered for June. | ridethelobster2008 | Rec.Sport.Unicycling | 0 | 2008-03-02 09:03 PM |
| non paying uni gig | uni man 22 | Rec.Sport.Unicycling | 5 | 2007-07-17 09:04 PM |
