Unicyclist Community
Reply
Old 2008-04-19, 04:20 PM   #1
phlegm
Registered User
phlegm's Avatar
KH/Schlumpf Hub -> loose bearing cup??
I've never had this happen before. A bearing cup came loose while I was riding. I did a ~35mile ride yesterday with a mix of asphalt and dirt, and toward the end after a UPD I noticed that the wheel looked crooked. When I looked more closely I saw that the non-tightened down bearing cup on my geared KH29 had come loose. The bolts had backed themselves out somehow, fortunately not enough for them to fall out.
Has anyone else had this happen? Do you think it is specific to using the geared hub? Maybe the shortish 125 mm cranks? Too much bumpy offroad or climbing while geared up?
phlegm is offline   Reply With Quote
Old 2008-04-19, 07:30 PM   #2
johnfoss
North Shore ridin'
johnfoss's Avatar
Loose bearing cups/holders can happen on any unicycle. You were lucky to notice while you still had the bolts! Back in the bad old days, inexpensive unicycles with main cap bearings just had lockwashers, if those. We replaced them with those self-locking nuts with the nylon inside. Those seem to stay put much better than anything else.
Any time you reassemble the wheel into the frame, expect to need to tighten those bolts after a bit of riding. It's when you forget to do this you usually have problems (I speak from experience)...
The same applies to square taper cranks.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2008-04-19, 07:58 PM   #3
phlegm
Registered User
phlegm's Avatar
What seems strange to me is that I've never had a bearing cup go that loose before, and I had just checked all the bolts right before my ride yesterday. Maybe I need to loctite them.
Old 2008-04-19, 08:28 PM   #4
Jim
Is this with a new Kris Holm frame? When they are a new there is often some blue stuff on the bolts which I think is threadlock, if you were re-using an old frame this threadlock might have worn off.
Just an idea.
It may be the bearing cups need tightening more with KH Schlumpf hubs - I don't own one of these hubs so am not an expert.
jim
Jim is offline   Reply With Quote
Old 2008-04-20, 02:50 AM   #5
pkittle
NorCal Riding Project
pkittle's Avatar
I've had this happen several times. Now I use blue loctite on the bolt threads each time I remove and reinstall those bolts.
__________________
Peter Kittle * Chico, CA
"The Revolution is just a t-shirt away."
--Billy Bragg
pkittle is offline   Reply With Quote
Old 2008-04-20, 03:46 AM   #6
chuckaeronut
Lover of Geared 36ers!
chuckaeronut's Avatar
Send a message via AIM to chuckaeronut
Yeah, I wouldn't worry about it. A bit of loctite should do you fine, methinks. I have stuff go loose all the time, and I loctite it, and it helps (and most of the time, completely cures), but I always still bring my tools along.
__________________
Uni to work to eat to live to uni to work to...!
chuckaeronut is offline   Reply With Quote
Old 2008-04-20, 07:26 PM   #7
siafirede
Flex Your Head
siafirede's Avatar
I had the same bearing cap on the same side come loose while I was riding my kh/schlumpf guni...and I lost a bolt. It was because I did not have that side tightened as much as I should...this was the only time as bearing cap has come loose for me as well, so I made sure to tighten that side a little more than usual as well.
__________________
-James
siafirede is offline   Reply With Quote
Reply
Tags
>, bearing, cup, hub, kh or schlumpf, loose
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Triton 36er w/KH Schlumpf Hub osmundo Unicycle Product Reviews 50 2008-07-17 01:59 PM
KH Schlumpf Muni Hub Review seriousslacker General Unicycling Discussions 81 2008-04-01 02:58 PM
KH/Schlumpf hub price fatlardboy13 General Unicycling Discussions 78 2008-02-03 11:21 PM
pics of kh/schlumpf hub siafirede General Unicycling Discussions 72 2007-11-16 09:38 AM
Copyright © 2001-2005 Gilby
Page generated in 0.06618 seconds with 10 queries
