#31 | |
Street. Trial. Flat.
Quote:
__________________
-Brandon Nankivell )--75cm Rolling Hop-'O, 2nd #1 Street + Trials (0-14s) at UniNats 2009 ![]() Most Recent Video |
#32 | |
Quote:
__________________
-Brandon Nankivell )--75cm Rolling Hop-'O, 2nd #1 Street + Trials (0-14s) at UniNats 2009 ![]() Most Recent Video Last edited by Unisykolist; 2008-05-30 at 06:22 AM. |
#33 | |
Quote:
__________________
#34 | |
Quote:
__________________
#35 | |
Registered User
Quote:
Also, to solve the problem of the 3 wheeler being harder to get going, it might be worth trying some longer cranks on it. I've been meaning to, but not got round to it yet. F. Last edited by Fraggle; 2008-05-30 at 08:41 AM. |
#36 | |
Quote:
Ducttape, do you have your bottom and top tyre hard and the middle softer? whats your tyre preffereance?
__________________
#37 |
Proud owner of Kris Holms old shoes
I reckon there must be plenty of people who can ride a two-wheeler. I know of four in NZ alone (myself, Peter Bier, Steve Pavarno and Adam Stone). I have a two-wheeler with 16" wheels which makes it relatively easy to freemount, both static and rolling.
As for freemounting a 3-wheeler I've seen it done by jamming a foot between the lowest and middle tyres, then standing on the pedal. There's a video of Aussie street performer Mr Spin juggling three baseball bats while balancing a glass of water on his head on a 3-wheeler here http://de.youtube.com/watch?v=X_xNbtlgiMI He uses a volunteer to mount his 3-wheeler. Scroll thru to the end as that's where the trick is.
__________________
Take a squizz at my YouTube videos! Last edited by TonyMelton; 2008-05-30 at 11:07 AM. |
#38 | |
Registered User
Quote:
Yes but you'll have no control, in the running mount standing on the back pedal turns the bottom wheel backwards and pushes the unicycle upright. With no drive, the bottom will just freewheel away from you and you'll land flat on your arse. Slipping of multi-wheels, or of the drive cog on a giraffe suddenly turns your uni in to a coaster uni, with no warning.
__________________
Dave - what a thoroughly post-modern subversion of the cycling genre - |
#39 | |
Recreational unicyclist
Quote:
If you moved more into street performance you could include it in your act to get someone to help you get on the three wheeler, as somebody mentioned above. +1 to what kington99 said too.
__________________
1-wheeled-grape: ''I could never do yoga... I'm too fat I was forced to do it in primary school and the results were by no means fun'' ... ''If my belly doesn't scare me though no nakedness will'' Last edited by jamessd; 2008-05-30 at 04:51 PM. |
#40 |
I unicycle for Donuts
I don't know the exact tire pressure on my tires but it's just right for me as was said above you need the middle wheel softest, and the top tire slightly harder while the bottom tire is hardest. Slippage of the middle wheel does matter when running mounting because it acts like the chain and cogs on your normal giraffe and when those slip your unicycle is uncontrolable. If I could time it better I could climb my three wheeler, I've almost got it now but I can't get onto the seat in time, I end up trying to ride my giraffe SIF which is very hard considering how heavy it is. Ihave considered putting a set of cranks on every wheel too, I've even got two spare sets that would work I just don't have two extra sets of pedals.
__________________
BUY MY SHIRTS AND STUFF WATCH MY VIDEOS Uniman Comics Original Thread for Uniman Sigged Quotes |
#41 | |
Ridin' my KH
Quote:
For performing, the 3-wheeler will look approximatel 1/3 more impressive to an audience. Add extra points because it's also taller. Put decorations in the wheels so it's easy to see them rotating in opposite directions. Make sure you idle on it, and if you can, practice walking the wheel up there. Caution: 3-wheelers are heavy, and dismounts can damage them or bend/knock them out of alignment. Treat it like a fragile machine and it will probably hold up longer. As a performer, having an act is more important than having cool props. The first expenditure I'd make, based on the photos you posted, would be for a new seat! Here's some old pictures of multi-wheelers.
__________________
John Foss Email: "jfoss" at "unicycling.com" -- www.unicycling.com ----------------------------------------------- "I ride unicycles against the orders of my doctors. I have six screws and a plate to help hold me together." -- Bungeejoe, 52 |
#42 | |
Anyone coming to Brazil!?
Quote:
I the cranks and the pedals of my tree wheeled... I will study this soultion ![]() Thanks John, your site is full of great pics and cool facts
#43 | |
Quote:
__________________
1-wheeled-grape: ''I could never do yoga... I'm too fat I was forced to do it in primary school and the results were by no means fun'' ... ''If my belly doesn't scare me though no nakedness will'' |
#44 | |
Ridin' my KH
Quote:
That's the short answer. He later brought a "regular" unicycle with the half-wheel to Unicons, but it always ended up leaving marks on the floor. The "150", as it was called, was surprisingly rideable if you could already ride a 2-wheeler. Yes, when the wheel is up it's freewheeling. Basic rule of riding it: don't freewheel any longer than necessary!
__________________
#45 | |
Registered User
I'm not sure that a 1/2 wheel unicycle does work. Seems like you would have to hop-up each half rotation in order to get up on the half part.
A "no wheel" unicycle is a unicycle minus the tire, tube hub and spokes. Basically you have the hub and cranks sitting on the floor. It's basically a silly prop. Quote:
__________________
><> Unicycle for (reducing the) Buddha <>< |
| Tags |
| multiwheeled, unicycles |
Similar Threads
| Plastic wheeled unicycles | harper | Rec.Sport.Unicycling | 23 | 2009-05-01 09:33 PM |
| Want to buy a multi wheeled unicycle but where? | jonnywebbhead | Rec.Sport.Unicycling | 5 | 2004-02-12 12:48 AM |
| multi wheeled unicycles | Jeff Lutkus | Rec.Sport.Unicycling | 1 | 2001-06-04 10:02 PM |
| Multi wheeled uni's | Gary Titherly | Rec.Sport.Unicycling | 2 | 2000-09-26 06:04 AM |
| Double wheeled unicycles? | Melville the Fourth | Rec.Sport.Unicycling | 6 | 1999-08-15 02:21 AM |
