#1 |
SevenTwentyUnispin
A few questions of KH frames...
I got a aluminium 20" KH frame today
. And I've just got a few questions.What's the best way to strip the powdercoating off a KH frame? And if I use paint stripper will it damage the frame at all? Will paint stripper work on the powdercoat? How wide should the slit at the top of a KH frame be? I mean the slit that is there so when you tighten the seat clamp the frame can push inwards onto the seatpost. When I got my frame the slit was less than a mm wide, but I widened it so it's good now. O and, do Koxx-one and other 31.8mm seatclamps fit KH frames as well as KH seatpost clamps do? Thanks Last edited by SkierAlex; 2008-06-11 at 09:33 AM. |
#2 | |||
UNI branded
Quote:
Quote:
Quote:
You can PM me, I can post it down from Auckland |
#3 | |
Registered User
Quote:
__________________
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of the complete fools My Website Fat-Tyre.co.uk |
#4 |
slc uni
Ask whoever is going to do your powdercoating if they have a sandblast booth. Most places do.
You'll need to mask the surfaces you don't want sandblasted and powdercoated. |
#5 | |
SevenTwentyUnispin
Quote:
At first the gap wasn't wide enough and I just thought it was strange that it was so narrow, when I put a 25.4mm seatpost with shim in it would turn really easily with the clamp as tight as it would go. No thanks on the clamp, I got a k1 clamp from Germany where I got the frame from and it just seems really loose, I have to tighten it so the 2 sides almost touch for it to hold the seatpost, and it just doesn't seem to fit that well. |
| Tags |
| frames, questions |
Similar Threads
| A few questions | The UniSLAB | Rec.Sport.Unicycling | 9 | 2008-01-20 03:09 PM |
| Just a few questions regarding purchasing. :x | Choy | Just Conversation | 11 | 2007-11-28 04:47 PM |
| A few beginner questions | penguini | Rec.Sport.Unicycling | 12 | 2007-11-26 06:33 PM |
| KH Freeride seat good for freestyle? (+ a few more Q's) | _Ground_Zero_ | Rec.Sport.Unicycling | 8 | 2007-11-23 06:59 PM |
| A few questions... | SqueakyOnion | Rec.Sport.Unicycling | 4 | 2007-07-30 10:46 AM |
