#1 |
Furry-kun
I'm having troubles writing a novel I am trying to write right now. I need some help with writing methods, I thought that if I wrote the basic storyline, added more parts, put in detail, put it in sentences then add more detail. Would that work? If not could someone tell me some helpful methods?
__________________
My dragon ate the other wheel. I am the dragon. |
#2 |
Nice kids don't drop acid
That sounds like a good way to go about it.
I only write songs, poem, short stories and such but I could also suggest writing it as a short story first. Then rewrite it as a short story in 5 parts and then rewrite it as a novel.
__________________
If Jackie was a girl, I thinkd id date her. ~Jerrick If my government ever decides to blow me up, I hope they will choose to do it in a humane way also. ~johnfoss hinunggbinu!!! ~JJtheunicycle
#3 |
Furry-kun
Ok, I'll try that, if it doesn't work out I'll go back to my old method.
__________________
#4 |
I'm just suggesting that... You're way sounds really good too.
Do whatever is easiest.
__________________
#5 |
Patronus unicycleus
start easy. dont plow into a novel to start with. work on developing a style through short stories and essays. Jot down the story line you have and maybe work on a few short stories using it. nothing to 'epic'. Easiest things to write about are things that you have lived through. You can make even something as simple as eating a bisicuit amazing by using words
if that makes sense.goodluck.
__________________
Your life is a storm, thunder is your music and lightning is your electric dancing legs, groove on friends. Groove on.
#6 | |
onetiredlover
Rewrite,rewrite,rewrite
Quote:
Good morning from the right coast of Canada. Now writing is something I can help with, having been paid to do it since I was twenty. It is easy to get in the middle of a piece and get discouraged. Here are my suggestions. 1. Read this: it contains everything about dramatic structure there is to know. This is Aristotle's "Poetics." http://classics.mit.edu/Aristotle/poetics.html 2. Read. Robert Hughes, an Australian art critic, who wrote what I think is the best history of OZ ever. Look for " A Distant Shore". You may also want to look at the book he created for the Barcelona Olympics. Look at the style, the organization of material. 3.Writing is an unenviable concern. Lots of time you simply don't know what to say, or worse, say what you don't mean in a bad way. Read a dictionary every day, a page a day. And never try to push the writing. It will not work. 4. The more time you spend with the work, the more ways you will see to say the things you mean. It is the hardest work I can imagine. 5. If you want to see the culmination of storytelling, read "The Old Man and the Sea." It is for a lot of reasons a manipulation of the form, endlessly sentimental, but just look at the language. You know, if you run Windows , there is a little program that analyzes the quality of your writing by looking at word length, syllable count and something called the Flesch Readability Quotient. This is a useful tool. You may also look at "Bullshot" , a free program that points out b***s**t in your writing. Hemingway scored in the low 80's which means his writing was available to anyone with a sixth grade education. I did a similar look at Thomas McGuane an American writer who has turned out incredible novels, with language to kill for. He scored the same as Hemingway, though their styles are fundamentally different. So, that's sort of a wide-ranging overview of writing. But never stop, never be discouraged and just sit in front of the keyboard everyday no matter whether you have an idea or not. Like riding distance, some days you have no idea what you are doing. Ignore this impulse. Writing a novel is like running a marathon. Take on water and never quit. With best from here, william dockrill
__________________
A Nova Scotia rider. Last edited by ridethelobster2008; 2008-05-11 at 12:30 PM. |
#7 |
768 - It's in your DNA
With the advent of word processors, it is easy to very quickly write stream of consciousness prose. This can be subsequently proofread with the nonsense and errors being corrected later. One of the things I tell grad students writing their theses is to do a very rough outline and then fill it in quickly without regard to grammar, structure, or spelling. Then go back and make it first readable, then precise, and finally artistic. In theory this should work for fiction as well.
__________________
-Greg Harper Destroying the climate by shutting down nuclear power plants, one by one, since 1979. JC is the only main man. There can be no other. "A fool on a unicycle is redundant" - J.D. Miller |
#8 | |
Dave Lowell
Quote:
#9 | |
Waffle-Tosser, Time-bider and JCTK
Location: the bustling metropolis of Nelspruitia, south africa
Quote:
It's probably not usual advice, but it strikes me as a good idea. |
#10 |
Last of the Dogmato-Revisionists
Here is a long list of comments about writing made by writers. It is annoyingly laid out, centered with a cloud background. And the odds are good that 25 to 50 percent of the quotes are misattributed. But stranger things have happened than that someone found inspiration from a web page.
__________________
Raphael Lasar To plotz is human, to schvitz divine. |
#11 | |
onetiredlover
Advice like this you can take to the bank.
Quote:
Once I started writing novels, I used something called "Power Structure", a nice piece of software that is essentially an editor. It had a dozen different views of the story, an easy way to keep the chapters and the characters straight, even a view of the dramatic tension (it could adjusted in increment of 1% point. Might be useful to have a look at something like that. best, william
__________________
A Nova Scotia rider. |
#12 | |
onetiredlover
Hemingway and work ethic.
Quote:
I have done the Thompson exercise, using other writers. It can be a useful, clarifying exercise. Best, william Oh and he thought 300 words a day was plenty. He always left himself an idea to start with the next day.
__________________
A Nova Scotia rider. Last edited by ridethelobster2008; 2008-05-12 at 02:52 PM. |
#13 |
Tailgate at your own risk...
Before you write anything, read this book. They've added pictures to help those with short attention spans.
Whether you're writing a novel or merely your next unicyclist.com post, it will serve you well.
__________________
Tom Blackwood is like a shadowy figure behind a 36" tree... |
#14 |
Yes?
This thread is part of what has inspired me to write an autobiography/autobiographical novel. It's going to take a while--perhaps years, but I'm going to keep at it.
__________________
"...if a bunch of fellow unicyclists can't rally around, commiserate and say 'chin up, lad', then what is this world coming to?" -GILD |
#15 | |
Dave Lowell
Quote:
| Tags |
| troubles, writing |
Similar Threads
| Writing Thread. | Kyle_Destroyer | Just Conversation & Introduce Yourself | 48 | 2008-10-08 03:14 AM |
| Writing a personal statement | ivan | Just Conversation & Introduce Yourself | 5 | 2006-11-06 07:48 AM |
| Speech writing for Bush | Tellurider | Just Conversation & Introduce Yourself | 4 | 2005-10-03 08:10 PM |
| writing request! | Tammy Marsh | General Unicycling Discussions | 0 | 2002-07-08 07:08 PM |
