#1 |
Registered User
tyre psi
hi my username is new im not actualy new to this forum
i forgot my username and password. anyway im starting to get realy into it since I got my uni, its a nimbus btw 20" . but whats better for trials kind of stuff psi wise in the tyre?? and also for a bit of offraoed when I fancy?? thanks |
#2 |
King of Carnies
There is no exact number I can just give you, because its up to your wheel and your own weight.
The point you are looking for though, is a pressure where when you do a drop or a forcible prehop/compression, you will not hit the rim. Yet, at the same time, you want your tire squishy enough for jumping, absorbing drops, and rolling over terrain. So, a real high pressure will get rid of you hitting the rim and folding the tire over, but your tire will be hard and will suck for jumping really. Too low and you will damage your rim, spokes, and probably pinch your tube. Start at a high pressure, jump around, see if you like it, if not, let some air out, test it, and repeat until you find YOUR sweet spot. Goodluck. |
| Tags |
| psi, tyre |
Similar Threads
| What is your fav psi ? | padst3r | Rec.Sport.Unicycling | 12 | 2007-08-03 12:21 PM |
| Riding and dropping with low PSI | jamessd | Rec.Sport.Unicycling | 15 | 2007-07-13 06:49 AM |
| tyre? | splat | Unicycle Product Reviews | 4 | 2007-01-05 04:15 AM |
| Which tyre to get | ivan | Rec.Sport.Unicycling | 5 | 2006-11-13 06:06 AM |
| Looking for a Tyre | unicycleboy | Rec.Sport.Unicycling | 7 | 2006-04-28 01:41 AM |
