Unicyclist Community
Reply
Old 1995-08-04, 11:03 PM   #1
Beirne Konarski
Newsgroup User
Posts: n/a
Forwarded message:
[color=blue]>[/color]
[color=blue]> This seems like a dumb question, i need to get a new helmet for my uni, my old[/color]
[color=blue]> one is cracked. Do you need a helemt for a uni (i don't mean law, a mean can[/color]
[color=blue]> you easilyfall on your head?), Should i get a good one or a cheap one. Also,[/color]
[color=blue]> when ever i sit on my seat, it will move down, or swivel around. ((when i[/color]
[color=blue]> tighten it a lot it barely slips) is this normal? It might be that i tried[/color]
[color=blue]> using a different seat, which had oil on it, so it made the pipe sliperey.[/color]
I won't tell you what to do regarding helmets, so that I won't feel bad if you
smash your head, but I'll tell you what I do. I don't wear a helmet for
non-street riding, and didn't own one until two years ago, and I've ridden the
uni 18 years. I've only taken one good head thump, and that was when I was
learning to ride backward in the early days. I usually would roll when I'd fall,
but for some reason I didn't once and all the momentum went into my head as it
hit the asphalt. No permanent damage.
I do own a helmet now. When my wife bought a bicycle for street use I said she
should have a helmet, and she pointed out that I should have one since I ride
my uni to work. I wear it when commuting, but never the rest of the time. At
the NUC last week I didn't see anyone wear one when they weren't required to by
the rules.
So, the risks of head damage from regular unicycle riding is fairly low. If you
want a helmet, though, you might as well buy a good one, on the logic that if
you care about your skull, you should care a lot.
Your seat is not supposed to move at all. You will want to clean off the oil and
crank it down tight. If you have a quick adjuster you might want to replace it
with a knurled bolt.
Beirne
Beirne "Bern" Konarski | Unicycling Web Page: bkonarsk@mcs.kent.edu |
http://nimitz.mcs.kent.edu/~bkonarsk/ Kent State University | "Untouched by
Scandal" |
Reply
Tags
fwd, helmet
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Reevu helmet - first impressions aardvark General Unicycling Discussions 12 2010-05-25 09:21 PM
My last ride without a helmet onewheeldave General Unicycling Discussions 25 2004-07-10 08:12 AM
Fule face helmet - review Mikefule General Unicycling Discussions 8 2004-01-14 05:56 PM
What helmet are you using? joona General Unicycling Discussions 19 2003-12-02 08:15 PM
reccomend a good popular helmet nbrazzi General Unicycling Discussions 3 2003-02-26 05:46 PM
Copyright © 2001-2005 Gilby
Page generated in 0.05809 seconds with 10 queries
